12-06-2016, 12:42 AM | #51 |
Re: 1966 C10 Daily Driver
its coming along nicely ....
dont want to hear excuses, i want to hear solution(s) |
12-06-2016, 02:00 AM | #52 |
60-66 Nut
So now you have the CPP engine mount brackets in the forward location and the engine mounts in the forward most location on the ICT adapter plates? What is the difference in oil capacity between the LS3 oil pan and the Muscle Car pan?
12-06-2016, 09:44 AM | #53 | ||
-The specifications for the crate engine say: 5.5-quart (with filter) but the original oil pan (12649748) is listed as 8 quarts on a couple websites. -The new oil pan (19212593) is listed as 5 quarts everywhere. |
12-06-2016, 10:53 PM | #54 |
Ran into hiccup. The slave cylinder disconnect doesn't clear the transmission. Going to mull it over and guess die grind some clearance into it tomorrow unless I decide on a different route... just hate the idea of grinding on a brand new transmission.
12-06-2016, 11:33 PM | #55 |
Of all the companies I deal with I have found cpps customer service to be the absolute worst in the industry I have used lots of their products, seems that the folks designing their stuff have some form of intelligence but between a lot of the components being manufactured overseas and the morons on the tech line + the crappy ship time when I have to buy their stuff I order from Summit
12-07-2016, 06:23 PM | #56 | |
The standard 14" out of the middle + 6" off the end shortens the frame to SWB dimensions while keeping the wheelbase & frame kick-up similar to a SWB. Cutting 20" out of the middle & moving everything forward yields the same overall frame length but seems to me it shifts the frame kick-up over the rear end 6" farther forward which in my head impacts the wheelbase. Am I missing something??
12-07-2016, 06:28 PM | #57 | |
12-07-2016, 11:45 PM | #58 |
So five minutes with a file and I was able to get the slave cylinder to fit. It still erks me that I didn't fit out of the box. The slot for the bleeder lines up perfect, but for the quick disconnect it is still quite off a bit.
Guess I could keep filing but did enough so it fits with a little to spare: The cut out for the bleeder lines up perfect: In proggress... |
12-11-2016, 03:23 PM | #59 |
Made some progress this weekend, pictures below. This is going to be an interesting week. I have to fly 24 to perform 4 hours worth of work. Then I am taking off two weeks after that. Hopefully lots of progress before the new year.
Hung the rear coil overs: Threw on the harness: The CabLifter2000: The cab back on: |
12-12-2016, 06:58 AM | #60 |
Nice!!!!!!!!
12-18-2016, 07:49 PM | #61 |
Got my Boyd's fuel tank in, it's an absolute work of art. After hours and hours of contemplating it I've decided I am going to put the original oil pan back on and shift the motor mount to the back holes. When I wonder why later I decided because:
1. The original oil pan is 8qt vs 5qt. I can only assume the 3 extra qt provide better cooling and lubrication capacity. 2. On the LS3 two of the transmission bell housing bolts mount to the oil pan. The muscle car oil pan doesn't have one of these bolts. Everything I've read says it is okay, but it leaves an unsupported section where the bell housing touches the block on the passenger side. Probably fine structurally, but I can only imagine it would make a vibration noise one day that I'de never be able to figure out. And the garage is once again cluttered while I take everything back apart. |
12-19-2016, 09:56 AM | #62 |
Nice, i agree on the boyds tank, its a shame to hide them, work of art for sure. i love where your going on this build!
12-22-2016, 08:18 PM | #63 |
Did a ton of work to end up at the same spot minus 2 and a half inches. Removed the trans, removed the muscle car oil pan, installed the original oil pan, installed the trans, moved mounts to the back two holes, drilled a new bottom hole for the mount, and reinstalled the motor and trans. I put on the original headers as well. Haven't decided if I am going to use them or not, at the point where I am tired of spending money though and still need to buy quite a few items just to crank it.
Close up fitment, about enough to stick my fingers between: Under: |
12-23-2016, 01:49 AM | #64 |
60-66 Nut
Looks good to me. Just curious if you have checked your trans output shaft angle to see how it compares to your pinion angle?
