Old 11-25-2013, 11:28 PM   #51
skymangs
skymangs's Avatar
Re: 49 ls1
here's the obligatory "rats nest" shots
I'll be back on Sunday for more work!
Happy Thanksgiving All!
skymangs is offline   Reply With Quote
Old 11-26-2013, 12:27 AM   #52
oldman3
oldman3's Avatar
Re: 49 ls1
Happy Thanksgiving to you also Chris...Jim
oldman3 is offline   Reply With Quote
Old 12-02-2013, 07:00 PM   #53
vht
Re: 49 ls1
Question on your eng placement, why did you move it back so far? I'm thinking about going this route with my 51 and was just curious. Can't really tell, but it looks like valve cover is back in the firewall a ways. I'll be watching your build, going to be a nice 1.
vht is offline   Reply With Quote
Old 12-02-2013, 09:19 PM   #54
skymangs
skymangs's Avatar
Re: 49 ls1
Right valve cover is about 1" into the firewall, left is flush. I placed it back there to maximize clearance for the electric fan setup.
I am using the truck accessories, so right now I have 5.5" between the wp pulley and the rad. If you used F-body accessories, you could gain that two inches without recessing the firewall. I just had a hankerin' to cut some steel and make it my way on this one. Besides, doesn't it look tough all notched into the firewall? LoL
Old 12-02-2013, 11:06 PM   #55
99 to Life
99 to Life's Avatar
Re: 49 ls1
don't know I missed this, man I hope they don't have a subscription limit on here. I'm liking the direction your going with this. Hey if you haven't tossed that OG dash PM me. Wish I woulda caught that break a while back. I got about 50 hours in a dash right now for my 49' I'm doing. Its def amazing how much LS engines are coming down. I think finally alot of those earlier bodies are just being done away with, its flooding the market pretty good. Nice truck and nice work.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-03-2013, 12:12 AM   #56
torchlight
torchlight's Avatar
Re: 49 ls1
Yeah I think it looks really nice the way it is notched into the firewall. You know that the further back the engine is, the better handling characteristics your truck will have! (theoretically) It is also nice that you have enough clearance now between your pulleys and the radiator. I've got an LS in my 53 but didn't do a firewall notch or tunnel like you did. So, I had to swap out and use the CTS-V front drive accessories to get enough clearance for my electric fan to go on the radiator.
torchlight is offline   Reply With Quote
Old 12-03-2013, 09:09 AM   #57
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks 99, unfortunately the 49 dash provided repair panels (around the radio) for one of my customers trucks. not a whole lot left of it now.
I happened across a complete uncut 2002 Tahoe in the pick-n-pull a couple weeks ago. compete un-cut harness, even had the ducting and air filter housing on it still. Unfortunately It was tit's cold and raining with a 30 min window before they closed. Took coil packs, throttle body, and some little stuff. Felt bad leaving such an opportunity.
Torchlight, I build rock-crawlers too. We always try to stretch the front axle forward a few inches, or place the motor farther back for center of gravity and roll center. Weight distribution is everything. That being said, I don't see this truck on the slalom course any time soon.
Old 12-03-2013, 08:52 PM   #58
vht
Re: 49 ls1
Eng looked back farther in the pic, and I can understand more room. The farther back the better it will handle and hook up. That's a old drag racing trick. They used to say the front spark plug needs to be even with the spindle. Real good build, I'll be watching.
Old 12-04-2013, 12:36 PM   #59
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks vht.
Got the PCM wiring finished up. Started drilling spot welds in the inner kick panels... Sucks. She's got some pretty good rot around the lower kick panels, but I think I can save her. Will be doing inner/outer kick panels and braces. probably some small patches in the toe board, lower hinge pocket on the R side, and inner/outer cab corners. There's also some rust on the upper A piller (drivers side) to adress.
Pics this evening.
Old 12-09-2013, 06:25 PM   #60
skymangs
skymangs's Avatar
Re: 49 ls1
Well, rust repair... Lotsa pics, nothing too impressive. Need to go to the city for patch panels from Classic...
