06-24-2022, 10:27 PM | #51 |
Re: Noob with a daughters project
Yeah.
Just searched a video (real}Quick before I left for work that morning BBC and SBC have a lot of the same dimensions
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 06-24-2022 at 10:32 PM. |
06-24-2022, 10:33 PM | #52 |
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-24-2022, 11:16 PM | #53 |
Ok, y'all inspired me.
I'm going to test the compression to make sure that's still good. Anything else I should check before I'm up to my elbows in education? I just bought David Vizard CBB engine book from Amazon about rebuilding. Thx all for the encouragement and perspective! Last edited by lintcollector; 06-24-2022 at 11:26 PM. |
06-24-2022, 11:25 PM | #54 | |
06-25-2022, 12:20 AM | #55 | |
AND, to perhaps inspire some confidence, I did a cam swap tonight on my 383 SBC! so, timing set off and back on, pulled the intake, swapped camshaft and lifters. It's on its way back together! I left the rear two oil pan bolts in, but loose. Removed the rest. Only two required a wobble socket extension to get around crossmember. The pan dropped JUST enough that I could pull the timing cover off. I haven't removed headers, engine mounts, or even front accessories, aside from the serpentine belt, water pump, crank pulley and harmonic balancer. I've been at it for about 3 hours, and will have it all buttoned up, ready to fire in about two more hours. It's REALLY not a difficult job! And, even if you had more issues that surface after the swap, your only out an evening and some cheap parts. I've done the same to the 434" BBC in my '68 GMC. No issues. Good luck! Post pictures! Nik
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
06-29-2022, 12:55 PM | #56 | |
John 3:16 - Saved me... God Bless |
07-16-2022, 03:10 PM | #57 |
Lint, how goes it???
Your thread was about to roll off the front page, didn't want to loose track of you!!! |
07-17-2022, 08:57 AM | #58 |
Keep it going brother you got this
07-17-2022, 05:41 PM | #59 | |
I'll get to going through the book and then find an engine hoist/mount and tear it down. Thx for the follow up Posted via Mobile Device |
11-27-2022, 10:29 PM | #60 |
Ok, so she's off to college and we're needing to try and cash out the truck, which is still rough. Where's the best place to try and recoup the $4k I'm into this little gem?
It's a sad day here for sure and I don't have the time or $$ to keep pushing forward. 😢 Posted via Mobile Device |
11-27-2022, 11:04 PM | #61 |
I would suggest Subscribing for $25.oo
Then post an add to sell here on the Forum. Link to sell : https://67-72chevytrucks.com/vboard/...splay.php?f=76 I my opinion this would be the best money spent.
