Old 12-10-2016, 09:59 PM   #51
slydogg76
Re: 52 pickup 77 frame 454bbc
Finished the leaf springs on the drivers side, so I had to see what it looked like on its tires since I lowered it. It's nice and low in front but rear is still a little high.Name:  image.jpg
slydogg76 is offline   Reply With Quote
Old 12-10-2016, 10:01 PM   #52
slydogg76
My dog photo bombName:  image.jpg
Old 12-27-2016, 09:39 AM   #53
slydogg76
Got a little more sandblasting done on the leaf springs and other suspension parts, but now its too cold to paint them. Will have to wait til I get the garage insulated and heated. Received the tail gate chains and hinges from Santa.Name:  tailgat_back angle.jpg
Old 01-17-2017, 10:29 AM   #54
slydogg76
So I started welding in the patch panels that I have had for a few years now, that were just screwed into place. I decided to do the majority of the work with butt welds. Didn't care for the overlapping of metal, especially when it comes to water getting into the holes or cracks.
This is my first attempt at welding, what do you think?
Name:  First Tacks_Welding.jpg
Name:  Tacks ground down_welding.jpg
Name:  More tacks ground down_welding.jpg
Name:  Top of Floor board started tacking_welding.jpg
Old 01-17-2017, 10:31 AM   #55
slydogg76
one more..
Name:  Top of Floor board more tacks ground down_welding.jpg
Old 01-17-2017, 12:52 PM   #56
Big Daddy Bear
Big Daddy Bear's Avatar
Those welds look like they are just fine!
Guess the final say will be if you put your feet in and you end up standing on the ground like a Flintstone mobile.
Will you have enough clearance in the front to not rub tire on the fender when turning?
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 01-17-2017, 01:22 PM   #57
slydogg76
Thanks!, appreciate it. I'm hoping to get better as I go, but I do like the Flintstone mobile.
Hopefully, clearance with the front tires won't be an issue. I think the front of the cab needs to go up some and I haven't purchased the new tires yet.
Old 01-17-2017, 01:36 PM   #58
Big Daddy Bear
Cool, hope they work out without having to do a bunch of changes.
What welder are you using? Are you using shielding gas or flux core wire?
Reason I ask is, I have a new project arriving this Thursday, and it has a couple spots that will need work and all I currently have is an Arc Welder, so using that as an excuse....errr...reason to get a new wire feed!
Thanks!!
Old 01-17-2017, 01:55 PM   #59
slydogg76
Thanks, me too!
I have a Lincoln Electric Pro-Core 100 w/flux wire (~12yrs old). Uses 110v.
My first welder, so I don't have anything to compare it with. Works great for me. Not sure how well it works for anything thicker than sheet metal.
Old 01-17-2017, 01:56 PM   #60
slydogg76
Its also a MIG welder.
Everyone needs a MIG welder
Old 01-17-2017, 02:12 PM   #61
Big Daddy Bear
Originally Posted by slydogg76 View Post
Thanks, me too!
Thank you for the info, appreciate it!!
That is exactly what I am needing it for, I have the stick welder for anything bigger than patching panels.
Old 01-17-2017, 02:14 PM   #62
Big Daddy Bear
I will pass that little fact onto my bride. I mean, afterall, it is on the internet so it has to be true...
Old 01-23-2017, 01:14 PM   #63
slydogg76
Made a lot of progress this weekend, even though it doesn't look it. Replaced a couple of pieces on the driver's side pillar, front of the rocker, also recut the inner cowl for butt welds and to line up with the outer cowl. Hopefully after some seam sealer, everything will look great.
Name:  Front cowl view.jpg
Name:  Side cowl view.jpg
Name:  Front Rocker replaced.jpg
Old 01-23-2017, 01:16 PM   #64
slydogg76
a few more...
pictures didn't take, will try again.
Old 01-23-2017, 01:20 PM   #65
slydogg76
A few more pics...
Name:  Front rocker and Inner Cowl pieces.jpg
Name:  Front Rocker piece replaced.jpg
Name:  Piece for front rocker.jpg
Old 01-28-2017, 10:04 AM   #66
slydogg76
Got the kick panel in place after much bending and cutting. Lining up the inner cowl with the emergency brake. I like the below bumper so the license plate can be center under the tailgate. What do you think?
Old 01-28-2017, 01:33 PM   #67
Big Daddy Bear
Looks like a good deal of progress to me. Puts you that much closer to being done than you were before you started, that can' be a bad thing!
Old 02-09-2017, 09:28 PM   #68
docrock
docrock's Avatar
Nice work! Subscribed. Keep up the great pics
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 12-16-2017, 12:43 AM   #69
Matt_50
I know it's been awhile, but I thought I'd check.
Any updates?
I've been watching for months lol. Anyone know what body this is? 3100? I'm surprised at how well it fit the c10 frame. Did I miss any major modifications or did he just make some cab mounts and there ya go?
1950 Build
Matt_50 is offline   Reply With Quote
Old 06-04-2018, 11:47 AM   #70
slydogg76
Haven't made any modifications to the frame or body (3100). I got rims with offsets to fit inside the fenders.
Old 06-04-2018, 01:42 PM   #71
Purcell69
Was the donor C-10 originally a big block truck? About 25 years ago, I swapped in a 454 in to the wife's 1978 Big 10 Chevy 1/2 ton, after the 350 dropped a valve seat. The factory front coil springs were not happy! At rest, the truck was almost on the bump stops. In the end, I swapped in a set of +2" Rancho coil springs to account for the extra weight of the big block and had no more issues with bottoming out.
It doesn't look like you're having that issue, but a different spring rate may be something in your future.
Keep up the good work!
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 06-07-2018, 08:22 PM   #72
slydogg76
The '77 C10 had a straight six, maybe it didn't cause much stress on the springs. Thanks, Dan
Old 06-24-2018, 08:12 PM   #73
slydogg76
Finally made some progress this weekend...
Old 06-24-2018, 08:26 PM   #74
Big Daddy Bear
Nice!
Old 06-28-2018, 10:45 PM   #75
slydogg76
Received a complete bolt kit today from totally stainless. Looks awesome!
advance design, big block, chevy 3100, frame swap, restomod
