Old 01-22-2014, 11:57 PM   #51
BurgerMan
Re: DIY Disc Brake Conversion
Good work so far, been following the thread closely. Pictures are helpful. Just one question: did you buy the brackets to mount the calipers? I think I missed that part.
1977 Chevy K20
1959 Chevy Apache 3200
BurgerMan is offline   Reply With Quote
Old 01-26-2014, 08:23 PM   #52
whitedog76
I went back to the drawing board and came up with this.
http://s1074.photobucket.com/user/wh...tml?sort=6&o=3
http://s1074.photobucket.com/user/wh...tml?sort=6&o=4
I know the top bracket will work, I have a template made out of wood. I wanted some more support, so I came up with the bottom piece. The top will bolt to the backside of spindle and the bottom will bolt to the front side. I'll have to come up with a spacer block to join the two, either by bolting them together or welding them.
whitedog76 is offline   Reply With Quote
Old 01-28-2014, 10:19 AM   #53
mechanixman
mechanixman's Avatar
Thanks Burgerman, I don't have brackets yet, That last picture was me just holding it in place. I'm going to pick up some 3/8" steel plate and make mine out of that. I'll post the drawings out so everyone can make their own if they wanted to. But I like where whitedog76 is going. When you make your on, you shouldn't have to worry about what thickness metal you need. It'll fit just the same with 1/4" or 3/8".
Whitedog, that looks pretty slick!
Anyone else think it's interesting that they had tapered roller bearing standard in 1936 on the rear axle, but kept the front axle the same with normal bearings?
http://www.youtube.com/watch?feature...j7JSpSpU#t=152
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 01-28-2014, 03:50 PM   #54
whitedog76
It is interesting how the General, and other manufacturers pick and choose their battles.
I'm guessing it had to do with how trucks were used at the time. Most trucks had the rear axle centered under the bed for weight distribution. You didn't see a truck pulling a trailer back then, if you needed to haul something bigger, you got a bigger truck. It may have had to do with convenience also. The HO52 and HO72 use the same wheel bearings, so if you had a 3600 or a 4100 truck, you could use the same bearing.
I still haven't figured out why GM paired the front wheel bearings up like they did. The 3.15x1.5" Inner bearing is actually still a commone size, but the outer .905x2.24 is an oddball by all standards.
Chris
Old 01-28-2014, 05:18 PM   #55
BurgerMan
WhiteDog, those links to the images didn't work. Says they were removed.
Mechanixman, what is the reason you aren't buying the bracket set that is available? Is it because of price?
http://www.speedwaymotors.com/Basic-...ckup,7688.html
I'm at a weird point, i am not sure if these will work on my 6 lug pattern, but I assume they should, just need a different rotor.
1977 Chevy K20
Old 01-28-2014, 10:02 PM   #56
whitedog76
My mistake. I moved my pics around in my albums.
http://s1074.photobucket.com/user/wh...99957045988476
Old 02-09-2014, 06:52 PM   #57
mikec4193
mikec4193's Avatar
I am curious about if those Speedway parts will fit or not....I think I can come up with the calipers and those rotors from my local NAPA store...larger lug studs I think they sell too..They dont sell that bracket to hold the caliper on tho...has anybody tried to see if these will work with the 8 lugs rotors and calipers?
Any insight would be great...
MikeC
mikec4193 is offline   Reply With Quote
Old 02-09-2014, 08:01 PM   #58
mechanixman
They'll fit the spindle, not the new caliper.
Yeah everything except the bracket you can buy at your local auto parts store
At the beginning of this thread 2 other people commented on how they made their 8 lug trucks work with disk brakes. But as long as everything fits, there is no reason that it shouldn't work.
-Nick
Projects:
Old 02-13-2014, 01:38 AM   #59
BurgerMan
-Works with 5 on 4-3/4 Inch bolt patterns
From the speedway page....i guess i just don't understand why they say that if they work with all patterns.
1977 Chevy K20
Old 02-14-2014, 08:22 PM   #60
mikec4193
mikec4193's Avatar
Hey Mechanixman
So once you figure out the bracket configuration you will have something that all the parts can be bought over the counter at the local parts store...I hope you can share the bracket sketch dimensions so I can send a copy off to the local machine shop and have him make up a pair for me...
