Re: 1971 chev tractor puller
got some work done on the truck over the last couple of days. welded the rear end, added some wheelie bars, changed the offset on a set of wheels so i can finally use the puller tires i have for it. next up is to build a weight rack in the bed, and do a little motor work. hopefully next pull, the front end will get off the ground...
1995 Chevy 2500 4x4 diesel (daily driver) 1971 Chevy 2WD pulling truck "Whiplash" "The Bandit" twin engine pulling tractor "Hog Wild" 2wd econoline pulling truck ![]() |
![]() Join Date: Jul 2012
Very cool. Can't wait to see some video with the puller tires on there. Let's see some air under the front tires, too! But if not, it's still a pretty cool build, and lots different than most of the others. Nice change of pace.
What plans do you have for the motor?
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
i probably wont be running the puller tires until next season because because they would bump me to the exhibition class which would mean no trophy lol. as far as the motor goes, i adjusted the valves and changed the timing. when i pulled the first time with it, it sounded a little fluttery so i knew i needed to do a little work on it. no surprise since that was the first real hard run on the motor since i put it back together. the next pull is in august so ive got plenty of time to work on the truck.
Still Learning
I love the video! that has to be the coolest puller out there.
thanks mcbassin. im the only guy that pulls a 2wd gas pick up out here, everybody else pulls with a diesel pick up. honestly, seeing the same diesel trucks "roll coal" as the youngsters put it and pull the sled eveytime gets a little boring from a spectators stand point. im hoping that my truck will make some of the farm kids around here bring the 2wd farm trucks out and try to compete lol
since i took the headlight buckets and everything out of the front of the truck, i wanted to replace the headlight areas with some aluminum plates so i did. i custom cut them myself but thought they could use a little something extra...
thought you guys might like this one. so, the wife told me that i couldnt get both wheelstanders on the trailer, well, this is what happened ha ha ha
![]() no, they are not touching. there is about 3'' between them. the 71 could also move forward more. ![]()
6>8 Plugless........
![]() Join Date: Sep 2007
Nice project! One of my friends has a nasty 2wd with a 540 in it! My machine shop guy used to have a 2wd dodge cummins puller. That thing was a blast to watch!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
we didnt do too bad, 190ft the first pull, 184.64ft the second time out and the third time was exhibition because we changed the tires so i didnt pay attention to the distance. all in all still not too bad for a stock 400 that is needing some rings thrown at it. before the next pulls, we are going to swap out the 400 for a 454. next pulls are sept. 20&21 but if we dont get it done by then, there is an end of the year pull in eastern washington in oct.
Where are the pulls in late September? would love to come see this truck run!!!
lynden,wa just a few minutes south of canada
so, today i picked up a 454 to swap into the truck. the 400 is gonna go on a stand and will probably find its way into another project at some point. its a stock 454 but it will get some goodies thrown its way before it goes into the truck.
#13 |
![]() ![]() Join Date: Jul 2002
Nice!!
#14 |
got the motor swap done today. got it running good and smooth, cant wait for the next pull to try out the new motor. still gotta tie up a few loose ends but im happy with it.
http://s582.photobucket.com/user/car...580fb.mp4.html ![]() ![]()
#15 |
#16 |
It looks really nice!
#17 |
Man this thing is coming along awesome. I love the details and creativity you're putting into this build. One question though, where did you get the front light bezels?
#18 |
thanks low&slow. they are actually a 4'' led stop, turn, and tail light that i ordered off of ebay for another project that got traded off. they have the standard rubber grommet and the "chrome'' ring is plastic and held on with three screws. the plates they are mounted on though, i made those myself out of a road sign lol.
#19 |
Cool stuff! You are correct, not many gas pullers left, especially 2wd
Posted via Mobile Device |
#20 |
Not Sure If You Answered This Already(sorry didnt read the past posts again) But Where Did You Find Your Round Fuel Tank? I'm Also Saving A Truck From The Crusher Into A Puller
Great Build And Hope You Don't Mind Me Using Yours For Ideas
1968 Chevy Longhorn "Built 4 It" Pulling Truck 1985 Chevy Corvette Z51 1997 Chevy S10 Custom Build Street Truck |
#21 |
i dont mind one bit Chevy_Guy2005. i used a lot of idea from the 80's when i was building thins truck. i got my tank off of ebay from a seller called thetankguy. its the same tank that speedway motors sells but theirs were all on back order when i last looked. are you gonna do a build thread for your truck too?
#22 |
any new progress to report? I know the season is probably over but that's usually when you make a lot changes...
married to TARA, that makes me the TARA-fied1 |
#23 |
Been a long time since I posted anything lol. A few years ago I sold this truck and focused on our other truck. This past Monday however, I bought it back for a couple hundred bucks as a roller. It's going to be getting a new rear end, new frame from behind the cab out the back, 18.4-16.1 pulling tires, and a mild built 454. Its going to be a completely different animal this time around.
I would upload some pics but they are not working 🤔
