Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-15-2014, 11:29 PM   #51
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Dream '69
Looking good!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 10-03-2014, 06:06 PM   #52
tune_1
Re: Dream '69
Looks like a good start. Like the look of the 4x4 SWB. Any more progress?
Dwight
tune_1 is offline   Reply With Quote
Old 10-05-2014, 10:57 PM   #53
lawest
Re: Dream '69
Haven't worked on it much this summer, just too hot out in the shop. I have been getting all the fittings together for my fuel lines, and I have my tank permanently mounted up now. Next step is getting the bumper on and fabbing up the fuel filler behind the plate. Need to start working on it more but its huntin' season now.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 07-22-2015, 04:29 PM   #54
lawest
Re: Dream '69
Truck cab is going to paint in just a few days, I will post some pics soon. Work is continuing on the chassis, but its all small detail stuff that doesn't really show up good in a picture. Plumbing the underbed tank and the rest of the fuel system. Will be starting on installing the Heartthrob exhaust soon. That should be interesting.
Old 08-30-2015, 09:44 PM   #55
lawest
Re: Dream '69
The Old Air compressor on along with the alternator using the supplied brackets.
Falcon tank installed.
Old 08-30-2015, 09:53 PM   #56
lawest
Re: Dream '69
My Carter elec. fuel pump
These are to show how tight the tank fits to the leaf spring hangers. If you have a shortbed with leaf springs this is a good under bed tank install.
Old 08-30-2015, 10:02 PM   #57
lawest
Re: Dream '69
This shows how the tank looks from the back. Camera is about the same height as the bumper.
Old 08-30-2015, 10:06 PM   #58
lawest
Re: Dream '69
I have an issue with the exhaust on the passenger side. I am going to have to take the intermediate pipe down the exhaust shop and have a joggle put into it get up and over the T-case cross member.
Old 09-18-2015, 11:05 PM   #59
lawest
Re: Dream '69
New rockers
Name:  New rocker.jpg
New cab corner
Name:  Truck cab corner.jpg
Headed to the paint shop
Name:  cab on trailer.jpg
In the paint booth
It's Red!
Old 09-19-2015, 09:52 PM   #60
86454k30
86454k30's Avatar
Re: Dream '69
looks great! Nice work.
86454k30 is offline   Reply With Quote
Old 09-20-2015, 12:17 AM   #61
lawest
Re: Dream '69
Here's the bottom. It is tinted bedliner.
cab corner speaker mounting plates installed. http://67-72chevytrucks.com/vboard/s...6&goto=newpost
Old 10-31-2015, 08:21 PM   #62
lawest
Re: Dream '69
Got the cab back on the frame today and installed the core support, radiator and shroud. Ordered a flexible stainless radiator hose kit and once I get that installed I can run the engine.
Old 10-31-2015, 09:30 PM   #63
ryanroo
ryanroo's Avatar
Re: Dream '69
looks great!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-31-2015, 10:43 PM   #64
brimc
brimc's Avatar
Re: Dream '69
Digging the red. Cab and frame look awesome together.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 11-01-2015, 08:55 AM   #65
RANDY COX
RANDY COX's Avatar
Re: Dream '69
Wow looking good like the red and 4x4.. awesome truck..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-01-2015, 12:13 PM   #66
bajabob
bajabob's Avatar
Re: Dream '69
Sweet build stay on it !!!
bajabob is offline   Reply With Quote
Old 01-24-2016, 11:13 PM   #67
lawest
Re: Dream '69
Cooling system and belts are done as well as the a/c unit. Working on wiring now.
Old 01-26-2016, 10:21 PM   #68
lawest
Re: Dream '69
Started cutting the dash for the ac vents. As you can see, I failed to do this before the cab was painted, so I have been dreading this step. I used the template that was supplied with the Old Aire kit and marked the cut out. I then drilled all around the perimeter with a 1/2 inch drill bit. Then I used a nibbling tool to remove the remaining metal right up to the mark. Finally, I smoothed the edge with a file.
Old 02-22-2016, 10:47 PM   #69
lawest
Re: Dream '69
Vintage Vibes USA 630 II installed, now just stringing wires. Will be cutting the holes for the speakers soon.
Old 02-23-2016, 11:38 AM   #70
First c10
First c10's Avatar
Re: Dream '69
Can I ask what AC unit you went with? and why? I am debating on vintage air or old air.
build looks good!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-07-2016, 05:25 PM   #71
lawest
Re: Dream '69
build looks good!
I went with the Old Aire kit. It seemed to have mor options for using factory style controller, vents, etc. but I think the Vintage unit is good too and the cost is about the same.
Old 03-07-2016, 05:46 PM   #72
First c10
First c10's Avatar
Re: Dream '69
Looking good. Thanks for the info as i felt the same way. I ordered my old air kit and started to mock up the mounting plates on the inside without the outside black plate.
GO GO!!!
Old 03-07-2016, 08:22 PM   #73
72MARIO
72MARIO's Avatar
Re: Dream '69
Nice build
While your under the dash with the ac install you might want to consider adding a ac override switch to turn the compressor on with the heat function. I find the kit in our suburban is not able to defog the inside with out the ac on and in fall spring temperature I need heat not ac !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-07-2016, 09:25 PM   #74
First c10
First c10's Avatar
Re: Dream '69
Quick question.
If you set to defrost with and the temp control to warm or hot air the compressor does not come on??
GO GO!!!
Old 03-08-2016, 01:58 PM   #75
lawest
Re: Dream '69
Quick question.
Right, the comp only operates when you select cold air on the temp control unless you add an override switch as 72Mario recommends. With the a/c running the air will be drier which makes the defroster work better.