Suddenly that makes a stock 1 ton that much more drive-able and stoppable too...thanks for all leg work your are doing. I think you are saving a lot of us from having to swap front axles too.
Thank you thank you thank you...
MikeC
Old 02-19-2014, 02:49 PM   #61
mechanixman
MikeC
Ha Ha No problem!
Yeah that's the goal. This should be the closest thing to a kit so far. and when all is said and done, I'll make a recap of the whole swap.
Sorry it's been a while, I've been trying to juggle a bunch of things at once, between this, having the driveline redone, planning out a straight axle rack and pinion set up, and then all this FRIGGIN SNOW.
I brought the original backing plate to school to measure out the hole pattern for the spindle. Got this far. Now I'll take this template and finishing measuring the caliper side of the bracket.
-Nick
Projects:
Old 02-22-2014, 04:04 PM   #62
whitedog76
Nick-
I was cleaning out my "favorites" and found this link I saved awhile back. Maybe it'll give you some inspiration.
http://s1074.photobucket.com/user/wh...99006953628577
http://www.performanceonline.com/blo...isc-brake-kit/
Old 02-22-2014, 04:12 PM   #63
whitedog76
Old 02-23-2014, 12:40 AM   #64
mechanixman
That's fantastic!
I hadn't thought of setting up spacers like that. Thank you!
-Nick
Projects:
Old 02-23-2014, 01:34 AM   #65
BurgerMan
That looks like it would be super, but i just bought all the parts to rebuild my rear drums. Same idea bracket for the front? Does it need the spacers?
1977 Chevy K20
Old 02-23-2014, 03:48 PM   #66
whitedog76
That's actually a setup from a 9" Ford kit.
It's basically the same as one of my original ideas.
Old 03-14-2014, 12:12 AM   #67
yossarian19
So, anything new?
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 03-14-2014, 09:20 PM   #68
mechanixman
I'm afraid not much as of late.
I've been finding the right design for the spindle side of the bracket, the problem being keeping enough material there for the bolt to support, yet still allowing it to fit properly.
It's hard to get the right measurements for the caliper, so it's been a whole lot of guess and check. Getting a ballpark guess, make a template, try to adjust it, make another template, realize you screwed up again, make yet another template........
I'm almost there
-Nick
Projects:
Old 03-15-2014, 08:01 AM   #69
FarmerSid
FarmerSid's Avatar
Hey Nick, what are you using for software? SolidEdge or SolidWorks? Is that MasterCAM as well?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 03-15-2014, 09:15 AM   #70
mechanixman
I'm using Autodesk Inventor. For this particular project, I just make a .DXF of the drawing file, and send it plasma cam for our plasma cutter.
But otherwise, its inventor to Mastercam mx6.
-Nick
Projects:
Old 03-17-2014, 05:26 PM   #71
whitedog76
Someone beat us Nick
http://www.stovebolt.com/ubbthreads/...77#Post1014977
http://s1206.photobucket.com/user/gi...26406476988996
Old 03-17-2014, 05:28 PM   #72
whitedog76
Here's some pics
Old 03-18-2014, 08:15 AM   #73
mikec4193
mikec4193's Avatar
Hi Whitedog
I just went over to the Stovebolt site...looks like this might work...How long do you think you are going to have to make the lug studs??
Do you think they screw the billet spacer to the existing vintage Chevy truck hub?
I knew someone was gonna figure this out. Thank GOD for the internet. I would still be scratching my head on this one for sure...
MikeC
Old 03-18-2014, 12:39 PM   #74
whitedog76
Even though I kind of like the looks of the bracket. After talking with him I'm not for sure if I like the complete setup. He's using a 1.5" spacer behind the rotor. With that being said, he would have to be using something like a 3.5"-4" wheel stud. I would want a wheel with a heavy offset then. Something from a 99 and up truck or 03 and newer van.
I think I will stick with my setup for now and keep tweaking it.
Old 03-18-2014, 01:04 PM   #75
mechanixman
Aww man..
I don't see any kind of plans though.
Why the spacer behind the rotor?
If anything, I'd bring the rotor and caliper back farther.
-Nick
Projects:
