Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 11-27-2019, 12:04 PM   #726
HeavyHauler
Re: D52 Caliper Rear Disc Brake Brackets
Does anybody know if you can get the 1992-2002 Astro Van rotors in cross drilled and slotted or even just cross drilled?
HeavyHauler is offline   Reply With Quote
Old 11-27-2019, 03:46 PM   #727
HeavyHauler
Hey could you change my order to the Camaro caliper adapter kit in black powder coat. It seems the parts for that kit are more readily available over the counter.
If you could also include one of your Power Brake Booster Adapter brackets for 1967-1972 Chevy C10 also in black powder coat?
I hope that you can make these changes to my order. I would appreciate it.
I also PMd you about the changes.
Old 11-27-2019, 10:33 PM   #728
Captainfab
60-66 Nut
The drilled and/or slotted rotors have been discussed ion this thread. Those part numbers are included in the parts list that is included with every bracket set
I replied to all of your PM's that you sent today.
Old 11-29-2019, 05:05 PM   #729
HeavyHauler
Does anybody have a actual part number for drilled and slotted rotors for 1992-2002 Astro/Safari AWD vans?
I checked Rock Auto and they dont show anything like that. It was mentioned here in this thread on page 23 but nobody posted a part number for them.
Old 11-29-2019, 11:25 PM   #730
Captainfab
60-66 Nut
Here is one of the sources from the parts list that comes with every bracket set as I stated above.
https://www.summitracing.com/search/...SPH-127-66022R
https://www.summitracing.com/search/...SPH-127-66022L
Old 11-30-2019, 11:39 AM   #731
HeavyHauler
Awesome and much appreciated.
Please just keep my order as I originally stated with the powder coated D52 rear disc caliper bracket kit for my 1968 Chevy C10 with the 12 bolt rear and conversion axles.
Old 01-11-2020, 11:35 AM   #732
Cash3481
Loves all GMC trucks
Cash3481's Avatar
I need a set of rear disc brake brackets for my 72 GMC 1/2 ton. Please send me an invoice to mcastillo3481@gmail.com I’ll get you paid ASAP. Thank you In advance
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 01-11-2020, 10:47 PM   #733
Captainfab
60-66 Nut
I sent you a Pay Pal invoice.
Old 01-12-2020, 01:29 PM   #734
Cash3481
Cash3481's Avatar
Payment sent!
I really appreciate all the things you provide us as a group!
Mike
Old 01-12-2020, 09:56 PM   #735
Captainfab
60-66 Nut
Payment received. It will be later in the week before I will get to your order. I have several orders ahead of you plus we are getting hammered with snow here. Saturday it took me 4 hours to clear my driveway at home. Then today I spent 3 hours on a backhoe at my shop and more snow is coming.
Old 01-14-2020, 02:39 PM   #736
HeavyHauler
Just assembled my rear D52 rear disc brake kit on my 1968 Chevy C10 SWB and the brackets seem to fit ok, but when I put on the D52 calipers and pads they fit on very snug and the rotor is very difficult to rotate by hand when installed. The D52 calipers are brand new and so are the pads. The piston is all the way retracted into the bore also.
Anybody else run into this and how did you solve it?
Old 01-14-2020, 10:13 PM   #737
Captainfab
60-66 Nut
Are both pads rubbing hard on the rotor or just one side. And is this the same on both sides of the truck?
Old 01-15-2020, 12:37 PM   #738
HeavyHauler
Both pads are rubbing and it is the same on each side of the truck.
Stop Tech Rotors: 127.66022R & 127.66022L
D52 Rotors from Autozone
Raybestos Pads
I am using Motive Gear 6569 Conversion 5 lug axles and they measured 30 1/8 while the stock axles were 30 1/4.
Could the axles be the problem?
Old 01-15-2020, 12:42 PM   #739
HeavyHauler
[QUOTE=HeavyHauler;8660229]Both pads are rubbing and it is the same on each side of the truck.
Raybestos Pads
I doubt the axles would be the problem though because there is no gap between the rotor and brake pads on the left or right side of the truck.
Old 01-15-2020, 12:44 PM   #740
HeavyHauler
Old 01-15-2020, 10:39 PM   #741
Captainfab
60-66 Nut
It sounds like the issue is either the rotor thickness or the pad thickness.
I would suggest measuring the thickness of the rotors with a calipers. Another option would be to measure the thickness of a set of D52 pads from a different store and compare them with what you currently have.
Old 01-16-2020, 11:25 AM   #742
HeavyHauler
I will caliper measure the rotors and the D52 pads to compare them with another set and see what I find. Tolerances always seem to vary between manufacturers. I appreciate your feed back!
Old 01-20-2020, 04:03 PM   #743
HeavyHauler
I had time to mess with it today and I did find out that when I remove the D52 caliper from bracket and I try to slide just the inner pad in between the bracket and the rotor I noticed that it is a tight fit but it will go in by hand.
These are the measurments that I got.
Stoptech Rotor R=32.81 and L=32.83
Raybestos Pads 15.28 and 13.80
Duralast MKD52S Pads 14.59 and 13.17
When I put the Duralast pads on it was just a little less drag but not much Also with the Duralast pads the outer pad made contact with the hub on my rotor while the Raybestos pads did not do that.
Old 01-20-2020, 10:55 PM   #744
Captainfab
60-66 Nut
Are those measurements in MM? I will have to go and convert them to imperial measurements.
Old 02-09-2020, 05:34 PM   #745
Frostflowz
Interested in this, however I am in canada. Curious what it might cost for shipping to edmonton alberta canada? Thanks sir
Frostflowz is offline   Reply With Quote
Old 02-09-2020, 10:34 PM   #746
Captainfab
60-66 Nut
Due to the weight of this bracket set, it must ship in 2 boxes when shipping international. The shipping cost to Canada will be $108.00 USD
Old 02-12-2020, 10:44 AM   #747
johnrcook
I am new to C10 ownership and to the forum. I am very interested in your brackets for C10 rear brakes. Is there a number or email address in which I can direct my questions?
thanks,
john
johnrcook is offline   Reply With Quote
Old 02-12-2020, 10:44 PM   #748
Captainfab
60-66 Nut
Send me an email to captainfab454@hotmail.com
thanks,
john
Old 02-24-2020, 01:09 PM   #749
Jrgunn5150
Payment sent for a set of raw brackets from JRgunn4786@gmail.com
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 02-24-2020, 11:06 PM   #750
Captainfab
60-66 Nut
So you are the one that sent me a payment with absolutely no info as to what the payment is for and also no address to ship to?
