Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 02-02-2017, 12:10 PM   #51
Pro Performance
Pro Performance's Avatar
Re: Pro Performance: C1500 RCSB Build
One more time... how about now? Uploaded to a completely different image hosting site.
Pro Performance is offline   Reply With Quote
Old 02-02-2017, 12:51 PM   #52
OutlawDrifter
They are now working.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 02-04-2017, 02:56 AM   #53
KingSize
Thumbs up Re: Pro Performance: C1500 RCSB Build
Cool man, keep it up
KingSize is offline   Reply With Quote
Old 02-07-2017, 03:22 AM   #54
Pro Performance
Got a few loose ends finished up this weekend on the truck. Quickly installed the roll pan, and have yet to weld it in. Also have a set of sport mirrors to go on. The truck will eventually get painted, but have decided to handle all the suspension and drivetrain first. Was able to pick up a 5.3/4L60E combo, which should be going in the truck in the next few weeks. My plan is to see how cheap it can be done, and plan on using as much factory stuff off the engine as possible, and doing the harness myself. I will do a full write up and document as much as possible.
Old 02-07-2017, 04:17 AM   #55
KingSize
Old 02-09-2017, 06:21 PM   #56
rydeordie
What roll pan are you running?
Instagram: rydeordie72 https://instagram.com/rydeordiechevy/
rydeordie is offline   Reply With Quote
Old 02-09-2017, 06:38 PM   #57
Pro Performance
It is from Grants Customs, when they had a sale about a year ago. Just need ot barely trim the one side, and then we will fully weld it in.
- Travis
Old 03-03-2017, 10:11 AM   #58
hawgfanman
Any updates?
hawgfanman is offline   Reply With Quote
Old 03-04-2017, 10:44 PM   #59
68basket
curious about the choice to do leafs and shackles vs a flip kit? pros and cons?
68basket is offline   Reply With Quote
Old 03-06-2017, 09:37 AM   #60
Pro Performance
Originally Posted by hawgfanman View Post
Any updates?
Just got the LS dropped in. Be posting pictures here shortly.
The previous owner had pulled leafs, and really destroyed the original leaf pack. Instead of finding stock leafs, decided to do drop leafs which had all new bushings installed as well. Then added a shackle to make it a 6" drop. I don't think it dropped the same as a flip, but gave the truck nice rake. Plus, with the LS, the front lifted a little due to slightly less weight, so I think it will even out nice.
Old 03-07-2017, 02:16 PM   #61
Pro Performance
Old 03-07-2017, 02:33 PM   #62
hawgfanman
Nice!
Old 03-07-2017, 11:37 PM   #63
91short
Man, I'm jealous! I'm wanting to do an engine swap just like this.
91short is offline   Reply With Quote
Old 04-28-2017, 08:27 AM   #64
KingSize
long time no update, what's going on with this build? I'm having withdrawls over here, tell me something...lol
Old 04-28-2017, 04:15 PM   #65
Pro Performance
Haven't worked much on it, since my schedule has been so busy. However, I am hoping to get some time in today and this weekend, and fire it up by Sunday.
Old 05-15-2017, 10:27 AM   #66
Pro Performance
Some updated progress on the truck. Got the LS fired, and just about ready to go around the block for the first time. Made a quick bracket to adapt the pedal on the inside, mounted the TAC module and installed the Dakota Digital gauges. Man, these gauges are so much better than the original sweeper style. Just make the inside of the truck seems a lot more modern.
Old 05-15-2017, 01:17 PM   #67
hawgfanman
Nice!
Old 05-15-2017, 10:07 PM   #68
KingSize
dig the gauges
Old 05-16-2017, 08:08 PM   #69
SCOTI
SCOTI's Avatar
I've been looking hard @ those gauges for my 90.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-17-2017, 08:49 AM   #70
Pro Performance
I think they are a great upgrade for these trucks. Especially being it is something that you always look at, and the early stock ones are terrible.
Old 05-17-2017, 09:11 AM   #71
Pro Performance
Got the 94-98 filler panel mounted in there, and used some spacers to adapt it to the 88-93 core support. I used 3/4" spacers on the ones shown, and a 1/2" one for the center. The far ends ones didn't end up on a flat spot on the core support. For the time being, I didn't attach those, and all seems sturdy. If I end up needing them, I will make a small bracket to attach them. After the grille clips in, it is firm.
Also cleaned up and re-did some wiring on the front lights. Got them all working, and did new bulbs and housings.
Old 05-17-2017, 05:12 PM   #72
arrg
How was the install on the gauges?
arrg is offline   Reply With Quote
Old 05-17-2017, 05:23 PM   #73
Pro Performance
Honestly, pretty easy since they are made for the truck. There is a plug for the original gauges at the back. You just splice into some of those wires for your blinker indicators, high beam, park brake light, etc. Can install in one-day, no problem.
Old 05-18-2017, 03:20 PM   #74
Joseog83
Joseog83's Avatar
Loving this build!!
Joseog83 is offline   Reply With Quote
Old 05-18-2017, 08:35 PM   #75
Kriegs
Ditto, following this build!
I take it there is no need to get the fillers for fenders from a 94+ to fit the 94+ center for the newer grille?I want to swap to the 94+ grille in my 90 w/t and taking notes on what all I need.
Read I needed the 94+ center bumper brackets as well,on another site, for the swap.Take it that aint the case?
Kriegs is offline   Reply With Quote
