Old 12-22-2015, 11:30 PM   #51
Jake Wade
Jake Wade's Avatar
Re: 79 K20 Custom Deluxe - Goldy LS1
I am a Gen 1 guy, I take it a LS 5.3 block(3.78) can safely be bored to (3.90), obviously since you have done it.
Jake Wade is offline   Reply With Quote
Old 12-23-2015, 10:07 AM   #52
whitels1
whitels1's Avatar
The iron blocks(mine anyways) was bored and sonic tested and all good.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 12-23-2015, 10:09 PM   #53
Jake Wade
Jake Wade's Avatar
What method did you use to change out the cab mount bushings? Did you raise cab off frame one side at a time?
Old 12-23-2015, 10:17 PM   #54
whitels1
whitels1's Avatar
Yes, I had the frame resting on 2x4 square tube, then raised each side just enough to change them, seemed to work out good and keep everything aligned.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-28-2015, 10:22 AM   #55
slotard
oddly enough, the aluminum 5.3 is very sought after for building big engines. I've seen them sleeved and running bores in excess of 4.125, apparently they're stronger than the car blocks too.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-10-2016, 11:38 PM   #56
whitels1
whitels1's Avatar
I finally had some time to get a video up, it's been crazy trying to find time for the old Square! I got a call on Christmas Eve about a very special baby that needed a home, so we added another to our family. It's been a sleep deprived whirl wind. Shifters are fabbed up, I think I will need to weld a washer at the end sort of like a shoulder, I believe that will help with the deflection, you will see what I'm talking about in the video. Then I got working on my crossmember after I received the transfer case mounting kit and misc parts.
I still need to finish welding the crossmember etc but at least it's fabbed up. I don't see any reason why that wouldn't be strong enough.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-11-2016, 01:19 AM   #57
MTCK
MTCK's Avatar
Looks good! Keep adding to the family and you will need a crew cab!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-11-2016, 10:10 AM   #58
whitels1
whitels1's Avatar
Thanks! I would love to do a crew, I just can't fit it in my garage!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-23-2016, 08:51 PM   #59
whitels1
whitels1's Avatar
Video update, found a nice harness at the wrecking yard, separated and pinned it out, and a few other things.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-25-2016, 02:59 AM   #60
whitels1
whitels1's Avatar
Exhaust work this weekend!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-25-2016, 04:29 AM   #61
MTCK
MTCK's Avatar
Good work. I'd like to do my own exhaust on my 3+3 when I get that far. We'll see how my patience is holding up at that point.
-Marcus
Project Plow Truck
Old 01-25-2016, 10:17 AM   #62
whitels1
whitels1's Avatar
Thanks Marcus, I'm sure you will still have some left lol
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-29-2016, 09:31 PM   #63
Jake Wade
Jake Wade's Avatar
Loving the build man, keep the videos coming, I look forward to them.
Old 01-29-2016, 09:35 PM   #64
Jake Wade
Jake Wade's Avatar
How to you determine your length/angles when cutting the pieces to make the S bends for the exhaust piping? Do you use math?
Old 01-30-2016, 03:11 AM   #65
whitels1
whitels1's Avatar
Thanks Jake! Math lol... I actually just cut a bend I had and then turned it 180deg which happened to come out just about right.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-01-2016, 12:15 AM   #66
whitels1
whitels1's Avatar
This weekend I got the core support back in place.
Good clearance for my winch mount location, so far!
PCM bracket made, just needs to be mounted!
The video!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-01-2016, 03:50 AM   #67
MTCK
MTCK's Avatar
Good progress. I may have missed it, but are the K20 axles staying on the K10 and vice versa?
-Marcus
Project Plow Truck
Old 02-01-2016, 10:44 AM   #68
whitels1
whitels1's Avatar
Thanks Marcus! Yes the 8 lug stuff will be staying in the K10 and the welded up 14 bolt sf / 10 bolt will stay in the K20 (trail rig)
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-01-2016, 04:08 PM   #69
400/400
Cool build!
A suggestion on your mount. Run gussets from the front edge back to the fire wall. With the amount of vibration an off-road toy will see it may end up cracking the firewall without the gussets. Also, grind large radiuses onto any corners contacting the sheet metal. Sharp corners or small radiuses will likely tear into the sheet metal.
Another reason to limit the movment of the bracket is, depending on how high on the firewall its mounted, it could start to seperate the dried out seam sealer in the cowl if it flexes a lot. Probably not as big of an issue where your at but up here that's an area that likes to rust out.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 02-01-2016, 04:21 PM   #70
whitels1
whitels1's Avatar
Originally Posted by 400/400 View Post
Cool build!
Thanks and Thanks for the heads up!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-05-2016, 02:02 AM   #71
whitels1
whitels1's Avatar
What are your thoughts of the PCM mounting location? I still have to add more support but I think it could work and it's out of the way.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-11-2016, 10:37 PM   #72
Greenlee
Greenlee's Avatar
Looking good! This thing is going to be a beast.
I would worry about the PCM getting really hot right there above the headers???
Greenlee is offline   Reply With Quote
Old 02-12-2016, 05:35 PM   #73
72MARIO
72MARIO's Avatar
Exactly what I thought before i read your post.
Why do you want it mounted to the engine ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-13-2016, 01:12 PM   #74
MTCK
MTCK's Avatar
I think it looks clean. You could fab up a little heat shield for it that goes below the pcm maybe?
-Marcus
Project Plow Truck
Old 02-13-2016, 03:17 PM   #75
whitels1
whitels1's Avatar
Thanks guys, I like the Idea of having it on the engine and out of the way, less wiring running all over the engine bay. If in the future it's an issue I'll come up with a solution.
Speaking of wiring, I started getting all of my plugs going and the pcm re-pinned. I did have to make a trip to the wrecking yard for plug ends but overall I'm happy with the 27 dollar harness. It's still a mess but it will come together, organized chaos!
An Idea of my lift and how much the axle has moved forward.
The Video
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
