Old 03-11-2015, 12:19 AM   #51
Nitis
Nitis's Avatar
Re: 4x4 LS cross member
My only issue with the ac in stock location is the fact that it is not user friendly to work on. Granted you hope you don't have to mess with it often if at all but still it's got to be a pita to adapt lines to and service
Nitis is offline   Reply With Quote
Old 03-11-2015, 12:26 AM   #52
First c10
First c10's Avatar
I agree with it's a pita I just made up two adapters to get around the frame and hooked hose from there on out getting the compressor on and off is easy it's the refrigerant lines that were the toughest part. And you are right I hope I don't have to mess with it.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-11-2015, 12:37 AM   #53
Nitis
Nitis's Avatar
First. I'm about two hours north of you And have been looking for an exercise to come to wool growers so as you get closer to completion I want to see your rig
Old 03-11-2015, 02:22 AM   #54
DWilbur
Check out post 162 in my build thread you can see how tight the AC compressor is in the frame.
DWilbur is offline   Reply With Quote
Old 03-11-2015, 12:52 PM   #55
First c10
First c10's Avatar
ok no problem now that you say that will have to go to dinner this week!!!
GO GO!!!
Old 03-11-2015, 01:00 PM   #56
First c10
First c10's Avatar
Thats about how my c10 was. I made custom stubs (lack of a better word) that connects to the compressor and curved around the frame and allowed about 1 inch clearance. I tig welded a fitting to connect to the refer lines I had made at Napa. They ordered the ends and put together the lines pretty cheap.
GO GO!!!
Old 03-11-2015, 03:29 PM   #57
Pacific Fabrication
Pacific Fabrication's Avatar
Originally Posted by SDfarms View Post
Scott i would go with dirty dingos cross-member if you are not able to build your own it would be quite simple. Myself got the pacific fab because it was dang near 150 cheaper... Big mistake... Both me and chris (Reno build) experienced the motor mounts not lining up, he didn't have it as bad as i did i had to weld an extension to the top on both sides. Once i got it bolted in i noticed one mount was twisted. I would not want anyone to have something like this.
Sorry to hear you had some issues with our crossmember. Please give us a call and let us know exactly what happened. We are always trying to improve on the design and feedback is greatly appreciated.
Pacific Fabrication is offline   Reply With Quote
Old 03-11-2015, 05:42 PM   #58
DWilbur
That's cool you where able to tig weld some fittings. I bought a nice Miller tig welder in 2006 but my tig welding skills are less than acceptable and I have not spent the time to learn the skills needed. some day I will.
Old 03-11-2015, 07:27 PM   #59
First c10
First c10's Avatar
Well I think you maybe giving me more credit than I deserve. I did TIG weld it. But it's not that great looking. I wish I had my own. I used one that we had at work. I would love to be able to get my welds to look like a roll of nickels. Wait 9 years you have had it? How come you don't use it more?
GO GO!!!
Old 03-11-2015, 08:02 PM   #60
DWilbur
some time I get about an 1" of weld that looks like a sloppy roll of nickels then it gets worse and it melts together and looks like one melted mess welding aluminum. At least I can melt the metal together and the fit and function are still in tact. I mostly mig weld anything thicker that 1/16" in steel and mig weld aluminum. their are so many adjustments in the tig welder with the square wave and heat adjustment I'm not sure what is what half the time. then you have the different tungsten for different metals. see how it gets confusing. the mig welder is wire speed and heat settings.
Old 03-11-2015, 11:54 PM   #61
First c10
First c10's Avatar
That's funny. In my comment I said I would like to be able to weld LIKE. I probably weld with a TIG like you!!! The TIG I used was already set up for me so that must be my secret!!! It is a square wave Lincoln high dollar unit.
I love my MIG though.
GO GO!!!
Old 03-12-2015, 12:58 AM   #62
GMC-YA68
GMC-YA68's Avatar
Raise the mount 1.5" and you are golden!
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 03-12-2015, 01:43 AM   #63
DWilbur
After I get my D60 front end rebuilt and the wheel on I will install my engine and take some pictures for you guys with more detail and see if I can get the Doug Throley Headders to fit.
Old 03-14-2015, 04:58 PM   #64
First c10
First c10's Avatar
I have a question Has anyone tried a crossmember from a square body in a 67-72 frame for a Ls swap? I found a complete chassis from a 91 suburban tongue to tail for 200$ springs and axles?
GO GO!!!
Old 03-14-2015, 08:38 PM   #65
Nitis
Nitis's Avatar
Not sure what modification would be needed but in theory why wouldn't it work? I've dug on this somewhat deep and first I've seen it mentioned
Old 03-15-2015, 05:36 AM   #66
First c10
First c10's Avatar
Well when I get a chance to get the frame next week maybe. I will post a picture.
GO GO!!!
Old 03-15-2015, 07:27 AM   #67
Nitis
Nitis's Avatar
I posted a thread in the 4x4 section someone out there must know the answer
Old 03-19-2015, 02:19 AM   #68
First c10
First c10's Avatar
Here's the thread
GO GO!!!
Old 03-19-2015, 02:23 AM   #69
Nitis
Nitis's Avatar
Man were your ears burning? I was just thinking about the thread and just finished reading it again
Any news on your build?
Old 03-19-2015, 11:06 AM   #70
First c10
First c10's Avatar
No I have had to work some OT this week and both my sons are in football & track so work on the truck had stopped for a few days. The frame I purchased should be ready to be picked up Friday. Not sure if I will get to pick it up before Monday next week.
How about you?
GO GO!!!
Old 03-19-2015, 11:38 AM   #71
Nitis
Nitis's Avatar
In all honesty I bet it's close to 12 months before I start on mine got a couple priorities muddying the water
Old 03-19-2015, 01:57 PM   #72
First c10
First c10's Avatar
I am a 12 months before everything!!! lol!!
GO GO!!!
Old 10-26-2015, 05:05 PM   #73
my67chevytruck
Under Construction
my67chevytruck's Avatar
great info.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-05-2015, 11:58 PM   #74
72LSK10
72LSK10's Avatar
Hey guys, I've been doing extensive research on a cross member for my LQ9 swap into my '72 K10. After realizing that hundred of dollars for a piece of bent tube is beyond Ludacris, I decided to make my own out of .120 wall chromoly tubing I have and use my JD bender. That's when I came across a guy at Pomona that had two sick old skool Burbans with LS Swaps. He had some simple and clean black powder coated cross members. When I asked the builder how much I could get one for, he told me to walk over to "The Truck Shop" vendor and buy a Chevy 47-59 truck V-8 Swap cross member they run $46.00, yup.... That's right..... $46.00 it's on page 93 of their 1947-1959 truck catalog. They even have the motor mounts, all you need is the LS mount plates and you're set. I'll try to post a pic tomorrow, trust me, you can't beast this cross member and the price is beyond right.
http://www.jegs.com/i/Trans-Dapt/969/4840/10002/-1
It looks like this universal kit but for even less coin, the build is very solid, I couldn't even build one myself for $46 and definitely not worth my time when I can get such a nice piece for this price, I hope it helps.
72LSK10 is offline   Reply With Quote
Old 11-06-2015, 12:22 AM   #75
Nitis
Nitis's Avatar
Well get it in and snap some pics!!