Old 12-09-2013, 06:30 PM   #61
skymangs
skymangs's Avatar
Re: 49 ls1
Looks like I'm going to need pass floor, lower kick panels (both sides) outer cowl panel (L) and lower outer cowl panel (R).
Old 12-09-2013, 06:34 PM   #62
skymangs
skymangs's Avatar
Re: 49 ls1
The more I work on it... the more rust I find... looks like I need the lower hinge area on the pass side as well.
Old 12-09-2013, 06:38 PM   #63
skymangs
skymangs's Avatar
Re: 49 ls1
Last two...
Old 12-09-2013, 07:48 PM   #64
oldman3
oldman3's Avatar
Re: 49 ls1
Hey Chris, nice repair work. Is the date on your camera off 4 months, cause down this way we got freezing rain, sleet, and about 10" of snow. Was finally able to get out of my driveway on Sunday. My driveway (gravel) is about 200' long. Anyhow, nice job...Jim
Old 12-09-2013, 08:27 PM   #65
99 to Life
99 to Life's Avatar
Re: 49 ls1
diggin it, luv seein patch work
Old 12-09-2013, 08:36 PM   #66
TheBlueBomber
TheBlueBomber's Avatar
Re: 49 ls1
That looks great.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 12-09-2013, 09:02 PM   #67
2 Pop
Re: 49 ls1
I've done the same dash but I just squared the ends and made a fill plate. I didn't do anything on the doors like you did but I'm wishing that I did after seeing yours. Nice Work!!!
2 Pop is offline   Reply With Quote
Old 12-10-2013, 12:57 PM   #68
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks all. I think my patchwork looks kinda ghetto fab, but it works. Jim, the date is really off 4 months. We had a little snow, and it's been cold as a well diggers ass here. That's why I've been kinda slow on the work.
2_Pop, I started out intending to square the ends... but I get some crazy ideas every now and again. Thanks.
Old 12-12-2013, 11:12 AM   #69
solidaxel
solidaxel's Avatar
Re: 49 ls1
Thanks for the tip on the shorter front drive units.
I may have to change the truck set up for clearance.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-12-2013, 01:48 PM   #70
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 49 ls1
skymangs,
I really enjoyed going through your build thread. Nice work man nice work.
Kabwe is offline   Reply With Quote
Old 12-14-2013, 11:53 PM   #71
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks Solidaxel and Kabwe...
Picked up a huge stack of patch panels from Classic last week. and scored another 5.3L 101K motor for 3 bills... can't walk past that! It came sans harness and PCM, but I think I'm gonna experiment with that MSD LS ignition controller and a carb on the next go round. Just for grins.
Old 12-15-2013, 08:44 AM   #72
ghettoluxury
ghettoluxury's Avatar
Re: 49 ls1
You will love it. The Edelbrock kit from Summit is easier than a Small Block, and peps up a 6.0/5.3 with just a 600 CFM carb.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-15-2013, 10:39 AM   #73
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49 ls1
Amazing work on the rust repair. Cant wait to see more.
--Josh
Old 12-15-2013, 06:39 PM   #74
vht
Re: 49 ls1
Keep it coming, this is a great build. I got a 2000 6.0 for mine, think I'll go carb with a 6010 MSD.
Old 12-15-2013, 07:41 PM   #75
skymangs
skymangs's Avatar
Re: 49 ls1
spent the day cutting out more rust. Kept finding more, my cab to floor brace looks like swiss cheese. guess I'll be heading back to the city to pick both up. Lot more rust under here than I had hoped for. I wound up welding bracing in to keep the door opening square, once I realized just how much needed to be cut out.
I started another thread, but does anyone have an exploded view of what that under floor sheet metal should look like? I think the rocker should extend forward past the door opening, and tie into the inner/outer cowl brace, but there was nothing there to use as a template, and none of the repro sites show a good pic of the rocker panel.
