View Poll Results: What style on the exhaust. | |||
Quiet turbo style mufflers(doubtful) | 3 | 27.27% | |
Borla x series(good sound but not obnoxious) | 5 | 45.45% | |
Chambered(flow master, thrush type) | 2 | 18.18% | |
Online chambered/dimpled style(60s/70s muscle cars) | 1 | 9.09% | |
Multiple Choice Poll. Voters: 11. You may not vote on this poll |
01-01-2021, 02:10 AM | #51 |
Re: 1965 Lincoln, need I say more?
And here's the madd fabricator hard are work. Hahaha
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
01-01-2021, 11:11 PM | #52 |
And the motor is back in for the last time, had to clearance the rear brace of the oil pan to clear the steering linkage. I’ll get the transmission in tomorrow and then I can start adding everything to make it actually go. On a positive note, which was my goal with doing the motor mounts the way I did it looks like a stock low mount ac compressor will have more room than in a TBSS and possibly more than a truck.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
01-02-2021, 08:13 PM | #53 |
Look what stopped by to visit the Lincoln.
01-03-2021, 10:24 PM | #54 |
And the TBSS ac bracket and compressor that josh gave me as a spare for my daily, well it’ll work great for the Lincoln. Gotta love stock parts in stock locations. Bonus I can run the stock GTO oil dipstick as it just clears the rear of the ac
01-10-2021, 05:19 PM | #55 |
So the alternator has been a bit of an issue since the setup is designed for a 105 and I’m going to run a 145 amp. Passenger exhaust is in with the drivetrain in its final position, ac compressor is fully bolted now, dipstick situation taken care of. She’s coming along.
01-19-2021, 11:56 PM | #56 |
You and the Jeep/Trailblazer guy are both mad scientists! Cool builds....both of you! I've been helping my son with his '66 Lincoln. At this point I'm going to say.....be glad you didn't stick with the old MEL engine. My son's is the 462 and we've been a few months now trying to get pistons in a .030" over. Finally having a custom set made by Ross Racing. These are just really cool old cars.
01-20-2021, 11:45 AM | #57 | |
01-20-2021, 12:08 PM | #58 |
Egge was several months out on 'correct' pistons and as of the past few years I've run across several bad reviews of the piston quality.....like pistons breaking! Decided not to take a chance. The new custom pistons will be the correct shape but in a new 9.75:1 compression.
01-23-2021, 09:29 PM | #59 |
low n' slo
ive always wanted one of these old Lincolns...nice ride
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-24-2021, 12:05 AM | #60 |
01-30-2021, 11:19 PM | #61 |
Sedans are still in “decent” price territory. The real problem is the price going up because of the few crazy sells that have happened. People will buy them with no research, and then any parts are 2-5 times the cost of any other classic and then people can’t afford to fix them. Real tricky cars if they aren’t complete or you want a proper restoration.
05-10-2021, 08:34 PM | #62 |
Not much has been going on, another family vehicle was given to me so the Lincoln didn’t get much done. That and I was waiting until I started at my new job before I bought any more parts. But here is how it sits now. Still have ac lines to deal with, fuel system, driveshaft, ecu/harness. I’ve never been one to make my engine bay “look good” so as you can tell it’s purely function.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 05-10-2021 at 08:39 PM. |
05-10-2021, 08:57 PM | #63 |
Post Whore
Looks good..!!...almost like it was meant to be..
05-10-2021, 10:10 PM | #64 |
Thank you. That’s what I always shoot for, not fancy but when you look at it you say did it come that way?
05-13-2021, 02:51 PM | #65 | |
Glad to hear an update on yours......tell me about this master cylinder I see. |
05-13-2021, 07:54 PM | #66 |
It’s a master/hydroboost combination from a gmt800 series. Had to make a 2” spacer and drop it down 1” to line up with the factory pedal height and still has full travel, lucky me I have the setup in my c10 also so I could just compare my travel.
05-13-2021, 09:09 PM | #67 |
Aahhh, big truck hydroboost. Got it.
05-13-2021, 09:53 PM | #68 |
Big truck weight and horsepower. I have the intent of upgraded the front discs to late model grand Cherokee rotors and GMt900 calipers
05-30-2021, 09:38 PM | #69 |
Slow progress as the factory tank was garbage. So I hammered an 04-06 gto tank to match the hour glass Lincoln’s tank. Then put an aftermarket Ford fuel sending unit on the original pump module for the gto tank. Now I don’t have to worry about sealing wires coming through a tank and if my pump ever dies I can do just a pump or another gto module and swap the upper half of mine to a new unit
06-12-2021, 02:11 PM | #70 |
Forgot this picture. Haven’t messed with the car again. Been doing painting and tree cutting around the house.
09-11-2021, 06:32 PM | #71 |
Clearly there hasn’t been any progress on the Lincoln. It’s still sitting in the same spot in the garage. I ended up with the family truck finally, so it has been taking precedence since it’s more sentimental. So here is what it’s going to be a Cammed and Carbed 5.3, T56, All wheel drive, and 3.73 gears. I also have a Sonoma GT body kit, and complete interior for it. Then maybe I’ll get back to the Lincoln after
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 09-11-2021 at 08:31 PM. |
09-12-2021, 08:16 PM | #72 |
How about a family truck build thread? We can pick the Lincoln back up with you afterward.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
09-12-2021, 11:36 PM | #73 |
Not really gonna be a “build” just throwing some parts together that I’ve had stashed away.
12-30-2021, 05:32 PM | #74 |
Alright so as typical with me I did some more jumping around. I had been buying up parts for all of my vehicles including the c10 that is now officially a k20 with trailing arms and a gmc front end. Once I had all the doors and fenders I decided to get those painted, put on the truck and get the suspension wrapped up. It works out better with the 37s for the cummins since it has 4.10 gears. Josh aka gottattooz is going to get me an auto leveling air valve for the rear, once I put that on I’ll be able to have the rear height I want and be able to dump it to get in and out of the garage. It sits dead bits level now and rubs the rubber going in the garage, but I want it higher in the rear as to not be confused with these stupid squatted trucks running around. I most likely won’t do any more paint work till spring so the lincoln is on priority again
12-30-2021, 05:36 PM | #75 |
As for the Lincoln, I pulled the cover off of it and back at it. I figure it’ll take less time to get this thing drivable but not done than the s15. The goal is to sell my suburban while the market is still hot but as of now it’s my only backup if I break the c10, I figure a 2500 burb shouldn’t be too difficult to sell down here in the south. So I didn’t do the picture thing but I built and installed the new 9” with 3.50 gears and a truetrac, should be able to sell the original Lincoln 2.89 posi to offset some of it as you can’t buy any 9 3/8” diff parts.
