Old 11-15-2014, 10:45 AM   #51
geezer#99
geezer#99's Avatar
Re: Urgent, need opinions on my new crate engine
I think you're going in the wrong direction with your motor choice 1972Blue.
You were worried about your choice of the 290 hp motor and now you're jumping deeper into the fire with even more motor.
You've got a big tall tire heavy truck that needs all the torque you can find. Buying more hp moves the hp/torque curve way up the ladder. Right out of your desired driving area.
It'll be a dog until it hits 3000 rpm.
You need a stock motor with some upgrades. Like this one.
http://www.summitracing.com/int/sear...g&autoview=SKU
Add a high flow performer intake, a small 600 cfm carb, a set of small tube (1 5/8") headers and you'll be far happier.
You'll set the tune on your motor and only need to look at it to check the oil.
The high horse motor will need constant attention. You'll be continuously tweaking the carb, checking the timing etc.
Forget the bling bling high horse motors, go stock.
Unless you enjoy tinkering all the time!
Old 11-15-2014, 11:10 AM   #52
1972BlueC20
1972BlueC20's Avatar
So I'll be happier with a 195 hp 350 tq engine over a 330 hp 380 tq engine?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 11-15-2014, 11:21 AM   #53
geezer#99
geezer#99's Avatar
Maybe!!
Do you do your own wrenching or get a mechanic to do it?
Do you do your own timing or carb adjustments?
Do you normally drive above 3000 rpm?
Old 11-15-2014, 11:23 AM   #54
Lattimer
Lattimer's Avatar
Originally Posted by 1972BlueC20 View Post
Ok cool.
What's the temperature valve for?
Should I have one of these?
Thats what controls hot/cold on your heater. You should have one in the heater return hose
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-15-2014, 11:27 AM   #55
1972BlueC20
Originally Posted by geezer#99 View Post
Maybe!!
I'm having a mechanic install everything and get it all dialed in, but I do work on my truck. I can do most medium level jobs. My problem is lack of certain tools and space. I have more $$$ than time at this point in my life.
As for my driving, I drive pretty aggressive. Not drag racing from light to light, but pretty aggressive. Or I'll just cruise normally and I don't care about power till I floor it. Lol
I never haul or tow anything.
Old 11-15-2014, 11:31 AM   #56
Lattimer
Lattimer's Avatar
Actually, the vortec head engines make begin making torque pretty low, and have a broad flat curve if done correctly.
Stock is NEVER a good answer to anything.....LOL
Shawn
Old 11-15-2014, 11:39 AM   #57
1972BlueC20
That's what my mechanic said. I asked him about just buying the cheap engine and he said why go through all this $$$ and trouble just to get a stock engine.
Keep in mind, he doesn't make any more money on the install regardless of whether I buy the vortec engine or the base engine.
Old 11-15-2014, 11:47 AM   #58
turp mcspray
turp mcspray's Avatar
The 290hp engine is just a mismatched mess!
At 2500 rpm, the 290hp engine has about 280lbs of torque, and the 330hp engine has about 350lbs. 70 lbs is a LOT, and you WILL notice it!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-15-2014, 11:52 AM   #59
1972BlueC20
That's what I figured.
Old 11-15-2014, 04:30 PM   #60
mechanicalman
Definitely a better engine, 1 piece rear main is a vast improvement. It will require a different flywheel and balancer than the other engine. Also different manifold. Very similar to what I am running. I just have the vortec heads with the bigger valves.
It's called an "external" balanced engine because it's a 1pc rear main seal, so a 2pc rear main seal crankshaft has a balance weight hanging off the end and they removed that to facilitate using a 1pc seal thus a counter-weighted flywheel.
The front of the engine is not affected and takes a regular balancer.
Production Vortec 350's (L31's) take a shorter balancer due to crank sensor, those are the ones with plastic timing covers and reluctor wheel between the lower timing gear and the balancer.
mechanicalman is offline   Reply With Quote
Old 11-15-2014, 04:36 PM   #61
Lattimer
Lattimer's Avatar
Whoops! Misspoke on the balancer. Thanks for the correction.
