#751 |
Re: Post Your Straight Six Pics!
Bad part is, we live in Florida, so he could drive it year round. He has the suspension set up properly with adjustable coilovers on all 4 corners and the truck will respond in all conditions. For the amount of $ he has in It I'd be driving it everywhere and all the time. I'm working on a 70 c10 long bed and would never consider not being able to take it every time I leave the house. Granted, i don't have the money invested that he does yet. I give him he'll about it all the time.
#752 | |
What I may do is put in some studs on the ends and just not put the nuts on. Definitely some good advice. Now for the ignition, I have never heard of anything with a .070 gap, that's impressive. Outside of the obvious, what are the pros and cons of a large gap? My poor truck sees all of the extremes from highway speeds for days at a time to pulling some CDL qualifying loads.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
#753 |
Not eye candy by any means, but here is the 292 out of my 68 C-20 . . .
1998 Chevy Tahoe 2D 1949 Willys CJ2A 1967 C-20 Flatbed (Sold) |
#754 |
![]() Join Date: Feb 2002
What Nate says may be true for stock cast iron exhaust manifolds, but threaded studs [3/8''-16 -- 3/8'' -24] with a nut and a support are necessary for steel tube headers. Otherwise they leak bad. I use a hardened steel rocker ball for a spacer. Works for me.
Cervantes was a Spanish Marine. He was captured by Barbary Pirates and held as a POW [slave] for 5 years until his folks and The Church paid his ransom. He started writing after he got back to Spain.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-17-2018 at 09:17 PM. |
#755 |
Whoops ! you're correct, tube headers often (not always) work better with fasteners on the ends .
It's still critical to tighten the whole mess from the center outwards, not any other way . When the GM HEI was new they spec'd .065" on the spark plugs, we thought it was crazy but they started and ran so easily in the sub zero temps Down East.... The changed that after a few years but running .045" minimum is wise . The only downside I've ever experienced is accelerated wear on the caps, rotors and wires...... The plugs proper wear a bit faster but no biggie . I hope everyone here knows to never use platinum tipped spark plugs in older engines ! . They run colder and cause fouling problems quite often . I think that 1968 292 looks great ~ those who work and drive these old rigs daily (more common than most realize) know how sturdy they are and if you keep up on the routine HOT OIL & FILTER CHANGES the thinwall bores don't wear out much . All through the 1960's and 1970's there were millions of GM products with thinwall (1963>) i6 engines that blew smoke and drank oil, this was caused by owner failure to properly maintain them . The previous generations of GM i6 engines could be overhauled with massive (up to .016") taper in the cylinder yet run fine and not smoke . @Dwyert : who knows ? maybe one day he'll tire of it and sell to you for an affordable price .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#756 |
I wish. Actually I think he's giving it to his son when he turns 16. That's one helluva present.
#757 | |
![]() Thanks for the tip.
#758 | |
That said, I always thought Cervantes wrote don Quixote de la Mancha while he was in prison. Just the same, it was required reading in my Spanish class back in high school and it turned out to be one of my favorite books to this day.
#759 | |
There's a reason I love this site. The overall wealth of knowledge is astounding!
#760 |
I didn't either, good to know. I just regapped mine to .055. It ran well for the half mile I got to drive it today. Funny story though, I ordered my plugs when I ordered my headers from Tom Langdon. He sent me a set of Champions with the gasket but I pulled out some version of R44. XS or something like that. Mind you, I do think the head of this engine I just had built was from a later year as it has the holes for the AIR system which I plugged. What does he know that I don't?
#761 | |
I looked for a snap of that rocker ball in hole #1: Looks like I can't find any pix. All I get are icons of little tan file folders. EDIT: Here it is. First manifold hole in L6 head filled with a 3/8''-18 bolt and rocker arm half-ball as spreader securing a set of Clifford headers on my 292 L6. [Also a similar fastener at the end.]
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-20-2017 at 10:54 PM. |
#762 |
Don't think I know much , the more I learn the more I realize how little I actually know .
Our Christmas present came early, on 12.19 we got dispossesed .
#763 |
![]() Join Date: May 2017
Here is my Mercruiser marine motor fresh off,I mean out of the boat. My version of a IL6 conversion! And it's not for sail!!!
#764 |
I was wondering if the big brake booster would clear the air cleaner. I'm assuming that is a 6". Where did you get the filter?
#765 |
RW: Points or Pertronix?
#766 |
![]() Join Date: Dec 2013
Here's a factory L6 A/C Bracket on this 292
#767 |
Here are a couple more 2-250's and another 292
#768 |
The filter is 6.5 inches diameter .picked it up at O'Reilly's.It misses the booster by about a quarter inch.The breather top was the factory one for the Merc motor.
#769 |
Pertronix
#770 |
Good to know. I have the little booster and i always thought it was strange on a 3/4 ton but it's not broken so i haven't fixed it. When it does break, I'd like to put on a big booster but it's been hard to find both 6" or the 9" I need. It's hard around here to find any round air filter for that matter.
#771 |
Who Changed This?
![]() Join Date: Jan 2013
That is hella cool!
#772 | |
Who Changed This?
#773 |
this is my fully rebuilt 292 which will be started and have the cam run -in with 2-barrel holley and then have the supercharger put on.
will be building my own inlet manifold and exhaust headers.
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
#774 |
Nice set up. Kind of a retro looking generator. Not the usual 67-72 Delcotron alternator. What year is your truck?
#775 |
69 but this is a bitsa motor and generator may be from v8. pickumup came in with 250 mtr in an when it died I found this mtr (very difficult) and got it fully reco'd.
