Old 11-14-2013, 12:30 AM   #51
mmiddle
mmiddle's Avatar
Re: power window regulators on the cheap
well Crap! I should have read further down.
Also look at www.mouser.com/ They are in Mansfield, Tx They are a electronics components supply company
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-14-2013, 05:57 PM   #52
70STOVEBOLT
70STOVEBOLT's Avatar
Has anyone who did this mod tested them in the truck yet?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-14-2013, 06:17 PM   #53
bonnieclyde100
mine have been in my truck for almost a month and they work great better than the aftermaket kits that turn the hand crank shaft to raise and lower the window and it is closer to what stock would be
bonnieclyde100 is offline   Reply With Quote
Old 11-14-2013, 06:33 PM   #54
70STOVEBOLT
Does it matter what year the motor comes from? I see a bunch of different part numbers but they all look very similar. I know there are different numbers of teeth, looks like we need 9 tooth motors.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-14-2013, 11:36 PM   #55
bonnieclyde100
mine is one that is for 1991 chevy truck but there is probably many that will work
Old 11-15-2013, 12:32 PM   #56
70STOVEBOLT
bonnieclyde100 what type of switches did you use? I see colgad posted that a reversing switch is needed. I was planning on using the chrome gm style switches.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-15-2013, 04:40 PM   #57
bonnieclyde100
those should work they are a reversing switch i used switches that came from an aftermarket kit that i had.
Old 11-15-2013, 04:59 PM   #58
70STOVEBOLT
Ok, good. Thanks for the info and the write up on this.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-15-2013, 06:36 PM   #59
First c10
First c10's Avatar
I plan to do this same Modification. I was looking at these.
Think these will work?
http://www.summitracing.com/parts/el...-421/overview/
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 11-15-2013, 07:03 PM   #60
bonnieclyde100
yes they will work and i like the way those look
Old 11-15-2013, 07:15 PM   #61
First c10
First c10's Avatar
I went to the wrecking yard and found a 70 GMC I was going to get a set of window regulators but they wanted $50 each. so I ordered some goodmark repops at $26 to try. figured what the hell its just $52 and I dont have to take my truck apart until its time to install the power set up!
Question is $50 each expensive for regulators at a wrecking yard???
GO GO!!!
Old 11-15-2013, 11:36 PM   #62
short n wide 72
short n wide 72's Avatar
Great idea!
Thanks for sharing.
short n wide 72 is offline   Reply With Quote
Old 11-16-2013, 05:23 PM   #63
Bigdav160
Bigdav160's Avatar
Bringin' it back to the top for a heads up.
While looking a drawings in the service manual (pondering the rear window regulators in my Suburban) I just realized I welded my motor bracket and gear 180º in the wrong direction.
Don't use the pics in post #35 as a guide.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-17-2013, 05:10 PM   #64
motorcritter
motorcritter's Avatar
I'm going to work with my Dodge Dakota regulator/motor combos- I've got a set of F-body convertible regulator/motor units, too. Winter is coming and I'll have plenty of time to 'experiment'. The window crank/switch idea is also in the plans- that should be pretty easy, compared to gabbing in the regulators.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 11-17-2013, 09:28 PM   #65
Syndrome
You should contact a moderator and have them edit your post so no one gets caught up with bad ideas.
1970 GMC
Syndrome is offline   Reply With Quote
Old 11-20-2013, 02:58 AM   #66
68 TT
Still plays with trucks
68 TT's Avatar
Nice work.
The switches, wiring and relay from a 77-87 Square body truck would be easy to install for a correct look.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-21-2013, 11:03 AM   #67
jimcaf
jimcaf's Avatar
I just got these switches off EBAY,best deal Iv could find http://www.ebay.com/itm/TWO-UNIVERSA...81255183341%26
I havent got them installed yet making a bezel took a little time,they feel and look like real good quality pieces,also just ordered a pair of these http://www.jegs.com/i/Electric+Life/...0-099/10002/-1 ,so my wires dont get pinched going from the door to the cab.
Does anyone have photos where they drilled and ran there wires to transition from the doors into the cab??? thanks jim
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION
Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed
The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10
jimcaf is offline   Reply With Quote
Old 11-21-2013, 01:19 PM   #68
70STOVEBOLT
jimcaf, did you leave your motor plate the way it is in your pic, or did you have to trim it for clearance? The OP has a specific shape to his motor plate, I was going to just use a rectangular plate, unless there will be clearance issues.
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-21-2013, 01:52 PM   #69
jimcaf
jimcaf's Avatar
Thanks,
Mark
Mark,,,I did just leave it in a rectangular shape and had no issues, the only clearance issue I had that came close was a guide I fabricated to keep the big gear on the regulator in better alignment (not completely necessary) and that is not really a problem its just touching the side of the window guide on the vent assembly.
Old 11-21-2013, 02:31 PM   #70
70STOVEBOLT
jimcaf, would it be possible to see a pic of the other side of your regulators?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-21-2013, 03:09 PM   #71
jimcaf
jimcaf's Avatar
Mark,,I dont have a photo of it with the guide in place,Im hoping not to have to pull them back out Im in the process of installing new glass if I do Il post a picture with the guide I fabricated in place jim
Old 11-21-2013, 03:12 PM   #72
jimcaf
jimcaf's Avatar
go back to the top of page 2 ,I like how COLGAD did his guide
Old 11-21-2013, 05:39 PM   #73
70STOVEBOLT
Thanks for the pic, I just wanted to see if you had to clearance the plate for the motor. I don't have my motors yet, but I thought I could go ahead and make the plates ahead of time. I think the motors all have the same bolt pattern and placement of the gear. I like the guide idea too. Thanks again for taking the time to post the pics.
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-22-2013, 05:31 PM   #74
jimcaf
jimcaf's Avatar
Mark ,,you might want to make the plates and drill out the big hole and wait welding and on the last 3 till you could hold the motor in place and line up the gears..
Old 11-22-2013, 06:02 PM   #75
70STOVEBOLT
Jim, that was my intention. I don't have my motors yet so I can't drill the mounting holes.
What did you cut the big round hole with, a hole saw?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