Shawn
Old 11-15-2014, 05:33 PM   #62
mechanicalman
So this one should be a good noticeable improvement power wise over my stock engine and will be ok for the my larger GVWR of 6700-7500 ?
What balancer would it take and what flywheel? I think I know but you guys are always better at this stuff than me at this point in my knowledge level
You are going to LOVE this engine, I have one in one of my pickups. Great choice for an engine, and yes very noticeable power improvement over your stock engine.
You don't need a special balancer, but I would get a new one. I think you already got this one, right? Perfect.
http://www.summitracing.com/parts/su.../applications/
It will fit. Just make sure you use the correct indicator
http://www.summitracing.com/parts/su...make/chevrolet
You do need a special flywheel AND flywheel bolts to fit that engine. It's NOT the same as a 383 or 400, it's the same flywheel that chevy has used since they started 1pc rear main seals starting in 86. Again, there is a 153 and 168 tooth I'd get whatever one matches the starter you already got. The difference is the 153 will crank your engine faster, but not harder. The 168 will crank your engine harder, but slower.
This one will do you for a 168 tooth slow cranker
http://www.summitracing.com/parts/pi...make/chevrolet
This one will do you for a 153 tooth fast cranker
Flexplate bolts
http://www.summitracing.com/parts/nal-14088764
You know you need a new Vortec style intake, right? You have an Edelbrock square bore AFB style carb, right?
The Best, $250.00
http://www.summitracing.com/parts/ed...make/chevrolet
Cheaper
http://www.ebay.com/itm/SBC-SMALL-BL...26b88c&vxp=mtr
Intake gaskets, get these they fit, do not split, last a long time.
http://www.summitracing.com/parts/na.../applications/
And, of course, special intake manifold bolts, sold individually, you will need 8.
http://www.summitracing.com/parts/na...0027/overview/
Old 11-15-2014, 05:48 PM   #63
RUN GMC
RUN GMC's Avatar
Originally Posted by Lee H View Post
Just for reference, My 72 C10, short fleet, 350/350, PS, PB, AC, spare, half tank of gas came in at 3,710 on a fresh fame off restoration. My 65 Corvette roadster came in at 3,146. Couple of fat chicks difference.
Nope he just likes them really really fat..................
RUN GMC is offline   Reply With Quote
Old 11-15-2014, 05:50 PM   #64
mechanicalman
X2!
Old 11-16-2014, 01:19 AM   #65
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Originally Posted by litew8 View Post
You can't go wrong with more HP. .
Except when lowend torque has been compromised for more high end horsepower.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-16-2014, 02:34 PM   #66
1972BlueC20
I don't have any kind of heater temp valve. The lines are just straight from intake to core, and from core to waterpump.
Old 11-16-2014, 02:38 PM   #67
1972BlueC20
Thanks guys for all your input!
I think I'm going to send a lot of my parts back along with the 290 hp engine since they are paying for all the return shipping.
I'm going to just get this complete package. It's more of a turn key almost deal.
My phone won't post link right now Arggg
Gm part # 19210008
Old 11-16-2014, 03:23 PM   #68
Vintage Windmills
Vintage 4x4s
That is the way these trucks are. Heat is modulated by a flapper that diverts air either through or around the heater core (in the fiberglass box mounted to firewall.) Not sure if burbs are different or why Lattimer has a different setup.
Old 11-16-2014, 05:50 PM   #69
mechanicalman
If your truck does not have a/c, then that is normal. If it has a/c, there should be a vacuum switch on the a/c control head that has 2 nipples on it don't think it makes any difference which one goes where just one from manifold vacuum in and one out through the firewall to the heater valve on the R fenderwell.
IMPORTANT
That engine needs a thermostat by-pass hose. PLEASE don't let ANYONE talk you into drilling holes in the thermostat, this makes your engine take longer to warm up. Bypass hose will NOT make the engine take longer to warm up as it goes back to the water pump (not cooled by the radiator) or the cold side of the radiator ready to be sucked into the water pump.
IF you DON'T have a/c, and you DON'T install a heater valve and you DO keep coolant circulating from the top of the intake into either the water pump or the cold side of the radiator, then the heater circuit will function as a by-pass hose. CAUTION if your heater starts leaking, you by-pass it and forget about it then you could damage your engine. I would not do that with my forgetfulness.
