02-27-2024, 11:36 PM | #1 | |
Re: Radio options
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
03-05-2024, 07:27 PM | #2 | |
Re: Radio options
03-07-2024, 01:14 PM | #3 |
Re: Radio options
I added a couple of Kenwood 6x9s in boxes under the back seat to give it a full surround sound and to keep it a secret audio "so to speak".
03-07-2024, 02:49 PM | #4 |
Re: Radio options
I got those same speakers. Specs say they go down to 70Hz, and they do sound nice and full. Way more than I need for the inside-of-an-oil-drum listening environment of my cab
1970 C10 Custom longbed 350/350 |
03-24-2024, 11:06 AM | #5 |
Junior Member
Re: Radio options
Hello, I have a question. I would like to just run an Amp like that Rockville and Bluetooth it to my phone.
I have 4 speakers going in to in the rear and to in the doors. So , is there anyway to adjust the Speakers for front to back and side to side ? I like the look of the radio delete, so something hidden is the way I would like to go. Thank you, Dan |
02-28-2024, 03:13 PM | #6 |
Re: Radio options
I got one of these to play with, $10 on the River
Going to leave the AM unit unattached for the moment, but I'd like to wire up the 2 4Ω in series(8Ω load) on an alternate switched circuit so I can still use it once in awhile
03-06-2024, 05:14 AM | #7 |
Re: Radio options
Well since I already used the space for the radio as the home for my switch panel, I thought, "What could be more 70's than mounting the head unit under the dash?" So, that's what I did. I still listen to cds. ****, I still dust off my cassette tape collection from time to time. Still sounds a damn sight better than streaming over Bluetooth. This radio is Bluetooth capable, but I prefer the USB or AUX ports and stored media, as the sound quality is much better. Then the signal is ran to a skar 500w 4 channel amp. The heft of the signal is handled by the 5.25" speakers on the doors. I couldn't justify spending $90 on a couple pieces of plastic to mount the woofers in the kick panels just to be... well..... kicked, so I fabbed my own damn mounts. The next two channels drive a pair of DS18 3" super tweeters mounted in place of the ball vents either side of the dash. Finally, in an effort to increase the width of my sound stage, the head unit is driving a couple 2.5" speakers I yanked from a surround sound system that i mounted in the center of the dash. Overall, it sounds pretty good considering i threw it together with **** i had laying around. It could use a sub. All in due time.
Yea, just goes to show, when it comes to these trucks, all that limits what you can do is your budget and your imagination.
1972 Cheyenne, 350/th350 12bolt posi, shift kit, 262 Craine Cam, Pertronix HEI. "When the power of love overcomes the love of power, only then will the world know peace." "Who are you people and where is my horse?" |
03-24-2024, 10:27 PM | #8 |
Re: Radio options
I thought you were talking about my bluetooth receiver.
03-25-2024, 10:07 AM | #9 |
Junior Member
Re: Radio options
I appreciate the response. Usually a radio will control the speaker functions and the Amp was used just for additional power.
With the Amp with Bluetooth I guess all the sound is equally disributed to the 4 speakers . I haven't purchased anything yet, and did not know a phone could control some of the speaker functions ? I recall back in the day adding a fader switch to a stereo system, but this is different without the radio. Hopefully someone has done something like i'm wanting to do. Thank you |
04-14-2024, 02:46 AM | #10 |
Re: Radio options
Finally got a wiring diagram done for my layout:
4Ohm load from the BT device wired in parallel 8Ohm load from the AM radio wired in series(hence the jumper from pin 6-9 at the switch) I used kicad(for Mac) to make this diagram ICYGAS
1970 C10 Custom longbed 350/350 Last edited by Rust_never_sleeps; 04-14-2024 at 03:02 PM. |
04-14-2024, 03:13 AM | #11 |
Re: Radio options
A tip for anyone installing speakers. For the best performance and sound quality. You always want to seal the front of the speaker from the back. Leaving the grill open around the speaker or leaving air holes around the mounting baffle will kill mid and lower frequency's. Many car speakers are meant for "open baffle" Meaning they need no enclosure or a large one. Understand that sometimes people do not have the means for that and there will be a compromise. The front of the speaker still needs to be separated from the back for best sound quality.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
