Old 03-10-2016, 03:09 PM   #51
daddyjeep
daddyjeep's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Top coat.
[IMG][/IMG]
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-10-2016, 04:05 PM   #52
68Timber
I know the pieces fit
68Timber's Avatar
You're moving fast - looks good!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-14-2016, 01:07 PM   #53
daddyjeep
daddyjeep's Avatar
I started Saturday morning off by stripping this fat girl.
[IMG][/IMG]
A couple hours with the wire wheel and it was looking pretty good. Next step was more POR15 metal Prep. I love this stuff, you can actually watch the rust disappear.
[IMG][/IMG]
Then it was time for some paint and reassembly. I guess I didn't get a pic of the dressed up fat girl by itself...sorry.
[IMG][/IMG]
[IMG][/IMG]
Then I realized a problem. The rear is way too soft. I took 4 leaves out of the main pack and now I can bottom it out against the overloads with little effort. I guess I need to clean up a couple more leaves.
04 1500 crew cab
Old 03-14-2016, 01:10 PM   #54
MTCK
MTCK's Avatar
Looks great. How did you scuff the POR15?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-15-2016, 12:42 PM   #55
daddyjeep
daddyjeep's Avatar
I did not scuff the POR15. I sprayed the top coat before it was 100% cured. Hopefully that works.
04 1500 crew cab
Old 03-15-2016, 10:26 PM   #56
daddyjeep
daddyjeep's Avatar
Got all my body parts ordered today from a local place. They had a couple parts on hand and the quality seems good. I ordered 2 sets of rockers, inner rockers, cab corners, and floor plans. It should all be here next week so I can start the next phase.
04 1500 crew cab
Old 03-15-2016, 10:49 PM   #57
MTCK
MTCK's Avatar
Cool who is the manufacturer?
-Marcus
Project Plow Truck
Old 03-15-2016, 11:18 PM   #58
daddyjeep
daddyjeep's Avatar
I have no idea. I'll find out when I get them I guess.
04 1500 crew cab
Old 03-21-2016, 09:57 PM   #59
daddyjeep
daddyjeep's Avatar
I added the two lower springs back into the pack and think I am a lot closer to where I need to be. I will know more once I get a bed on the truck.
[IMG][/IMG]
[IMG][/IMG]
I got my custom made u bolts in too. $35 from my local Napa.
04 1500 crew cab
Old 03-22-2016, 12:10 AM   #60
MTCK
MTCK's Avatar
That looks a lot better.
-Marcus
Project Plow Truck
Old 03-26-2016, 01:43 PM   #61
daddyjeep
daddyjeep's Avatar
I started cutting out the rusty floor and rockers and started fitting panels. This is going to take a while to get everything fitting g correctly.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Don't worry, the doors will go back on before welding so I can be sure the rockers are lined up.
04 1500 crew cab
Old 03-27-2016, 10:21 PM   #62
daddyjeep
daddyjeep's Avatar
A little more fitting tonight. Anyone who has been here please feel free to chime in. I think the rocker is pretty close, but the floor appears to be way off where it nests with the rocker. Am I missing something or are these panels just that much off. I can make them work, but before I start cutting them up I would like some opinions.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 03-27-2016, 10:41 PM   #63
Front Range
Front Range's Avatar
Just went through that on a passenger rocker, maybe these pictures will help a little. If I lay a straight edge across the original floor / inner rocker it sits roughly 3/8 to 1/2 inch above the new outer rocker seal lip / edge.
I didn't have to replace my inner rocker or floor. I lined my rocker up by hanging the door to check the lower gap and also using door measurements off the drivers side from top of door frame to rocker sill. That gave me a pretty good idea of where the new rocker needed to be. Hanging the door was the most beneficial.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 03-27-2016, 10:49 PM   #64
daddyjeep
daddyjeep's Avatar
The pics do help. At least I have some reference. Thanks. I will re-hang the front door tomorrow before going any further.
04 1500 crew cab
Old 03-28-2016, 11:50 PM   #65
daddyjeep
daddyjeep's Avatar
I put the front door back on and verified the position of the rocker. It was 1/8" low in the front. I ran a couple screws to lock it in place. I then focused my attention back to the floor. I build a patch for the transmission tunnel and got it tacked in. I need to clean up the underside before I weld any more. I don't like fires. The floor pan should work out with a little more trimming and persuading.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 03-29-2016, 11:06 PM   #66
daddyjeep
daddyjeep's Avatar
Finished the transmission tunnel patch and started burning in the floor. I have to make a couple fillers. One because the new pan just didn't get to that area and one because I made a bad cut. Oh well, it's just 200 extra spot welds
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 03-29-2016, 11:48 PM   #67
MTCK
MTCK's Avatar
Nice work man. You are getting after it. Going to meet your April deadline for towing your jeep?
-Marcus
Project Plow Truck
Old 03-30-2016, 09:50 AM   #68
Front Range
Looks good, that is a lot of work to get done. After doing your own rust work you start to understand why body shops charge so much.
Old 03-30-2016, 01:02 PM   #69
daddyjeep
daddyjeep's Avatar
I doubt I will make the deadline, but that doesn't mean I'm not going to try. Aside from getting the rust repair out of the way, I still have some big items to take care of. I still need to shorten the drive shaft, make all new brake lines, figure out the gas tank, find or make a bed, put the interior back in, and see if the truck even runs. That's a pretty good list to accomplish in three weeks while still having to work for a living and chase around three kids. I still have to replace the rockers and brake lines on my son's car since he will have his license in three weeks as well. If I can't take the Jeep to the trail guide training in Butler in three weeks it isn't a big deal, but the next training in May is at Raush Creek Off Road Park. I will not miss taking the Jeep there.
04 1500 crew cab
Old 03-30-2016, 10:26 PM   #70
daddyjeep
daddyjeep's Avatar
Floor pan is fully welded. I could grind the welds more, but it isn't worth the effort. It will be under sound deadening and carpet anyway.
[IMG][/IMG]
The fillers were a bit of a pain, but they came out just fine.
04 1500 crew cab
Old 04-03-2016, 03:06 PM   #71
daddyjeep
daddyjeep's Avatar
Cut, weld, grind...cut, weld, grind...cut, weld, grind. That is all I seem to do anymore. The drivers side front floor and rockers are done and the rear rocker has been modified and is ready to weld in.
For those wondering how to do complete rockers for a crew cab using 2 front sets, here is my take on it.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 04-03-2016, 05:48 PM   #72
MTCK
MTCK's Avatar
Looks good! Want to come do my plow truck truck when you are done???
-Marcus
Project Plow Truck
Old 04-03-2016, 06:21 PM   #73
daddyjeep
daddyjeep's Avatar
Nope
04 1500 crew cab
Old 04-03-2016, 08:07 PM   #74
Chevy_mud_truck
Chevy_mud_truck's Avatar
So much fun look good thanks again for the frame pieces
Chevy_mud_truck is offline   Reply With Quote
Old 04-08-2016, 11:47 PM   #75
daddyjeep
daddyjeep's Avatar
I haven't had a whole lot of time to work on the truck this week. I did at least get the rear rocker in place and started blending in the voids and blending the rear into the front. Hopefully I can finish up the drivers side this weekend.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
