Old 02-15-2016, 10:50 AM   #51
CustomCab66
CustomCab66's Avatar
Re: 1966 C1434 SWB Custom Cab
Captainfab,
Thanks I thought they looked the same. But for some reason the listing on the lower ball joints shows the press in diameter of the lower ball joints are a little different between 66 and 71. i have a little more clean up to do anyway. ill bust out the dial calipers just to confirm. I do need to change the lower driver side one because it lost a battle with a curb at one point and is twisted up at the front bushing. i know is most likely cosmetic still seems to function as intended. i hope i can get the lower BJ's out without a press. Ill try using my 6" vise
CustomCab66 is offline   Reply With Quote
Old 02-20-2016, 08:50 PM   #52
CustomCab66
The ball joints were a breeze. now i'm just waiting on the caliper rebuild kits and the tie rod sleeves from performance online...
Old 02-21-2016, 07:53 AM   #53
northern 85
northern 85's Avatar
Looking good!!!
northern 85 is offline   Reply With Quote
Old 02-22-2016, 08:41 PM   #54
CustomCab66
Now i can check the calipers of the list of things to do. also the brake lines need to be bled out. Now its back on all fours but the tie rod adjusting sleeves from performanceonline havent made it yet. I called and they said that they are scheduled for delivery tomorrow...
Old 02-22-2016, 08:46 PM   #55
CustomCab66
Here's the adjusting sleeves that performanceonline.com make for this disc brake conversion.
Old 02-25-2016, 09:29 PM   #56
CustomCab66
So here's the adjusting sleeve from performance online.com. I couldn't get the picture to turn on my phone
Old 02-28-2016, 11:23 AM   #57
CustomCab66
Added a proportioning valve from an 84 3/4 ton that had disc brakes. Should be just what I need. Running brake lines is not my specialty so after 12 feet of 1/4" line and 20 grey hairs later I managed to separate the front braking system from the rear. The original brake lines are in great shape so I just extended the line that feeds the rear brakes on the passenger frame rail to the proportioning valve on the drivers side.
Old 03-09-2016, 10:22 AM   #58
CustomCab66
Booster installed and brakes bled out once again. Stops pretty good considering
that I have only 14hg vaccuum.
Old 04-10-2016, 07:12 AM   #59
northern 85
Looking good! Any updates??
Old 11-12-2016, 04:14 AM   #60
CustomCab66
New wheels
What better way to show off my disc brakes than with a pair of American Eagle 111's that I scored off of eBay. They are 15x8 with 3 3/4 inch back spacing and they fit perfectly.
This weekend I will be taking some photos of my axle conversion using Early Classic Industries 5 lug axle kit
Old 11-12-2016, 09:54 AM   #61
northern 85
Nice!!!!
Old 11-12-2016, 03:35 PM   #62
CustomCab66
Axle kit
Christmas came early this year with thisEarly Classic Enterprises 5 lug axle kit complete with bearings, seals, and a differential cover gasket. I also purchased to new Rabestos brake drums for the rear to finish things off. To be continued!!
Old 11-12-2016, 03:54 PM   #63
MOONLIGHT CUSTOMS
Love this truck!
63 Shop Truck Build...Sorta
http://67-72chevytrucks.com/vboard/s...d.php?t=722311
MOONLIGHT CUSTOMS is offline   Reply With Quote
Old 11-12-2016, 04:47 PM   #64
CustomCab66
Smile Re: 1966 C1434 SWB Custom Cab
Out with the old axles and bearings. I had to hire my son as a helper so he cleaned out the tube.
Old 11-12-2016, 05:32 PM   #65
CustomCab66
My helpers salary will be Oreo's and gummies bears. The new bearings, seals, and axles are in place
Old 11-12-2016, 05:35 PM   #66
CustomCab66
Sorry guys my phone will only let me use one image at a time. Now the brakes are adjusted and drums installed. Hopefully three Jugs of lube is enough to fill it back up. The original gears are also in fine shape.
At this stage in the game it has only taken me two hours to get this far. I'll be driving it later on this afternoon
Old 11-15-2016, 06:59 AM   #67
northern 85
Saaaaweeet! You gotta luv buying parts that fit with no mods!!!!
Old 11-15-2016, 07:45 AM   #68
CustomCab66
Heater Core restoration
So my heater core died in me about a week ago. The new one will be in today sometime. In the meantime I have cleaned and painted the heater box with satin black paint.
The damper door inside the box used to have some type of black rubber foam glued to it seal the hot air duct while slowing cool air to flow. Any suggestions on what I should use to replace the original foam
Old 11-15-2016, 01:15 PM   #69
VictoriaHardware
VictoriaHardware's Avatar
PM me your address and I'll send you the right stuff. I bought a whole roll from McMaster-Carr and have plenty left over.
VictoriaHardware is offline   Reply With Quote
Old 11-16-2016, 07:40 PM   #70
CustomCab66
Here are all the heater box parts cleaned up ready for assembly. Turn the clock back one detail at a time.
Old 11-16-2016, 07:42 PM   #71
CustomCab66
More images
Old 11-16-2016, 07:43 PM   #72
CustomCab66
Last of em
Old 11-21-2016, 07:55 PM   #73
CustomCab66
Working out the kinks, the heater blows blistering hot now. The damper has a new gasket so it gets TO hot in full recirculating mode. ����
Thanks to Nick with Aspen Auto who sent me a heater core strap and the input and experience from others that made it such a smooth repair.
Old 02-23-2017, 03:54 PM   #74
CustomCab66
Just an update now. Now I have the wheels for the back have to say looks pretty sharp. In these photos the front wheels are two piece and the rear are one piece. The two piece look wider so I put em in the back.
Old 02-23-2017, 03:55 PM   #75
CustomCab66
Round two
