Old 03-21-2018, 11:37 PM   #801
66clow
66clow's Avatar
Re: How about some pics of Static Dropped C-10's
Originally Posted by todds66 View Post
awesome truck. Can you please share the size rims, tires and backspacing? Love to duplicate this look on my 68
Thanks! Not sure of the back spacing. I bought them used boss 338's. Pretty sure they come in a standard size. 255/35/20 and 295/40/20
66clow is offline   Reply With Quote
Old 06-22-2018, 03:01 PM   #802
dmartin00
dmartin00's Avatar
Re: static drop pics
Originally Posted by TxSqueeze View Post
Here's mine with a 5.5/7 and 20's
you have inner fender wells still?
dmartin00 is offline   Reply With Quote
Old 06-22-2018, 03:05 PM   #803
dmartin00
dmartin00's Avatar
Originally Posted by 66clow View Post
I was wondering too since I'm at 5 in the rear and it is sitting pretty low with springs. Not sure if there is a difference due to the bed. Haven't looked lately at the axle spacing underneath.
you have fender wells still?
Old 06-22-2018, 03:29 PM   #804
jkk
jkk's Avatar
Nice stance
jkk is offline   Reply With Quote
Old 06-25-2018, 12:30 AM   #805
gringoloco
A guy with a truck
gringoloco's Avatar
It is possible to run at this height with inner fenders, but you will rub on big bumps/dips
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-25-2018, 12:31 AM   #806
66clow
66clow's Avatar
Yes I do, I'm down to 5 7 now
Old 10-11-2018, 10:28 AM   #807
Canadac10
Any of you guys running a 4/6 drop have issues with hitting the stops? My shop is saying if I go over a 2/3 drop on my '70 c10 longbox I am going to have issues of hitting, and a 2/3 drop in my opinion does nothing for the stance. I don't want to notch the frame if I can avoid it. A whole lot of nice looking rides on here!!!
Canadac10 is offline   Reply With Quote
Old 10-12-2018, 12:41 PM   #808
knomadd
knomadd's Avatar
I had a 3.5/5 before going with air and would notice the rear would hit the cut down bump stops on a large bump, but nothing too bad (no notch). I'd imagine you'd be hitting the bump stops pretty regular with a 6" rear drop. But that will also depend on the company you buy the springs from. Some companies will advertise a drop based on out-of-the-box height while others will advertise their drop based on a settled suspension which can take months to get there. I don't know which companies drop is out-of-the-box vs. settled though, so good luck.
I wouldn't imagine a long bed would make much difference on the drop, but I doubt a 3" or even a 4" drop would be a problem with bump stops.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-12-2018, 06:32 PM   #809
smbrouss70
smbrouss70's Avatar
It also depends on spring rates. One company's 5" spring might have a lower spring rate to allow it to compress more than another company's 6" spring that has a higher spring rate when hitting bumps, or being loaded down.
That being said, my only experience with drop springs has been with Early Classic's 6" drop springs for the rear. I cut down my bump stops with no notch and never bottomed out unless it was loaded down and I was driving like an @ss. I did add 2" lowering blocks later with a CPP bolt-in notch and it was even better then.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-15-2019, 12:40 PM   #810
azbmwcrew
Almost ready to put the body back on! 68 c10
azbmwcrew is offline   Reply With Quote
Old 05-01-2019, 11:00 PM   #811
karl1964chevytruck
I have to say there are some great looking trucks on here, it has my head spinning on which direction I want to go now haha. Getting ready to lower my 66. Are there any drop spindles that will enable me to keep my drum brakes? Everything I find requires a disc conversion. I’m looking to do a 4/5. Thanks!
karl1964chevytruck is offline   Reply With Quote
Old 05-08-2019, 11:38 AM   #812
68Stepbed
68Stepbed's Avatar
There aren't any drop spindles for drum brakes. Why not just make the disc brake swap?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-08-2019, 01:40 PM   #813
karl1964chevytruck
Well I would love to, but the lack of money holds me back. Also it really sucks since I’ve already put everything new on the front suspension, drums, wheel cylinders, pads, ball joints, tie rod ends, master cylinder, all new lines, etc. I’ve been doing some research and I think I just might do a spring kit, shocks, shock relocating brackets and sway bar for now.
