Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-13-2016, 10:06 PM   #51
First c10
First c10's Avatar
Re: Project "Hulk Jr"
One picture at a time from my iPhone.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-13-2016, 10:07 PM   #52
First c10
First c10's Avatar
Close up of the driver front leaf spring perch bolts.
GO GO!!!
Old 04-13-2016, 10:13 PM   #53
First c10
First c10's Avatar
After I got the floor cleaned up. And tools wipped off. I through on the brake booster and master cylinder to see how I am going f to run the lines. Damn it sticks out a long ways. Atleast from before. Lol.
Oh and I hung the new front brake lines for the GM 10bolt.
GO GO!!!
Old 04-15-2016, 01:29 AM   #54
First c10
First c10's Avatar
Got the Rancho add a leaf installed it really stiffened up the leaf pack. See the picture of the stock spring and the spring with the add a leaf and the bottom spring removed.
This is the first add a leaf with the leaf brackets. Do I fold them down?
GO GO!!!
Old 04-15-2016, 01:32 AM   #55
First c10
First c10's Avatar
A picture of the driver side spring installed. I also drilled the holes for the captain fab power steering bracket.
GO GO!!!
Old 04-15-2016, 01:39 AM   #56
swamp rat
swamp rat's Avatar
7/16 is the correct diameter for the rivet then? was wondering if so.
I haven't removed any of them yet, I have some slightly wandering steering even after a front end rebuild and a rebuilt steering box from a local parts store about 6 years ago, I asked a front end guy about it and he had me rock the steering wheel while he looked, he said told i had slightly loose rivets on my front spring mount, I haven't seen the movement myself yet, replacing the rivets is on my list if things i need to do eventually.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-15-2016, 02:37 AM   #57
First c10
First c10's Avatar
Yes 7/16 is just a little bit bigger so you will have to drill them out. I used flat washers and top lock nuts in grade 8.
GO GO!!!
Old 04-16-2016, 12:44 AM   #58
First c10
First c10's Avatar
Thought I would try the Eastwood flat black rust encapsulater brushed it on. Not bad.
GO GO!!!
Old 04-16-2016, 02:11 AM   #59
Nitis
Nitis's Avatar
I have the same issue on mine right now
I can really feel it on some right turns the steering wheel almost feels like it skips!
Nitis is offline   Reply With Quote
Old 04-16-2016, 09:34 AM   #60
First c10
First c10's Avatar
I hope I don't have that problem. It's tough when you have replaced the old parts with new and still have problems. I am converting to the newer style steering components.
Heck I have down it to both trucks. This one will be the test as it will be up and running first.
GO GO!!!
Old 04-17-2016, 01:57 AM   #61
First c10
First c10's Avatar
I bet I spent 12 hours on the truck today. I got the front of the frame and firewall completely painted. I bent up all the brake lines and installed the brake booster. Installed the power steering gear box, steering column and mid shaft. Got the bezels cleaned up and switched over I didn't get it installed yet as I wired up the new brake switch, drilled a new hole in the pedal. Wired up the neutral safety switch, brake light switch, reverse lights and tc lock up is ready to go. I also replaced the heater control that was black with a good silver one I got front the parts truck before I sold it. The black one had been rebuilt with the cheap levers very flimsy. The silver one is all original. I also took the cables and readjusted them and lubed them up. They work good I just hope the fan switch works.
I feel like I spent all this time and didn't get a lot done. This stuff is tedious. But after typing it looks like a lot got accomplished today. I will post a few picture later.
GO GO!!!
Old 04-17-2016, 11:16 AM   #62
First c10
First c10's Avatar
Picture of the front frame painted up.
GO GO!!!
Old 04-17-2016, 11:19 AM   #63
First c10
First c10's Avatar
Steering box view
GO GO!!!
Old 04-17-2016, 11:23 AM   #64
First c10
First c10's Avatar
Steering column installed. Any idea what steering wheel would look good in this truck?
GO GO!!!
Old 04-17-2016, 11:25 AM   #65
First c10
First c10's Avatar
Replaced heater control. Just not sure about the fan switch but everything is adjusted and ready to go.
GO GO!!!
Old 04-18-2016, 10:41 AM   #66
7dee2
7dee2's Avatar
Looking good great progress Scott! What does the boy say about the steering wheel seeing as he gets to look at it?
IMO, I'm old school fart and prefer the 3 spoke Chevelle wheel (slated for both my current project trucks) but have ran the Vega, Camaro, Chevelle 4 spoke wheel more often over the years. My old C30 daily is sporting the similar but later truck 4 spoke since I had it already and couldn't stand the boy racer wheel it came with which a buddy was glad to take off my hands for free!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-18-2016, 11:24 AM   #67
First c10
First c10's Avatar
Well he likes the 14" aluminum 3 spoke. This is what his brother has in his 70 c10.
That is why I asked the question. I wanted to know what others think that have been keeping track of my build thread.
GO GO!!!
Old 04-18-2016, 11:33 AM   #68
First c10
First c10's Avatar
This is my sons senior pictures. This is the first truck we rebuilt everything but paint and body work.
I like the picture because it has all the stuff he's into.
Hotrods/trucks
Motorcycles
Guns(California State Champion trap shooter)
Fishing(bass)
Just all around outdoorsman.
He will be attending University of Montana Western in the fall.
Proud dad moment.
GO GO!!!
Old 04-18-2016, 10:50 PM   #69
skyjgmc
Congrats to your son attending Western. Im from Montana (Helena) and this is the perfect state for an outdoorsman. Enjoying following along with these father son project build.
skyjgmc is offline   Reply With Quote
Old 04-18-2016, 11:19 PM   #70
First c10
First c10's Avatar
Thanks sky. I actually can't wait to retire as I am out of this state. We have family outside Missoula. Stephenville actually. Great state love the blue sky!!!!
I did have to add a vent line back to the fuel tank for the fitech injection command center. Probably could have save a few $$$ by custom configuring a I tank fuel pump. But decided I don't really have time. I am going to run the vent and fuel line 100 steel no hose(well maybe right at the command center connections.
GO GO!!!
Old 04-18-2016, 11:20 PM   #71
First c10
First c10's Avatar
Close up of the fuel sending unit
GO GO!!!
Old 04-19-2016, 10:11 AM   #72
7dee2
7dee2's Avatar
Nice work Scott and you should be proud for raising some fine young men!
Brett
Old 04-19-2016, 10:55 AM   #73
First c10
First c10's Avatar
Thank you Brett, I tell everyone my job as a parent is to set them up for success and its up to them to make the right decisions as adults. So far working pretty good. lol!
GO GO!!!
Old 04-20-2016, 12:58 AM   #74
First c10
First c10's Avatar
I got the vent line soldered up in the sendeing unit on the fuel tank. I ran it into the same grommet in the floor. I did wrap it in a peice of rubber so not to touch the tank but took the picture before.
GO GO!!!
Old 04-20-2016, 01:02 AM   #75
First c10
First c10's Avatar
Got the axle under the frame. The 90 axle under a 68 frame fit great. Just need to get it painted. I was not going to but now it looks old under there.
GO GO!!!
