Old 02-19-2021, 01:26 PM   #776
beaterku
beaterku's Avatar
Re: 1971 Stepside LS Build
Hey hey, glad you figured it out.
beaterku is offline   Reply With Quote
Old 02-19-2021, 02:02 PM   #777
Wiekser
Wiekser's Avatar
I've had the exact same issue with my new horn switch.
Took me some time to figure out it was that tab
Sander
All Ideas, advice, critisism is welcome. Nothing better to learn from.
______________
'72 C/20 http://67-72chevytrucks.com/vboard/s...d.php?t=809053
Wiekser is offline   Reply With Quote
Old 02-19-2021, 06:39 PM   #778
TA_C10
TA_C10's Avatar
Originally Posted by 1971Stepside View Post
Now to figure out why the steering wheel won't sit closer to the column.
Glad you got the horn issue fixed.
Question on your column. Is it an aftermarket or reman unit? It looks like it is an issue with the shaft. Too long. Check out this thread:.
http://67-72chevytrucks.com/vboard/s...d.php?t=787782
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-22-2021, 10:19 AM   #779
1971Stepside
Almost Satisfied
1971Stepside's Avatar
It is a van tilt column that I purchased from a member here. I don't think it is the shaft, but I could be wrong. I will mess with it after the alignment since I'm sure the steering wheel will have to be adjusted after that.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-22-2021, 10:27 AM   #780
1971Stepside
Almost Satisfied
I did a lot of research on the fancy hood hinges, including talking to others at shows. I felt like $800 was just too high for hinges if they didn't really add something besides looks. I had one guy tell me that he wish he had purchased the CVF hinges instead of the Ringbrothers. I had never even heard of them until this point. After reading about them I felt much more comfortable taking a chance on a $575 hinge that I did and $800 one.
My first impression was that they looked well built and heavy enough to handle the metal hood. We got them bolted in this weekend and I was afraid they would take hours to get right due to all the adjustability that they have built in. I was wrong. They bolted right up and adjusters actually do adjust the hood with little input. Very happy with how the hood operates now. Goes full up and they also look nice. No raised hood in the back!! Hope this helps others on the fence about hinges.
Old 02-22-2021, 01:12 PM   #781
Custom 68
Custom 68's Avatar
those do look great Shannon. They sure open up the engine bay. The stock ones are pretty bulky. Your truck is coming along nicely! Keep up the fine work.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-23-2021, 07:38 PM   #782
zicc1835
zicc1835's Avatar
thanks for sharing that .....
zicc1835 is offline   Reply With Quote
Old 03-01-2021, 09:55 AM   #783
1971Stepside
Almost Satisfied
Got her all loaded up for her first trailer ride. We are headed to upholstery for carpet etc. As I was loading it I managed to get the horn to honk by getting the steering wheel in just the right spot...so, that issue isn't fully worked out yet...smh.
We went by a gas station for her first fill up too.
Old 03-01-2021, 02:09 PM   #784
Qknf4u69
Qknf4u69's Avatar
Trailer looks great but the build looks better. Strong work on what you have done so far. The finish line is insight.
Inspired that it can be done. I am looking forward to be at that part of my build someday too.
'Hay Burner'
1969 C10 Long Bed, 454 BB, Hooker Headers, TH-400 w/3500 B & M Stall, 4.11 w/ Auburn-Pro Limited Slip.
http://67-72chevytrucks.com/vboard/s...d.php?t=813448
"Wouldn't say I was missing it Bob"
Qknf4u69 is offline   Reply With Quote
Old 03-03-2021, 10:08 AM   #785
1971Stepside
Almost Satisfied
Thank you I appreciate that
Old 03-03-2021, 10:11 AM   #786
1971Stepside
Almost Satisfied
The carpet turned out really nice. They ended up putting some additional material up under the dash as the ACC carpet didn't go up high enough to cover all of the Dynomat. Of course, it cost more money to do so...
Waiting on them to finish up the speaker cabinet and kick panels and the interior will be finished....except the horn!
Old 03-04-2021, 04:11 PM   #787
MDPotter
MDPotter's Avatar
Something about a red interior in a Chevy pickup that just works so well. I have some of my firewall showing because of the ACC carpet too...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 03-11-2021, 10:24 AM   #788
1971Stepside
Almost Satisfied
Have the speaker enclosures back from upholstery. Started installing them last night. Almost hate to cover it up with the seat.
Old 03-11-2021, 12:14 PM   #789
MDPotter
MDPotter's Avatar
Beautiful. Just beautiful. You're going to have to get those clear sheets that dealers use to put on the floor mats and also wear booties.
Old 03-11-2021, 12:50 PM   #790
1971Stepside
Almost Satisfied
I was thinking about a no shoe policy LOL
Old 03-11-2021, 05:15 PM   #791
TA_C10
TA_C10's Avatar
No shoe policy LOL.
Those kicks man. Turned out awesome. And to think back, you almost put those tweeters in the dash.
Everything looks fantastic.
"It's only money".
Old 03-11-2021, 05:59 PM   #792
Low Elco
Great lookin' work!
Low Elco is offline   Reply With Quote
Old 03-12-2021, 10:57 AM   #793
Custom 68
Custom 68's Avatar
Looking great, I will kick my shoes off for a ride!
That red is poppin.
Dave
Dave
Old 03-12-2021, 11:40 AM   #794
TexasLS1
TexasLS1's Avatar
I’m blown away with how nicely this truck has come together. Freaking awesome job!!
TexasLS1 is offline   Reply With Quote
Old 03-13-2021, 10:50 AM   #795
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
The truck turned out great!! You took great care every step of the way. You located your ECM in the same place that I did, under the passenger seat. The only difference is that I came in through the side of the hump with my wiring. Is that bracket sitting near the ECM for bolting down the Snowden seats? I'm seriously considering those seats for my next build (71 C10 build). Again congrats on an awesome job!
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-15-2021, 11:11 AM   #796
1971Stepside
Almost Satisfied
Great lookin' work!
Thank you!
That red is poppin.
You are welcome anytime after April 2nd...that is the tune date
Man, I appreciate it.
The seat brackets clear with room to spare. I did find that removing the ECM is not as easy as I had thought. Turned out easier to take the three bolts out of the bracket than it was to get it out of the bracket itself due to the low clearance under the seat.
Old 03-15-2021, 01:34 PM   #797
Putzer
Thank you!
What's drivability like now prior to being tuned?
Putzer is offline   Reply With Quote
Old 03-15-2021, 02:38 PM   #798
1971Stepside
Almost Satisfied
It is just running super rich with the base tune. It idles fine. Driving it around the neighborhood it goes fine until you brake for a corner and then it wants to die if you don't keep the RPMs up. I'm afraid to go on a main road until it gets sorted out better and won't die on me. Also hoping it all holds together on they dyno
Old 03-15-2021, 03:01 PM   #799
72 tigger
72 tigger's Avatar
Some fine craftsmanship has went into this build- congrats on seeing it through
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 03-19-2021, 11:05 AM   #800
1971Stepside
Almost Satisfied
Alignment Day! Also having them bleed the brakes one more time and do the state inspection. Tune is scheduled for April 2nd and then back to the paint shop for a couple touch up issues.