12-23-2016, 08:45 AM | #65 | |
01-15-2017, 08:18 PM | #66 |
In full on assembly mode this weekend, on the way to cranking it, crossing fingers next weekend.
-Got my DeWitts radiator in (pn# 6239017M) and mounted using the original hardware and new rubber. It is a thing of beauty. -Bought a repro tri plus radiator support and battery holder. I am in short supply of hours so and mine needed too much work. I couldn't justify the cost differential of labor and powder coating to fix the original. -Dropped off a ton on parts to the powder coater this week: inner feasder wells, pedal assembly, brake booster mount, drag link and a bunch of small brackets. Should get them back on Wednesday. I really need the Captain Fab's brake booster/clutch mount back so I can depress the clutch so I can crank the truck. -I finally got my Boyds tank mounted. I made my own install kit from some 1/8" sbr rubber, and 6 - .5"x1.5" bolts. -Lastly, I plumbed the fuel system. I used Russel on my last car so I decided I'de try Earls this time. I'll let you know in 10 years how it stands up. I went the braided line to stainless to braided line route. Looks good. I really impressed myself with the stainless line. I bought a new Rigid 3/8 and 3/16(for brakes and clutch lines) 600 series tubing benders. They are nice so nice... New core support: Pretty bent stainless line, and fish plate I forgot to take pictures of earlier: Tank to filter/regulator: Sweet bulkhead fitting from stainless to flex line: |
01-16-2017, 01:37 AM | #67 |
60-66 Nut
Very nice work
01-16-2017, 01:15 PM | #68 |
Wow, great build! I just found this thread and am loving it. I can't wait to see this truck running!
01-16-2017, 04:12 PM | #69 |
Custom Truck Lover!
loving it. all caught up. MORE.....MORE......MORE!
Squarebody guy |
01-16-2017, 08:43 PM | #70 |
Looking great, LS's Motors just look sweet in these trucks!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
01-17-2017, 01:33 AM | #71 |
60-66 Nut
Did you get someone to cut those new engine mounts you were wanting?
01-17-2017, 08:19 AM | #72 |
Yes & no. I sold my 3 axis CNC mill when I moved to Virginia, my wife said I could buy another one as soon as the truck is officially my daily driver. Plan is to finish the truck, get my new mill, and then I am back in the parts making business.
01-23-2017, 02:58 PM | #73 |
Assembly, assembly, assembly. Everything is a mess, parts all over the place. I decided to powder coat the valve covers now so now assembly is going in reverse.
Driveshaft came in, and I realized I still dont have a transmission crossmember... I swear I ordered it... I was sweating the driveshaft coming in. I measured 100 times, but still had that fear in the back of my head that I mismeasured or wrote something down wrong. I bought a 3" aluminum from Dennys, took about a month to get it. I am apparently in a driveshaft desert, couldn't find anyone around me to make one. I've been playing the back and forth game with Jegs looking for a straight water neck/thermostat housing for a LS3. The Spectre 4932 is the one that ended up being right. Advance Auto let me spend an hour looking through their hose wall. I found a Dayco D71852 that fits almost perfect (with a little trimming). It's 1.5 on both ends and the height for the z is dead on. ICT Billet sells a hose that works perfect for a heater core loop untill I get the heater set up. I splurged and bought the GM (PN#19301246) air intake kit. I looked and looked, but couldn't figure out if the Spectre intakes had the bung for PCV on it so I gave up and ordered the Chevrolet Performance Kit. (I know the MAF sensor tube is mounted backwards). I'll eventually trim it to length when I get the fenders mounted. |
01-26-2017, 08:47 PM | #74 |
Hoses in, system filled, and currently pressure checking. I made a change and put a hard piece to clear the air intake a little better. I was able to find 4 oem steam clip hoses at the junk yard too.
Valve covers are back too, everything is buttoned up, torqued up, and filled up. I've primed the motor all I've got to do is connect the clutch and basic electrical so I can crank it this weekend. |
01-28-2017, 08:31 PM | #75 |
Motor cranked and running.
