Old 06-07-2014, 03:15 PM   #51
jdoisher
jdoisher's Avatar
Re: Jason's Bagged Farm Truck
Originally Posted by bab59 View Post
What is your measurement from the top of stock frame to bottom of notch?
Its 4" above the stock frame.
Jason
http://67-72chevytrucks.com/vboard/s...d.php?t=531177
Maggie's truck!
jdoisher is offline   Reply With Quote
Old 06-07-2014, 09:07 PM   #52
Lowl!f3
Lowl!f3's Avatar
Hey man, your suposed to be with the wife.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 06-08-2014, 05:06 PM   #53
creep
Registered Loser
creep's Avatar
Nice! Another quality build to follow
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-08-2014, 08:58 PM   #54
jdoisher
jdoisher's Avatar
I took some 2x3 and had them drilled so I could make some lowering blocks. I pie cut them to put pinion angle back into the rear.
Name:  65 C10 033.jpg
Name:  65 C10 034.jpg
Name:  65 C10 036.jpg
Than got started on lowering the body mounts 5/8 of a inch. Why? that is the amount of spacer I have on her bed, buy lowering the cab that amount I won't need the spacers!! I was able the drill the holes lower, super easy.
Name:  65 C10 037.jpg
Here are the front cab mounts, I lendthen them.
Name:  65 C10 040.jpg
Maggie's truck!
Old 06-08-2014, 09:02 PM   #55
jdoisher
jdoisher's Avatar
Welded up.
Name:  65 C10 041.jpg
To do the core support mount I lowered the front frame section so the drop included the bumper too!!
Name:  65 C10 044.jpg
Name:  65 C10 046.jpg
Thanks Jason
Maggie's truck!
Old 06-08-2014, 09:18 PM   #56
Bhelton
Bhelton's Avatar
Looking good, you and wife honeymooning in shop?
Bhelton is offline   Reply With Quote
Old 06-08-2014, 09:21 PM   #57
hopped up
hopped up's Avatar
Awesome as always, a lot of work for a minimal amount of drop. But it's soo worth it. How much angle you put in those lowering blocks?
hopped up is offline   Reply With Quote
Old 06-08-2014, 09:34 PM   #58
jdoisher
jdoisher's Avatar
lol, I know you know whats up, you follow me on instagram!!!
Maggie's truck!
Old 06-08-2014, 09:37 PM   #59
jdoisher
jdoisher's Avatar
Kind off!!
I took out a 1/2" wedge on the block. It was 5 or 6 degrees on her truck.
Jason
Maggie's truck!
Old 06-08-2014, 09:45 PM   #60
Bhelton
Bhelton's Avatar
Lol, yeah man. It's mutual...profile pic look familiar?
Congrats again bro!
Old 06-08-2014, 09:49 PM   #61
jdoisher
jdoisher's Avatar
Congrats again bro!
Yes!! and Thanks!!!!
Maggie's truck!
Old 06-08-2014, 10:44 PM   #62
Bigd426
whats the bag of concret for on the frame? holding down flat?
Bigd426 is offline   Reply With Quote
Old 06-09-2014, 12:01 AM   #63
jdoisher
jdoisher's Avatar
yes, I needed weight on it to keep it level!! Whatever it takes! lol
Maggie's truck!
Old 06-09-2014, 06:37 PM   #64
Dinos63
chevy only
Dinos63's Avatar
very cool!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-09-2014, 07:28 PM   #65
Painter D
Painter D's Avatar
The more I look at this the more I dig it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 06-09-2014, 08:31 PM   #66
Bomp
Bomp's Avatar
Thats tha way ta do it.
Stop, look, wonder whats different, know theres something but well,,,, I Dig It!
Bomp is offline   Reply With Quote
Old 06-10-2014, 01:37 AM   #67
Lowl!f3
Lowl!f3's Avatar
Way to go Jason. You giving a couple more ideas for mine. But first!!! I got to tackle the pancake..... now what kind of syrup should I use
1965 C10 Project
Old 06-11-2014, 08:10 PM   #68
jdoisher
jdoisher's Avatar
Speacking of Pancakes.
Name:  65 C10 039.jpg
Name:  65 C10 042.jpg
Name:  65 C10 043.jpg
Jason
Maggie's truck!
Old 06-11-2014, 10:04 PM   #69
creep
Registered Loser
creep's Avatar
You make it look easy! Luckily for guys like me there are bolt-in solutions.
Old 06-11-2014, 10:13 PM   #70
Bigd426
most of the fun in this stuff! I see you are in Denton, not for from you down here in Plano. Already making me feel behind on mine!
When you pan cake the cross memeber does the motor or motor mount move at all?
Old 06-12-2014, 08:49 AM   #71
jdoisher
jdoisher's Avatar
As far as feeling behind, I know the feeling!!
No, it stays in the same place!!!
Maggie's truck!
Old 06-12-2014, 10:41 AM   #72
JakeDW
JakeDW's Avatar
Glad to see you are doing another one.Even more cool to see you got out the grinder plasma cutter and welder to do it.
Jake
JakeDW is offline   Reply With Quote
Old 06-20-2014, 08:36 PM   #73
jdoisher
jdoisher's Avatar
So I saved all my patterns from when I did Maggies truck, and started on the rear bag mounts. On her truck the bag is off set on the control arm, no biggie other than the control arm is twisted when the truck is aired up. I wanted to see if I could center it on the control arm. I was able to by not having the bag mounts square to the frame and using just the lower outter two holes.
Name:  65 C10 050.jpg
You can see that I'll have to notch the frame in order to have bag clearnce. Its hard to tell but the bag bolts are not parallel to the frame. The upper mark is nothing.
Name:  65 C10 051.jpg
Lower bag plate welded on and the inner frame support welded in. (its not parallel to the frame either) Its at a angle.
Name:  65 C10 052.jpg
Upper bag mount done!
Name:  65 C10 054.jpg
Maggie's truck!
Old 06-20-2014, 09:14 PM   #74
jdoisher
jdoisher's Avatar
The rest of the pics!
Name:  65 C10 053.jpg
This is how I set up bag heigth (3") and lined up the upper and lower bolt holes.
Name:  65 C10 055.jpg
Done.
Name:  65 C10 056.jpg
Name:  65 C10 057.jpg
I'm at a stand still, waiting on parts. Just got my rear wheels in so I could order my axles, and I have some other parts on order too, Porterbuilt control arms, pan hard rod kit, disc brake kit and dropped spindles.
Stay tuned!!
Jason
Maggie's truck!
Old 06-20-2014, 09:58 PM   #75
Tennypicou1
Tennypicou1's Avatar
Nice work man
Tennypicou1 is offline   Reply With Quote
