#726 | |
Re: Project '64 Cheapskate
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#727 |
Love this truck....it belong on the Bonneville Salt flats as a Pusher
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#728 |
Subscribed!!!!!!!!!!!
64 LWB to SWB Step build. Daily driven! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
#729 |
![]() Join Date: Jan 2015
diggin those tucked lines!
#730 | |
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
#731 |
awesome work and great ideas, thanks for sharing.
12:30 am here in the hotel and a meeting in the morning. I dont think everyone will understand "I was up late reading about a guy restoring an old chevy truck in CA" LOL well worth it in my book! |
#732 | |
#733 |
![]() Join Date: Mar 2005
I am on it! I have been doing a bunch of work on it each night after work, but I have not been keeping up with progress shots. I have been finishing up the last of the AC lines and the heater hoses. I have been working on whatever I can. The weather has been really crappy the last couple of weekends, but I have been doing work on the smaller items that I can do inside the garage where it's a whole lot warmer. The "To-Do" list is getting smaller!
Still need to route the taillight wiring, finish up the underdash wiring, finish the mods on the radiator shroud, make positive and negative battery cables, make the spark plug wires, install u-joints in the rear driveshaft, ........ok, I'll stop there. Still a lot to do, but it's a culmination of a lot of small jobs. Unfortunately, they are the ones that cost the most money and aren't fun.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#734 |
We'll be ready and waiting on you.!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#735 |
1961 crewcab
wow! just went through this whole thread, read/skimmed about a 1/4 of it, gonna have to check back a few times, lots of great tricks!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#736 |
One of the best for sure...!
#737 |
Subscribed! Can't wait to see some progress pictures!
'71 Chevy C10, 250 straight six, 3 on the floor, long bed '70 Plymouth Duster, 340 small block, 4 on the floor, 3.55 ratio 8 3/4 rear "Rust is a major food group." "Burn 'em if you got 'em." |
#738 |
Alex.... are you out there?
#739 |
I am! I've been working some insane hours for the past 3 months, but I'm working on the '64 as much as I can. I've got a LOT of stuff done, and I'll post up pictures soon.
I need an upper radiator bracket for a V8 radiator. Anybody got one they want to sell? It doesn't need to be pristine, I need to use it for parts.
#740 |
Glad to see you are still gettin at it. Can't wait on pics.
#741 | |
Posted via Mobile Device |
#742 |
Good to hear from ya!
#743 |
Been doing a lot of little jobs on the truck when I have the free time, and this weekend, I pulled the entire front suspension back apart for final installation and detailing. Everything on the front suspension is either new or rebuilt. I also built new brackets and mounted the trans cooler. It's big, kind of overkill, but it was an extra that I had laying around and I put it to use. It's mounted under the core support and tucked behind the bumper, so it's in the airstream but still protected. Also mounted the swaybar (1.25"). All the bushings are polyurethane throughout the suspension. It was a very productive weekend.
#744 |
![]() Join Date: Jan 2014
Looks great, Alex!
#745 |
Rollin' Old Skool
Good to see some new progress pics!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#746 |
Oooooooh an update. Thank you sir.
#747 |
This weekend's progress
The new aluminum radiator did not work with the upper bracket that I had previously modified for the original copper radiator, so I bought a used bracket from a member, Jonzcustomshop. I needed to gain an additional 3/8" in height, so the best way was to splice my original bracket and the one I got from Jon. ![]() ![]() ![]() I will sandblast the part and do a little body filler on it, and it'll look like a factory piece when it's finished. I have spent a lot of time modifying every part on my truck to look like it came that way from the factory. .....and nothing has been left untouched. I also cut and trimmed the radiator upper radiator rubber seal. It turned out really nice. ![]() Still lots of little stuff to do!
#748 |
Thank you for the update. No matter how big or small!
#749 |
![]() ![]() Join Date: Jul 2002
#750 |
Oooh, pretty stuff! Thanks for the update. Aiming for October? (cough, cough)