IF YOU DON'T have any thermostat by-pass, eventually air/steam pockets will form before the thermostat opens and the thermostat will not see hot water to make it open, the engine will get hotter and hotter and you will eventually either blow hoses, heater core, radiator, and worse yet crack the heads. Here is an example of a vortec style engine with a by-pass hose, but it's a Ramjet 350 and that manifold has a fitting on the front for the heater supply.
For NON-a/c, heater supply you need what you probably already have a "restricted" 5/8" fitting.
http://www.napaonline.com/Catalog/Ca...515_0421632233
Shown is a short water pump, the fitting on the top for t-stat bypass and the fitting on the side for heater return. The heater return can also go to the nipple you will sometimes see on the cold (passenger) side of the radiator.
Another problem: For your temperature warning system, gauge or idiot light, your sensor or sender may be too large (1/2"NPT) to screw into the smaller hole on the Vortec head (3/8"NPT). However, the intake on your new engine might have the right passages to accommodate everything. The upper one on the passenger side for your heater fitting, the one on the upper driver's side for your temperature warning sender or sensor, and the one in the front for your thermostat by-pass hose. The bypass hose can be 5/8", you will have to remove the plug atop the water pump and adapt down to the proper size fitting for the hose you choose, or drill a hole in the plug and pipe tap it to the size you need.
https://www.google.com/search?q=3/8%...IQsAQ&dpr=0.95
https://www.google.com/search?q=3/8%...+5%2F8%22+hose
Lots of these can be found at Home Depot, Help sections at auto parts stores, or online, but I expect your mechanic will figure it out. If he (your mechanic) balks and wants to drill your t-stat, I'd round up the fittings myself and go to the parts store and get a pre-formed section of heater hose and cut it to fit. He's going to be in a hurry, and really don't get paid to run around and hunt parts.
IF the hole in the driver's side top of the intake is not 1/2"NPT but instead 3/8"NPT (hard to be sure just looking at the picture) you can use a different sensor and either put it there or leave it in the head. I think leaving it in the head looks better, but a better sample of pre-thermostat temperature on the intake, but might poke into the radiator hose. Splitting hairs LOL.
For 3/8"NPT Idiot light use Duralast TU81.
For 3/8"NPT Gauge sender use Duralast TU66.
You may have to install a female spade connector but it will probably shove on there. When your engine arrives, look over the intake/heads, check the water pump plug, sensor/sender on your old engine, and get your parts lined up coming so the installation can proceed un-hindered. Of course have it delivered directly to the shop installing it.
Old 11-16-2014, 06:18 PM   #70
mechanicalman
My 72 factory a/c came with a heater water valve, my 68 factory a/c did not.
I notice your 67 has a/c, but you don't show it on your newer trucks. I'd be interested to know just when they started putting it on.
72 is C10, 68 is C20.
Old 11-16-2014, 06:35 PM   #71
Lattimer
Lattimer's Avatar
Dunno.
My truck was non ac and had a cable operated valve in the heater hose line. I tore all of that out and put in aftermarket air, but it uses basically the same water valve.
Shawn
Old 11-16-2014, 06:57 PM   #72
t5noel
I bought the 195 HP 350 crate engine along with the summit TH350 rebuilt transmission a year or so ago. I put them in a 1974 GMC stepside 1/2 ton long bed. I am very happy with both to date. It has headers with a quadrajet carb and an Edelbrock 2701 Performer Intake Manifold. I have to be easy on the gas peddle, It wants to jump down the road.
t5noel is offline   Reply With Quote
Old 11-16-2014, 07:19 PM   #73
71K20chevy
71K20chevy's Avatar
Fast. Cheap. Reliable. Pick two.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 11-16-2014, 08:01 PM   #74
1972BlueC20
Well said man!
Old 11-16-2014, 11:06 PM   #75
sprint_9
sprint_9's Avatar
Good choice on the engine, while it is more expensive now I think it will be a better piece for you in the long run. The 1 piece rear main and vortec heads are worth it.
sprint_9 is offline   Reply With Quote
