#51 |
![]() Join Date: May 2012
Re: 1967 C10 SWB Fleetside Project
Thank you I think it was a great find as well. Now just test fitting rockers and fitting cab corners as well.
Garage Built |
#52 |
No cab mounts yet, still needs rockers and corners but couldn't help seeing what its going to look like. That and still debating on new coil springs or air bag system.
Garage Built |
#53 |
Picked up a sweet set of prothane body mounts from Travis at pro performance a board vender. Very excellent service and highly recommended by this user. Cab to box line sits pretty good for just setting them in place.
Garage Built |
#54 |
Ahhh!! Put the other wheels back on!
![]() ![]() Posted via Mobile Device
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#55 | |
I agree, it'll help the ride quality for sure. I'm very happy with the new parts and progress so far. Wheels are set aside while I take the body on and off for fitment and corners/rocker install coming up after the wood fence is built tomorrow at our place. They sure make it look better than the stockers though.
Garage Built |
#56 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Great job so far, super find on the cab too!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#57 |
Thanks so much. I really am loving this build. Couldn't have asked for a better project. I want to fire the engine, but figure I better have the core support on, radiator in, and exhaust then figure out how to wire it to brake it in.
Garage Built |
#58 |
Not much progress lately. Been organizing the garage a lot which helps free up room to work on the truck. I need to get the box floor cleaned up and undercoated and lined. And work on the corners rockers and primer the cab and box. Thats my goal the next 2 months. Wish me luck.
Garage Built |
#59 |
New Guy.... I am installing an automatic TH350 in my 67 Chevy C10 and am wondering if someone could tell me what would be the best floor shifter for my application.
Thanks |
#60 |
I have been trying to upload photos for the last few days and get a message that says upload failed. Anyone have any ideas on a solution so I can keep posting photos? I just usually upload from my hard drive. I don't have online photo center.
Garage Built |
#61 |
I cut about a 1 1/2 inch out of the lower rails. And put in a 20 gallon 1969 f*rd mustang gas tank in. Fits very nice I think. I'm planning to support the tank with a steel frame and support the frame with a rear c-channel if its needed. Love the low profile look of the tank. It sits up high, and I like the bed fill.
Garage Built |
#62 |
Did some more work to the truck. I mounted the bed floor just to see how the gas tank will line up. Worked out perfect. Looks like whoever cut the hole in the bed before I owned it saved me some work. Time to get that floor sandblasted and undercoated/lined.
Garage Built |
#63 |
My son Bentley a (3) yr old and I have spent most of our labor day weekend working in the garage between the truck and organizing. We had a blast and got the suspension all dialed in. The "bent fame" was a coil spring issue after all. And I found out that that cross member is meant to be angled aft on the pass side that way. All is good!
Garage Built |
#64 |
mocked up my front end to start lining up the rockers.... that's what I tell myself at least. Its nice to see it look like a truck again, however have a long way to go with body work and sheet metal repair.
Garage Built |
#65 |
Whatever keeps you motivated. Keep it up.
#66 |
Garage Built |
#67 |
Recap on the 69 mustang 20 gallon tank. I picked it up off ebay and it was like 89 dollars complete shipped with pickup and sending unit lock ring ect. I trimmed 1 1/2" off the lower frame rail. Then I cut mocked it up and built some side brackets using 1 1/2" x 1/8" angle iron. I used some stock holes in frame that were a bit larger than the bolt hole I drilled for the support. I did this so I can tweek it right before I put in some bigger bolts. Also im in the process of mocking up a rear support for the frame since I "weakened" it a bit. I'm not sure what to do with a sending unit yet but at least it will hold gas.
Garage Built |
#68 |
Im so stoked!!!! I got the 400 sbc started. Fired right up ran half throttle for about 1 min and sounds very healthy. It was open pipes but man it sounded mean. True break in to follow after exhaust and tach. Just got a radiator and a couple hundred dollars worth of parts for it..... totally worth it. I plan to try for full exhaust this weekend as well. Pics and video to follow.
Garage Built |
#69 |
That's awesome! Congrats on the progress.
#70 |
http://www.youtube.com/watch?v=vdHFz...ature=youtu.be
link to the first fire up. Now need to time it and break in the cam. More on that after this next week when I get the super 10 mufflers and fit up all the coolant lines ect.
Garage Built |
#71 |
I have a stiff deadline of March 7th to get the truck drivable. My wife and I will celebrate 5 years of marriage that weekend and we both want to drive in the truck even if its "under construction" on the exterior. Sounds like I'm going to have my hands full on the mechanical and safety portion of the build. The good news is my wife's on board for late nights in the garage till then. May need your guys help along the way.
Garage Built |
#72 |
That's an awesome reason for the deadline. Good Luck!
#73 |
Traded a set of calipers, and a rear view mirror for a set of nice recovered seats that I plan to build into my interior. I plan on building a center council seat that somewhat resembles buddy buckets, or late model 40/20/40 seats.
Garage Built |
#74 |
First try at getting youtube link on page well see?
Garage Built |
#75 |
I like your seats. Any idea what they are out of?
71 swb 350/4sp manual 5/7 static drop |
