Old 11-29-2013, 10:55 PM   #51
MashTheGas 72
Re: 72 GMC Short Step Build
very nice build. I really like all the extras that your doing.
72 GMC 1/2 Ton
MashTheGas 72 is offline   Reply With Quote
Old 11-29-2013, 11:05 PM   #52
Z10
Z10's Avatar
Thanks Mash. From the minds of Car Boss and Double E, things are getting fun.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-01-2013, 09:53 PM   #53
Z10
Z10's Avatar
Custom Electrical Harnes
Double E did a test fit of the new custom electrical harness that he has been spending untold hours designing and fabricating. Simply outstanding work.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-01-2013, 10:06 PM   #54
Z10
Z10's Avatar
Cab Insulation and Noise Control
Well I spent Saturday and Sunday afternoon, finishing up the cab insulation project. First I put down a Dynamat type product, then came the aluminum backed closed cell insulation, then the MLV...Mass Load Vinyl. The MLV is heavy and doesn't like to bend where you need it. The carpet will go in hopefully next weekend.
Ran out of Dynamat so the doors will have to wait. Looks pretty clean, I think.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-01-2013, 10:11 PM   #55
MashTheGas 72
Hey Z10 where did you pick up your aluminum insulation mat.
72 GMC 1/2 Ton
Old 12-01-2013, 10:51 PM   #56
Z10
Z10's Avatar
Mash, I'll let Diceman chime in. He had it left over from another project. It's really nice stuff. Very easy to work with. The MLV......not so much.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-02-2013, 09:37 AM   #57
diceman50
www.lobucrod.com/
diceman50 is offline   Reply With Quote
Old 12-02-2013, 10:34 AM   #58
MashTheGas 72
Thanks diceman. I will be ordering a role.
72 GMC 1/2 Ton
Old 12-03-2013, 06:56 PM   #59
diceman50
Hey Z10,
You're going to have to turn loose of some of your Cialis brochures. We need water pump gaskets.
Old 12-03-2013, 10:14 PM   #60
Z10
Z10's Avatar
Hey!!!!!!!!!!!! Forget the gaskets! Who stole my heads???
Jump forward to post 81, to solve the mystery
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-03-2013, 11:23 PM   #61
swamp rat
swamp rat's Avatar
What purpose does the MLV accomplish besides not laying down very well? I never seen the stuff used here before so wondering if its insulation or sound property's?? Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-04-2013, 01:06 AM   #62
Z10
Z10's Avatar
Diceman, can you respond to this comment from "Airstream" from a TPI post I'm monitoring?
Quote:hey z10, I see you are building a surge tank. I was going to make a fuel injection cleaning tank that i was going to fill with cleaner fluid and pressurize it with air and feed it to injectors. My tank size and style was a lot like your surge tank. I discussed this with my brother ( a mechanical engineer) and he said "you must have domed ends, they look like bell ends. If not and the ends are sharp 90 degree transitions, these areas are stress risers, create flexing, and eventually crack". This would lead to pressurized fuel spray in a hot engine compartment with spark generators (coils, alternator, etc). My brother also said to look at any ASME (american society of mechanical engineers) tank and you will notice rounded ends. I work at a power plant with compressed air everywhere with surge tanks, etc, etc, and all holding tanks have rounded ends with an ASME id tag listing working pressure, burst pressure etc. I think the quality of your work looks great as i don't wont to rain on anyones parade, but when i switched careers from dealer mechanic to power plant work it was an eye opener. Keep up the good work, good luck Brian F.[/QUOTE]
Airstream, please go over to my build and copy and paste your comment.
My surge tank was created by diceman50, I'm sure he'll respond. The tank was actually created by utilizing two DOT calibration gas cylinders which were originally rated at 500psi. As far as the domed ends, I'll default to your brother. On second thought I'll copy and paste your comment, just monitor it for his reply.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-04-2013, 01:15 AM   #63
Z10
Z10's Avatar
Rat, the MLV is used as a sound barrier. Here's a link from the place I purchased it.
http://www.supersoundproofingsales.c...2D00005%2D48R/
And here's an article you might find interesting.http://www.supersoundproofingsales.c...2D00005%2D48R/
What I'm trying to accomplish is keep the heat out, the cool in, and reduce the amount of noise that enters the cab. The jury is still out as to how well this will work. I still haven't done anything with the doors and will need to do that after we get the truck back on it's feet.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-04-2013, 05:18 AM   #64
swamp rat
swamp rat's Avatar
Ok thanks for the product link, The link to the article you posted was the same as the product link so i couldn't read the article..
