#801 |
Re: Project 68 k10 LWB..aka "The Hulk"
Cool you figured out the DBW. Sound great.
#802 |
![]() Join Date: Dec 2012
Thanks. I noticed in the video that my phone could not record the exhaust sound I guess it was too loud LOL
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#803 |
Started working on the upper radiator hose/pipe and thought I better get the engine cover installed. I think I am going to paint it body color.
I tacked up the stainless pipe to see if I was going to like it or if it was in the way of the intake tube. Seems to fit but had to re adjust a little. After I as able to get it tacked where I wanted it I ran out of argon. To be continued. I was able to get the MAF mounted and connect the intake tube. What do you guys think?
#804 |
I just filled my 125 bottle of argon cost me $173.00. Double the cost from last year. The radiator tubing looks great. Where did you get the intake Y pipe looks cool
Posted via Mobile Device |
#805 |
173? Damn. That’s bs. My bottle is the same size as yours.
I bought a corvette kit and added the 2 long 45 degree pieces. They will have to be cut down on the ends but won’t do it until the fenders and fenderwells are on. The kits was like 38$ on eBay. I figured it was worth it to just try it. I bought the silicon couplers, SS and aluminum piping from Www.siliconintakes.com https://rover.ebay.com/rover/0/0/0?m...2F223382248961 I am a little worried about hood clearance. I do have a cowl induction hood but will have to measure for clearance.
#806 |
I have a smaller bottle I was going to fill and it cost almost as much so I passed on the the small one. That is cheep for the intake Y why. I will have to order one.
#807 |
I ordered the intake Y pipe. free shipping too
#808 |
![]() Join Date: Nov 2008
I am very pleasantly surprised about the amount of hood clearance on these trucks. You will probably have more room than you expect.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
#809 | |
Trying to get the SS upper radiator piping built. Had to give myself the crash course in tig welding again as the last time was the exhaust I did 4 years ago. I plan on sanding the welds down and buffing them shiny.
#810 | |
Maybe worth a ride to LB for you to just exchange a bottle.
#811 |
That is what I did bottle exchange. I went to Ait Gas to exchange
#812 |
Last year I went to Madco welding Suply
#813 |
MARFAB is where I went. It’s the only place in Los Banos to exchange gas cylinders.
#814 |
Wow, big big progress!
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#815 |
For being out of practice, it looks great!
#816 |
Thanks. I always go to slow and get the metal too hot.
Thanks Brett. Trying to spend time on it each day. How is ol Ray treating you?
#817 |
Amazing how much you can get done that way, looking forward to seeing your truck together.
![]() Got just a little over 1k miles and put it in storage for the winter, currently storing our patio furniture on the bed! ![]()
#818 |
Spring is around the corner for Utah. Time to put the patio furniture out also then the truck will be freed.
Got out the wire wheel and rotoloc scotchbrites to smooth the welds and then polish on the bench top buffer. I forgot to take a picture of it before installation but I was excited how good it turned out so I installed it. First picture is from the driver side and the second is the passenger side. I tried to take a picture from the front but it’s tucked under the intake tubing.
#819 |
I wanted to add a 6° shim to rear leaf spring pack to lower the pinion as the rear shackle left tilted the pinion up and I didn’t like it. Since I was adding the shim I removed my rear leaf spring packs overload spring. I didn’t take any picture of it but wanted to update it on the build thread.
Probably dropped the rear of the truck 3/4”... well maybe 1/2” since the shim was about a 1/4” thick at the center line of the axle.
#820 |
Hey DW this May affect you with this intake Y.
After getting the upper radiator pipe built I added antifreeze and started the truck up and let it run. I found out that the intake tube air supply to the crank case ventalation system is unmetered as it connects before the MAF. The CEL came on and the code was for lean bank 1 and 2. Like an intake or vacuum leak. I disconnected the ventilation and plugged it, clearedthe code and the code never came back. So I am not sure of it can be tuned that way or if I need to figure out how to connect it after the MAF.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() Last edited by First c10; 04-07-2019 at 11:58 AM. |
#821 |
Decided to make a custom mount for the heater control valve. Got a chance to take a crash course in aluminum tig welding. I was able to tap the AC compressor and bolt the bracket and heater valve to it. After I mounted it I only needed two 7” heater hoses to it from the water pump.
#822 |
I was able to build the a/c hoses today. Since I relocated the compressor on the LS with a high compressor mount the hoses needed to be shortened a lot. Oh and I used large diameter heat shrink tubing to cover the crimped ends of the a/c lines
The last thing I need is an adapter to go from standard 1/4” flare port to M10-1.0 port for the stock GM a/c refrigerant sensor. After I get it I will attached it to the other side of this tee. The other side will have the compressor binary switch.
#823 |
I also forgot to mention I had a problem with the CEL staying on even though there wasn’t a problem. The Dakota Digital HDX gauges I installed needed a 1k resister from 12+ power to the CEL terminal on the DD HDX box. Light went away. I only had a 1.5k resister but it worked the same.
I just wanted to make sure I posted about it as I am sure others reading this thread may run into the same issue.
#824 |
I picked up a 7/16" to 10mm AC adapter fitting (in the middle)for the GM refrigerant sensor(on the right) for the ECM to see the AC. I also picked up a binary switch (on the left)because I ordered a trinary switch when I ordered the system years ago.
I was able to get them installed and wired up. Now time to pull a vacuum on the system and check for leaks.
#825 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Is your ECM programed for the AC? And I'm curious as to why are you planning to use a binary switch and not trinary? My PCM is set up to control the fans, but I'm also using a trinary switch.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