Old 06-29-2019, 08:22 PM   #814
bozly
'71 work in progress. Currently at 4.5/7 drop with spindles/springs/blocks/shock relocation. Once I get new wheels and tires I have shorter springs for a 5.5/7 drop. It needs to have the driveshaft shortened a bit before I can get it back on the road.
bozly is offline   Reply With Quote
Old 07-01-2019, 12:55 PM   #815
Montierth
Montierth's Avatar
New paint and wheels. Drop spindle in front and flip kit in back with 1.5 -2 inch block
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 09-14-2019, 09:45 PM   #816
BigTopGT
Active Member
I call her Brick
I've got new shocks, springs, and away bars going on tomorrow, all around.
BigTopGT is offline   Reply With Quote
Old 09-19-2019, 09:15 PM   #817
19Loki67
This is Loki
19Loki67 is offline   Reply With Quote
Old 10-02-2019, 03:36 AM   #818
mailman
mailman's Avatar
Originally Posted by 19Loki67 View Post
This is Loki
Any side pics and wheel and tire specs?
mailman is offline   Reply With Quote
Old 11-13-2019, 08:20 PM   #819
rcnutt
rcnutt's Avatar
my 64 with 5.5"/8" drop
64 short fleet
rcnutt is offline   Reply With Quote
Old 03-22-2020, 09:07 PM   #820
novajess1972
novajess1972's Avatar
My 85 Silverado
4/6 Belltech with 3/4 coil cut
1985 SWB Silverado 1/2 Ton
1972 Chevy SWB 1/2 Ton (sold)
1972 Chevy Chevelle SS (sold)
1971 Chevy Nova (sold)
1967 Chevy El Camino (sold)
2001 Mustang Bullitt (sold)
2019 Toyota Tundra Crewmax (daily)
novajess1972 is offline   Reply With Quote
Old 03-24-2020, 11:36 AM   #821
Matt Man
Matt Man's Avatar
67 Gmc 4/6
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-31-2020, 08:01 PM   #822
arkracing
Weekend Warrior
For the guys running 4"/6" or 5"/7+" how do they actually ride? Please be honest. I just picked up a '66 Suburban and I am really torn on Static or Air suspension. I want to be able to travel.
I'm considering a 2.5"spindle with 2" spring and then 6" spring out back so I can use a block if it needs to go to 7" to level it out. Obviously a notch and shock relocators and good shocks.
Or just Bag it
Thoughts?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 05-31-2020, 08:45 PM   #823
Robznob11
Robznob11's Avatar
Or just Bag it
Thoughts?
Just bag it, adjustable is the way to go for different terrain and loading on a trailer if needed
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-01-2020, 02:38 PM   #824
SCOTI
SCOTI's Avatar
Or just Bag it
Thoughts?
When you get past 4/6 static drops using OE geometry/pick-up points, the driving experience diminishes quickly.
4/6 is usually the most you should drop for mostly trouble free driving. Once you pass that mark, those lower control arm pivot points (& bottom of the front x-member) get real close to mother earth. The lower they are, the closer you need to pay attention to the bumps & dips in the road surface.
Air can offer better ride quality & definitely offers adjustability as mentioned. But air alone doesn't improve ride quality if you're bottoming out unless you're adjusting it. Set the ride up w/proper clearance & either choice works well.
I drive my stuff low (5/7 or more). With no mods, it does suck on crappy roads. Static or air doesn't make a difference if you're bottoming out. To make it better, I use a modified factory or aftermarket raised front x-member. It allows for the more aggressive drop I like while provide additional ground clearance. The additional ground clearance is only part of it though. Once you have the aggressive drop w/a modified or raised x-member, you now will most likely need some raised fender wells so the tires don't constantly buzz.
Same for the rear.... C-sections provide some clearance but not much. They also can impact using a truck as a truck to some degree. Usually w/C-sections the differential gets closer to the flooring & can hit on the 5/7 drops. That can also be remedied... w/more work. Target a minimum of 3" clearance to your bump-stop @ the lowest point of rear suspension travel on the road for trouble free driving.
How low w/a good ride is impacted by how much will you modify.
In the pics below, my 74swb bottomed out. A lot. The dually is a little lower than the 74 was but never bottoms out. The difference is the mods (raised x-member, shock mounts, rear rails, wheel wells, bed floor)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-01-2020, 02:50 PM   #825
66clow
66clow's Avatar
Or just Bag it
Thoughts?
I think 4 6 isn't bad on yours. I use to have a 66 c10 with that drop. Currently have a 69 5.5 7 drop. You don't want to drive it everyday. You have to watch out for potholes and dips etc. For me you can't beat the look lol.
