01-01-2016, 03:31 PM | #776 | |
Re: 1976 Square "Simple Green"
I missed this post all together. I thought your battery wire was going to the junction block and then down to the starter, not the other way around. I'm no electrical engineer or wiz kid either, so is it possible that when your cranking the engine over that the starter is interrupting the power going to the junction block? As in is it sucking power (amps or volts) and keeping it from the junction block? Then again, that wouldn't explain why it's stalling out after it starts. unless it's then getting full power and it "rests"?? God, I feel like I'm talking out of my ass If you do the test of running dedicated wires to the battery and it works, verify that it's not because it needs both. If it does need both I would run a wire to the junction block and then from the block to the starter. |
01-01-2016, 03:50 PM | #777 | |
01-01-2016, 03:59 PM | #778 |
When I get back home I am going to run it straight to battery power and ground and test it. We shall see...
01-01-2016, 04:00 PM | #779 | |
I'm not saying that it's the problem, I'm still thinking grounding is the problem. Just brought it up so you can double check it and in case we do get an electronics guy in here and maybe he can say something for sure. I don't want you have problems down the road after you spent all this time fixing this issue. Plus look at it this way, if you need to run the battery cable to the junction block. You can run it along the fenderwall and down to the firewall all in black sheathing to give it a cleaner look. (trying to put a positive spin on it ) |
01-01-2016, 04:02 PM | #780 |
01-01-2016, 04:09 PM | #781 |
Ray here.
Mine would stall about two minutes after I removed the charging cables at idle. I don't think this has any thing to do with yours.. I believe you are stalling shortly after the start?If it starts? Im heading out back to swap body's than maybe the chip to see if mine idles better After I take the **** battery back out... Maybe I will do the chip first! I really just need to go home......NOPE....wife is sewing don't want to even enter the house when that's happening. Ray. |
01-01-2016, 05:39 PM | #782 | |
01-01-2016, 05:40 PM | #783 |
01-01-2016, 06:39 PM | #784 |
But Found Her 25yrs Later!
Anxiously waiting to see if the direct wires do the trick.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-01-2016, 07:38 PM | #785 |
Ray here.
After 28 posts can I start calling you RG10 ? But in all seriousness I have not read this thread post to post... I bore easily. Have you done a voltage draw? to see if that's what your working against. and not some built in problem..It can happen.... On the controller.....Not that's its the best meter for this....... Go to large gauges... click down to battery voltage and bring that up.... Try to start it and see what you get.. you my have already done this...I don't know that it would mean anything. But what the hell. Ray. |
01-01-2016, 09:24 PM | #786 |
01-01-2016, 09:25 PM | #787 | |
And yes I have. Short so you don't get bored. Lol. |
01-01-2016, 09:53 PM | #788 |
I really hope adding direct connections to the battery positive and ground solves your problem...
I am no electrical engineer and I know you are focused on the voltage. ...but the power formula P=IxV...tells us that even with an equal voltage of 10.5 volts at the starter and the distrobution block...that if the computer or injectors are not getting enough Power. ..watts...due to not being able to draw enough amps...then no go....looking at your diagram of how you have the positive wired...I am assuming that you are using a heavy cable to the starter and a light wire to the distribution block...and we all know that when cranking that the starter can draw hundreds of amps....and maybe that is not allowing the necessary Power to get to the distribution block...and maybe a direct connection to the battery will.... I keep trying to apply the old fire hose analogy..but can't seem to articulate it....just trying to help eliminate items with you.... I do recall when I was running am old powerjection system on another car...having similar issues that were solved when directly wired to batt + & -... I hope it works for you (and the rest of us with units on order)...so you can stop pulling your hair out....
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510 |
01-01-2016, 09:58 PM | #789 | |
01-01-2016, 10:02 PM | #790 |
Ray here.
Can you shorten up that last post i barely got to the end. Ray. |
01-01-2016, 10:09 PM | #791 | |
01-01-2016, 10:15 PM | #792 | |
Sure...add wires...tell us if it works...
01-01-2016, 10:17 PM | #793 |
A read on fuel line/hoses.
http://www.hotrod.com/how-to/engine/...ce-fuel-hoses/
01-01-2016, 10:17 PM | #794 | |
I would start with just stringing an extension for the positive to battery...then negative...??
01-01-2016, 10:25 PM | #795 |
I will test it tomorrow and let everyone know. I am getting tired of dealing with this. I want to move on to my next install my tranny. Then my c notch. Then interior. And maybe just maybe if every goes my way which it probably won't a supercharger hahaha!!
01-01-2016, 10:28 PM | #796 |
I will say this never had this much issue with a carb the MSD or the Holley. But with saying that I still like the FiTech the best out of all of them if I can get this ***** to fire up cold I will be golden.
01-01-2016, 10:30 PM | #797 | |
Maybe you could wrap a nitrous bottle warmer around it...😂
01-01-2016, 10:36 PM | #798 |
01-01-2016, 11:28 PM | #799 |
Just came across this on a corvette forum....I know u have good grounds...just more data...
"...... After all was running great, I started having issues starting the car when it was cold. I noticed that the display would go blank or go blue when I tried to start the engine. After talking to Ken, he said that was a ground issue. After looking around for the grounds, most had been removed (exhaust, starter to engine). Since the TBI unit uses the engine as it's ground, the injectors weren't firing. I went ahead and added some engine ground straps and it started right up. Lesson learned: Make sure you have good grounds!....."
01-01-2016, 11:39 PM | #800 | |
