Old 10-13-2014, 12:20 PM   #51
1970C20L9H
Re: 1970 c20 l9h 6l90e
Originally Posted by bigmone View Post
The O ring gaskets actually cross over to Pontiac G8 and a few other cars like the Acadia but not a 2010 Camaro.. The studs are in the help section of most part stores
Thanks, I will check that out. Studs at GM Parts direct are about $8 each, seems like a bit much.
1970C20L9H is offline   Reply With Quote
Old 10-20-2014, 02:18 PM   #52
1970C20L9H
I have decided to use an in-tank pump with the factory tank behind the seat. I am going to do something similar to what Phill has done in the following thread, post 21
http://67-72chevytrucks.com/vboard/s...5&postcount=21
It is a Tanks Inc. TBA-4 fuel pump assembly which has been modified for the 67-72 behind the seat tank.
I have read too many stories of loud pumps or pump failure on inline pumps vs in tank pumps that I decided I am not going to cut corners to make it easier or save a buck because it sounds like it's not worth it in the long run and the only reason I wanted to do inline was to preserve the behind the seat tank and I don't think I would have saved a buck with an inline pump anyways.
Old 10-30-2014, 07:07 PM   #53
1970C20L9H
If anyone else is planning on using the Tanks Inc TBA-4 fuel pump, don't forget the mounting plate and gasket which is sold separately.
Tanks Inc Part Number: 3TR - Threaded Mounting Ring 6 Hole 3-1/4" Diameter
Tanks Inc Part Number: 3G - 6 Hole Cork Gasket 3-1/4" Diameter
OR
Tanks Inc Part Number: 3G-N - 6 Hole Neoprene Gasket 3-1/4" diameter
I am guessing the mounting plate does not come with mounting hardware and I will have to buy that from the hardware store.
Old 03-11-2015, 01:55 PM   #54
HOTRODSBYCHIP
Any updates?
HOTRODSBYCHIP is offline   Reply With Quote
6l90e, c20, l92, l9h, swap
