Old 06-04-2016, 11:12 PM   #51
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Very excited about this delivery. Brand new GM Performance LS3 6.2L with Hot Cam and 4L70E transmission. 480 HP / 475 ft-lb torque. Gonna be fun!!!
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 06-05-2016, 01:26 AM   #52
swamp rat
swamp rat's Avatar
Thanks for the update! was wondering about this build.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-05-2016, 02:12 AM   #53
whitels1
whitels1's Avatar
Awesome man, can't wait to see more!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-05-2016, 07:15 AM   #54
GR8-68
GR8-68's Avatar
This is going to be one sweet ride
GR8-68 is offline   Reply With Quote
Old 06-07-2016, 09:21 PM   #55
derotoreut
derotoreut's Avatar
Decided to do some engine test fitting on the Scott's chassis. Bolted up the 4L70E to the LS3 to put it on the chassis. The LS motor mounts from Scott's are pretty slick. The only problem was the LS oil pan interfered with the cross member. Going to use a Holley oil pan.
~ Dan
Old 06-08-2016, 11:00 AM   #56
Dustmaker65
Dustmaker65's Avatar
I really like that chassis! Can't wait to see it going together!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 06-08-2016, 04:14 PM   #57
trkfrk
trkfrk's Avatar
Coming along nice! That LS3 looks great in your chassis.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 06-08-2016, 04:29 PM   #58
derotoreut
derotoreut's Avatar
Thanks Mark. Your build has been a big inspiration for me. Thanks for putting it together.
~ Dan
Old 06-18-2016, 09:56 PM   #59
derotoreut
derotoreut's Avatar
So I bought the Holley 302-1 oil pan for LS retrofit applications. It is a really nice pan. The only problem was I found some porosity in the casting around the oil filter area. I contacted Holley and sent them some pictures. They thought it would be fine to use, but wanted to be safe and have me return it anyway. I decided not to take the chance and return it for another one.
~ Dan
Old 06-18-2016, 11:59 PM   #60
boynton
boynton's Avatar
good eye and good call on the oil pan. it looks like it was a bad pour. you never know where else it is weak/compromised. looking great otherwise.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 06-19-2016, 09:03 AM   #61
Bennett68C10
Bennett68C10's Avatar
Really nice looking project Dan! Love the new frame and drivetrain
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-19-2016, 09:01 PM   #62
derotoreut
derotoreut's Avatar
Thanks. I agree on the bad pour. Thanks for the complement.
Thanks Keith.
~ Dan
Old 06-26-2016, 09:45 PM   #63
derotoreut
derotoreut's Avatar
I received the new Holley 302-1 oil pan to replace the one that had porosity around the oil filter area. This one looks much better. Did the install, which was pretty easy and straightforward. Good thing for the engine stand.
Name:  Holley Oil Pan - 13.jpg
Name:  Holley Oil Pan - 14.jpg
I thought there might be some modifications required to the windage tray, but there weren't any needed.
Name:  Holley Oil Pan - 17.jpg
The install went pretty good.
Name:  Holley Oil Pan - 18.jpg
Test fit on the chassis will be coming up soon.
~ Dan
Old 06-29-2016, 08:53 PM   #64
derotoreut
derotoreut's Avatar
With the new Holley 302-1 oil pan installed, I wanted to do a test fit with my LS3 and 4L70E.
Here is the LS3 with the new Holley pan installed. Pay no attention to that orange thing of mine in the background.
Name:  LS3 Engine & 4L70E test fit - 05.jpg
The Scott's LS motor mounts were installed on the block.
Name:  LS3 Engine & 4L70E test fit - 03.jpg
Chassis is ready for test fitting.
Name:  LS3 Engine & 4L70E test fit - 04.jpg
Engine and transmission fit on the chassis like a glove!
Name:  LS3 Engine & 4L70E test fit - 06.jpg
Name:  LS3 Engine & 4L70E test fit - 10.jpg
~ Dan
Old 06-29-2016, 08:59 PM   #65
derotoreut
derotoreut's Avatar
Here are some close up pictures of the Scott's custom LS motor mounts installed on the engine and in the chassis.
Name:  LS3 Engine & 4L70E test fit - 11.jpg
Name:  LS3 Engine & 4L70E test fit - 12.jpg
No clearance problem now with the chassis crossmember.
Name:  LS3 Engine & 4L70E test fit - 16.jpg
Name:  LS3 Engine & 4L70E test fit - 17.jpg
~ Dan
Old 06-29-2016, 09:25 PM   #66
boynton
boynton's Avatar
looking great. I know you have a long road ahead but the small victories are always nice along the way. Also I couldn't ignore the orange thing in the background. it's too nice.
1970 SWB Step-Side
Old 06-29-2016, 11:06 PM   #67
derotoreut
derotoreut's Avatar
Yes, there's definitely a long road ahead. Hopefully I can stay positive with the build. Thanks for the words of encouragement.
~ Dan
Old 07-15-2016, 09:33 PM   #68
derotoreut
derotoreut's Avatar
Well I ran into another snag with my oil pan. I decided to install the rack and pinion to be sure there was enough clearance. And guess what? The oil pan hit on the rack. Time to back pedal a bit.
~ Dan
Old 07-18-2016, 03:39 AM   #69
swamp rat
swamp rat's Avatar
Humm, did Scott's recommend that particular rack and pinion?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-18-2016, 09:14 PM   #70
derotoreut
derotoreut's Avatar
Mike, Scott's did recommend that particular rack and pinion. That's what shipped with my chassis. I'm now finding out that they used a factory Corvette oil pan on their LS3 build. Apparently the Corvette pan is more shallow at the front end. Here is a picture from Scott's Hot Rod of the oil pan they used. One step forward then one backward. Oh well.
~ Dan
Old 07-24-2016, 07:56 PM   #71
derotoreut
derotoreut's Avatar
Since the Holley 302-1 oil pan hits on my rack and pinion I'm going to swap it out for the 302-2 pan. The 302-2 oil pan was designed mainly for LS swaps in Gen-1 F & X-body cars like Camaro, Firebird and Nova. They say its also used on other car and truck LS swaps. Hoping it should work OK
~ Dan
Old 08-09-2016, 09:44 PM   #72
derotoreut
derotoreut's Avatar
I went ahead and did the swap to the Holley 302-2 oil pan. I am very pleased in how it turned out.
Here is the engine with the oil pan removed and full windage tray still installed.
Removed the windage tray.
Name:  Holley Oil Pan - 29.jpg
I had to either modify the existing windage tray or purchase the GM one. I decided to buy the GM tray already modified.
Name:  Holley Oil Pan - 32.jpg
Once the new pan was installed I had plenty of room between the rack and pinion and the oil pan.
Name:  Holley Oil Pan - 34.jpg
You can see there is plenty of clearance between the 302-2 oil pan and the cross member as well as the rack and pinion.
Name:  Holley Oil Pan - 35.jpg
~ Dan
Old 03-17-2017, 08:16 AM   #73
Bennett68C10
Any updates, how is the build going?
Keith
66 Suburban
IG: bennett68c10
Old 03-17-2017, 12:35 PM   #74
meenaggie
Good to see someone posting what actually happens on these type of custom builds … parts rarely just bolt on and the lack of instructions with many of these custom setups leaves the end user to figure things out on their own. Nice build and keep up the persistence!
meenaggie is offline   Reply With Quote
Old 03-17-2017, 09:55 PM   #75
derotoreut
derotoreut's Avatar
Hey Keith, I'll get some updates on here soon. I've been busy with work and family. I haven't given up on the build. I'll keep you posted.
~ Dan
