Old 08-19-2013, 03:44 PM   #51
Ta2Don
Ta2Don's Avatar
Re: 64 StepSide - Let's the games begin
Originally Posted by Bomp View Post
Got my attention.
Sub'd
Me too!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 08-19-2013, 09:56 PM   #52
wayno
Got some color on the fire-wall - trying to decide if I go with the classic white on top of the cab or not... productive day though.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 08-19-2013, 10:00 PM   #53
wayno
And in the interior - the clear didn't lay as flat as I would like - I think it was due to spray in close quarters... laid much better on the firewall - so I'll probably cut it with 1000 grit and give it another go maybe with a little more pressure - any thoughts here appreciated.
Old 08-20-2013, 08:56 PM   #54
step65
Nice work great build. Thanks for sharing. I really like the wheels
step65 is offline   Reply With Quote
Old 08-21-2013, 01:16 PM   #55
TJ's Chevy
TJ's Chevy's Avatar
Consider me subscribed to this one. Great work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-05-2013, 11:07 PM   #56
wayno
Thanks guys... got the old girl set back over the frame - can't find the two front shims so have a couple of them on order then hopefully I can start putting this old girl back together... a lot of little modifications to linkages and stuff to deal with - the manual clutch etc... but can't tell you how much better I feel just having her sitting back on the frame - let all the air out and she lays rockers.
Old 09-13-2013, 08:19 AM   #57
wayno
New shims are in - front two mounts are in - had to clearance the holes so the new mounts would sit down in - have to do the rear two - since I was up under the front end - I decided to get the new brake lines run in the front.
Old 09-21-2013, 08:39 PM   #58
wayno
Surgery to the transmission hump complete - looks like that TKO was born there...
Old 09-21-2013, 09:34 PM   #59
T Smith
T Smith's Avatar
I'd like to see/hear more details on the TKO swap. Where did you get the TKO and what shifter did you use? What location is the shifter? Are you using the bench seat?
More details! More pictures!
T Smith is offline   Reply With Quote
Old 09-21-2013, 10:14 PM   #60
CDNchevydude
CDNchevydude's Avatar
Nice work man! Subscribed
87 R-10 SWB
CDNchevydude is offline   Reply With Quote
Old 09-22-2013, 07:54 AM   #61
Neatbeard
Neatbeard's Avatar
Ooooo loving the look of this!
My old truck:
'66 Shortbed Stepside - Ex USAF - Shiny and new on the inside & underside, original patina on the outside. - http://67-72chevytrucks.com/vboard/s...d.php?t=487701
Tattooed pinstriper and graphic designer with an awesome award winning beard! Check me out at http://www.vontash.co.uk
Neatbeard is offline   Reply With Quote
Old 09-22-2013, 10:26 PM   #62
wayno
TKO is the mid shifter location - told they don't do the front location anymore - not sure if there's any truth to that or not... don't know what I'm doing for a shifter yet - but dropped the seat in and it looks like I'll have plenty options - doesn't look like I'll have any issues with clearance - put the doors on today - had to do some surgery - will post some pictures of that tomorrow once I get that all finished up... here's a shot with the seat in and a shot of the girl side to... starting to feel like I am making some ground... have to figure out how I'm going to raise the bed floor in the back due to the extreme notch...
Old 09-25-2013, 10:55 AM   #63
wayno
So I tack welded the rear pan in place - wasn't sure if this the direction I was going to go or not - but after seeing it on here..... I really kinda like the look of it. Also mocked up the stepside fender so I could get a look at how things were coming together.
Old 09-25-2013, 01:25 PM   #64
Jmorales3181
Jmorales3181's Avatar
She is looking good man!!!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 09-26-2013, 07:42 PM   #65
wayno
Thanks man - making some slow but steady progress this week. Here's adding the end cap on the passenger side - not an ounce of mud on this - amazed how far my skills have come since the beginning of this thing.Name:  IMG_0457.JPG
Old 09-26-2013, 08:08 PM   #66
Ta2Don
Ta2Don's Avatar
Sweet!
DON
Proverbs 27:17
Old 09-27-2013, 12:02 PM   #67
Jimbabwe
Jimbabwe's Avatar
Nice! I like those.
Jimbabwe is offline   Reply With Quote
Old 09-27-2013, 05:43 PM   #68
Bomp
Bomp's Avatar
Gaining on the metal working skillz. Some serious talent.
Bomp is offline   Reply With Quote
Old 09-27-2013, 07:00 PM   #69
NEWFISHER
NEWFISHER's Avatar
Have you seen any clean floor lift threads? I'm ding mine shortly and was looking for some guidance
NEWFISHER is offline   Reply With Quote
Old 09-28-2013, 09:13 PM   #70
19GMC66
19GMC66's Avatar
Cool build, like the color and love to see a stepper laid out!
19GMC66 is offline   Reply With Quote
Old 09-30-2013, 07:50 AM   #71
wayno
Coming from you Bomp that's a real compliment.. thanks man.
Old 09-30-2013, 07:53 AM   #72
wayno
I have been thumbing through several - I have been avoiding it a bit myself because I don't to screw it up. I was going to use some 1" tubing but I want to put wood back down and I don't think that's going to be wide enough on the two outsides... but I do have plans to tackle that this week so hopefully I will be able to provide an update soon enough
Old 10-07-2013, 10:59 AM   #73
wayno
Got the radiator and the inside of the front fenders all painted up... doing the body work on the front nose - hopefully get that into some paint over the next day or two. Had the rails for the bed sand blasted - so hopefully can get that all picked up tonight and start mocking up the rear of this thing.
Old 10-07-2013, 01:42 PM   #74
19GMC66
19GMC66's Avatar
What color did you go with? Looks awesome!
Old 10-07-2013, 09:34 PM   #75
wayno
It's a turquoise metallic - can't tell you how many colors it was in my head before settling on this - hope the rest of the truck turns out as good as the radiator support lol.
