Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-08-2019, 03:10 PM   #51
MONTE
MONTE's Avatar
Re: C20/cummins 12 valve
I hit up a transmission shop in San Diego. Guy had one in stock. I’ll try to find the name.
MONTE is offline   Reply With Quote
Old 05-08-2019, 03:45 PM   #52
projectking
projectking's Avatar
Awesome man, thanks!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 05-08-2019, 03:49 PM   #53
projectking
Is there a part number on it?
67 Chevy C10 LWB
90 Mustang Gt
Old 05-08-2019, 07:18 PM   #54
MONTE
MONTE's Avatar
Hope this helps you.
Let me try it this weekend to make sure it fits.
Old 05-08-2019, 07:39 PM   #55
MONTE
MONTE's Avatar
Wiring:
Would I need a voltage regulator for a cummins for the swap?
Which wires need to be connected to make this work?
Should I run the grid heater? Don't get cold in Texas.
On the 68 I have the following for the alternator.
Red
White
Blue
Black
On the starter side I have the following.
Purple
Black
Yellow
On the cummins I have the following on the alternator:
Big black
Green
Blue
Don't have anything for the starter or the injection pump/shutoff solenoid.
Name:  68 wiring.jpg
Name:  89 cummins wiring.jpg
Old 05-08-2019, 09:03 PM   #56
Madkidd007
Madkidd007's Avatar
Alternator you can run a Mopar external voltage regulator as a stand alone Setup like the old school applications did, or like mine I used an internal regulator conversion and all I need is one keyed hot wire to the alternator and it puts out 14.4ish at the alternator at idle. Starter solenoid run your original purple wire to it, fuel shut off solenoid on the injection pump just needs a hot in start/run. I have my original ignition source feeding mine as it draws little current. Besides gauges I literally have 3 wires going to my engine.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 05-08-2019, 09:12 PM   #57
Madkidd007
Madkidd007's Avatar
Starter and fuel shut off solenoid. I used my starter lug as my distribution block for my alternator, battery, and auxiliary take off to feed accessories and the cab, you can see the single purple solenoid wire. Shutoff solenoid is just a female spade terminal. My wiring is a little custom but the engine side will be the same. I planned on grid heaters hence the large gauge auxiliary wire coming off the starter, but in the low 20s mine still hit after just a couple seconds with a fuel heater delete also.
Old 05-08-2019, 11:16 PM   #58
projectking
The old school Mopar regulator made my lights “jump” a ford truck regulator will correct this
67 Chevy C10 LWB
90 Mustang Gt
Old 05-08-2019, 11:16 PM   #59
projectking
Attachment 1901945
Attachment 1901946
Attachment 1901947
Thanks, I’ll see what I can come up with.
67 Chevy C10 LWB
90 Mustang Gt
Old 05-09-2019, 11:23 AM   #60
projectking
Found it! Lmk if it works and if you have the contact info please.
Thank you,
Jon
67 Chevy C10 LWB
90 Mustang Gt
Old 06-04-2019, 09:26 AM   #61
projectking
Did you have a chance to install the mechanical speedometer drive?
67 Chevy C10 LWB
90 Mustang Gt
Old 06-09-2019, 10:25 AM   #62
MONTE
MONTE's Avatar
I was out of town for a few weeks but will be back on it this week.
Old 06-29-2019, 12:47 PM   #63
projectking
The vss screws into the part you bought and isn’t needed. I also bought one but could’ve just removed the vss and been done
67 Chevy C10 LWB
90 Mustang Gt
Old 06-29-2019, 03:47 PM   #64
MONTE
MONTE's Avatar
Sorry I couldn’t check it out for you “projectking”.
Little progress.
Old 06-29-2019, 08:10 PM   #65
projectking
All good. Nice progress!
67 Chevy C10 LWB
90 Mustang Gt
Old 06-30-2019, 11:15 AM   #66
MONTE
MONTE's Avatar
Little more.
Old 07-12-2019, 06:56 PM   #67
MONTE
MONTE's Avatar
Thumbs down Re: C20/cummins 12 valve
Not good.
Figured out why I couldn’t get it running.
Hopefully it’s not expensive.
“Chrome lever”
Old 07-12-2019, 10:10 PM   #68
Madkidd007
Madkidd007's Avatar
Not good.
Attachment 1918872
“Chrome lever”
That’ll do it for sure. If you decide to tear it down and fix it yourself I have a couple spare fulcrum assemblies. There are different numbers from the factory but I honestly don’t have a clue the difference. I remember one of the numbers being more prone to breaking and researched it when I built my pump but can’t rememeber which one I used. Future thought Incase you broke it putting the top back on, I usually back the power screw all the way out and then use a 6mm 1/4” drive with a swivel and extensions to get past the fuel lines to run it back in. I know it’s not a proper place to “sale” but if you need one I’ll send you one for $10 when it’s time.
Be warned it is easy to mess up and destroy internal pump parts if you don’t put things back in just right and then you’ll be looking for more parts or another pump. I’ll admit my first time I broke my rotor and since then always know for sure it’s all just right before install.
Old 11-08-2019, 12:04 PM   #69
MONTE
MONTE's Avatar
Hydro boost
Will this work for me? Gmc van
Old 11-08-2019, 02:57 PM   #70
Madkidd007
Madkidd007's Avatar
Hydro boost
Attachment 1956352
Attachment 1956354
Don’t think so with that combination and your intake pipe. I moved my intake forward using a 24v plenum plate. Are you just wanting the better stopping power or is the vacuum pump not working?
Old 11-08-2019, 03:00 PM   #71
MONTE
MONTE's Avatar
Need that stopping power.
Old 04-27-2020, 07:36 PM   #72
jarrodblake
jarrodblake's Avatar
I was wondering if you ended up using this hydroboost setup? I have the same one on my truck. I am still looking for a different master cylinder. I was wondering if you ended up using a different master if so what did you use?
jarrodblake is offline   Reply With Quote
Old 01-01-2021, 09:06 PM   #73
MONTE
MONTE's Avatar
Sorry hadn’t been on the site for a while. Moving and building a house and shop.
Old 01-01-2021, 09:23 PM   #74
MONTE
MONTE's Avatar
It’s been a minute.
Got busy moving, building a house and shop.
Back to working on it.
Not sure about body work.
Might just get it blasted.
Old 01-01-2021, 09:24 PM   #75
MONTE
MONTE's Avatar
And the new shop.Name:  image.jpg