So i'm guessing this stuff may be better than just using 2 layers Dynomat first then the closed cell? Or possibly the way you layer it makes a difference? I'll be interested to read your thoughts on how well it performs, my truck is LOUD...
I was also wondering if you had a heat gun if it would help shape the MLV a little?
Then i had one thought, how thick are the 3 layers and will it affect the accelerator pedal movement enough to be a problem? Just thinking ahead.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-04-2013, 10:54 AM   #65
diceman50
My surge tank was created by diceman50, I'm sure he'll respond. The tank was actually created by utilizing two DOT calibration gas cylinders which were originally rated at 500psi. As far as the domed ends, I'll default to your brother. On second thought I'll copy and paste your comment, just monitor it for his reply.[/QUOTE]
Diceman here,
The gas sample canisters we used are rated at 500 PSI and although they are flat bottom on the outside they have a very large radius on the inside which in effect makes them domed on the inside. However, the point is mute since in our application there is ZERO pressure on the surge tank. We are using the mechanical pump on the engine to fill the surge tank with a return line to the main tank. The high pressure pump is inside the surge tank. It pumps fuel to the fuel rails after which excess fuel is returned to the pressure regulator which is mounted on the outside of the tank. Therefore no pressure is introduced to the tank. The pressure testing I did was for the fittings.
Old 12-04-2013, 03:17 PM   #66
Z10
Z10's Avatar
The three layers actually do different things. The dynamat reduces harmonic vibrations which can create sound. From what I've studied it is not necessary to completely cover a surface with the material, but somewhere between 25% to 50% coverage will get it done. The aluminized foam serves two purposes, stop heat transfer and stop noise. The mass load vinyl, also stops what I would call airborne noise such as exhaust, tire noise etc.
As for thickness, all 3 layers are less than 1/2 inch, probably closer to 3/8. If I find it's to thick around the gas pedal, I'll just cut it out.
I did try a heat gun, but the MLV didn't seem to want to hold it's shape when it cooled. The good news, is that if you trim it in smaller pieces, it stays put.
My mistake at first was trying to use two large pieces to cover the floor and firewall.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-04-2013, 03:30 PM   #67
swamp rat
swamp rat's Avatar
Ok thanks! You have a great build going!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-05-2013, 01:54 AM   #68
Z10
Z10's Avatar
[QUOTE=swamp rat;6401001]Ok thanks for the product link, The link to the article you posted was the same as the product link so i couldn't read the article..
Here's some more light reading on the subject.
http://www.sounddeadenershowdown.com/
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-06-2013, 09:26 PM   #69
Z10
Z10's Avatar
First Engine Test Fit
Had some fun today. The decision was made to test fit the engine and trans.
We found that the 700r4 trans and factory crossmember will match up to existing holes in the frame with out any need to drill holes. The engine stands were sorted out and bolted to existing holes, with the exception of the bottom stand holes, which we'll drill when we pull the engine back out. No interference between the firewall and distributor and the distributor will drop in. Looks like the drive shaft will need to be shortened about 3 inches. No clearance problems with the Sanderson CC11 headers.
All in all a very good day. So, here's a few pics. You'll notice the engine still has the stock ZZ4 carb manifold. The TPI set up will go on later.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-07-2013, 08:52 PM   #70
Z10
Z10's Avatar
Just a little Jewelry
Got a few things done this afternoon. Car Boss is working on the fuel lines for the FIRST TPI, we got the trans cross member bolted down, and we had a little fun adding some "Jewelry" to the fender, a little preview of things to come.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-09-2013, 08:45 PM   #71
Z10
Z10's Avatar
Fuel Pressure Gauge Port Installation:
Time to install a port in the fuel rail.....Car Boss to the rescue.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-09-2013, 09:15 PM   #72
67chevy1
67chevy1's Avatar
Your doing a great job keep it up.
67chevy1 is offline   Reply With Quote
Old 12-09-2013, 09:21 PM   #73
Z10
Z10's Avatar
Thanks 67, the team appreciates it.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-09-2013, 09:25 PM   #74
Z10
Z10's Avatar
Stainless steel fuel line install on TPI manifold:
Car Boss seems to always be busy.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-09-2013, 09:32 PM   #75
Beetle
Beetle's Avatar
I can only hope my 70 GMC short fleet looks this nice one day! I am keepin my six though
Good lookin work by you the car boss and EE
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
