#801 |
Post Whore
![]() Join Date: Aug 2014
Re: My Dusty 71 GMCe Electruck
decided to shave off a few protruders to ensure flatability
#802 |
Post Whore
trying to look all official and shiet
#803 |
Post Whore
just some scrap piece with a "speed hole" in it
#804 |
Post Whore
one of many, many, trial fitments (FYI, if frame rail hurdles ever become an Olympic event, I will bring home both the Gold and Silver medals for team USA)
#805 |
![]() Join Date: Sep 2017
Westward HO! The bracket looks good, and the cable seems to have healed up.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#806 |
Post Whore
I need one of them 90° drill extensions to drill out this one and single hole in the frame cause the firewall is in the way even with the cab unbolted and slid further back, and I don't feel like unbolting the bed of the truck
#807 |
Post Whore
another day another template (and one dull razor)
#808 |
Post Whore
not my favorite tool, still trying to learn how to use it as sometimes I am a surgeon with it, but most of the time a Barbarian
#809 |
Post Whore
top tip on fillin in them holes, anything bigger than tiny I like to use some backing plate on it, this is a flattened out piece of copper pipe you can source at your local plumbing supply, works great as the filer rod won't stick to it
#810 |
Post Whore
A Note On The Side:
if you are good with working with wood, or simply enjoy working with it, you will be really good with working with metal as it is more forgiving, you can bend it and you can straighten it, you can also cut it as many times as you like and it will still be long enuff, ha ha (if you get my meaning, unlike wood) |
#811 |
Post Whore
Top Tip: on punching holes, lay a piece of paper or card stock over the holes and with a ball peen hammer gently tap tap tap the holes perimeter and it will punch out the perfect hole for you to transfer over, also great for making paper gaskets, works around edges as well for that perfect border cut
#812 |
Flatability always prevents warpability.
#813 |
Post Whore
#814 |
Post Whore
and let's glue it on there
#815 |
Post Whore
well now for the moment of truth, will this thing come out?
#816 |
Post Whore
over the last 20 years I have seen more painting products get banned in California than I care to mention, you know the good ol'
May cause California in the State of Cancer warnings! I about lost my shiet when I found out we can no longer buy Denatured Alcohol here !!! so this is the latest thing I have tried lately, works pretty OK, and it has that familiar smell like it is just rebranded Mineral Spirits or Acetone? maybe one of you Walter Whites can set me straight on the ingredients |
#817 |
Post Whore
and I got it covered with primer just before the rain that night, I really like this RUST-OLEUM primer it covers well, makes me feel like a PROFESSIONAL and you can get it at Home Depot or Lowe's at half the cost of what they sell the same stuff at the Auto Parts Stores
#818 | |
#819 |
out of curiosity, why are you mounting that so far back into the firewall? Seems like it would be kind of tough to get at for any maintenance you might want to do on it.
#820 | |
Post Whore
I considered mounting it where our stock AC unit went but I did not want to attach it to the firewall as it weight over 40 pounds do you have any suggestions / ideas for a better location? I am open to any and all advice |
#821 |
Post Whore
and here is Reason #197 why I chose the Lexus GS450 transmission as my electric power plant, essentially so I won't have to do this:
In this The Grey Goose : Nismo Electric E46 Touring video Damien Maguire shows us what it takes to attach a first gen Nissan Leaf electric motor to a BMW E46 five speed transmission.
Don't get me wrong we loved our 2013 Nissan Leaf which we leased for three years, and of course I love Damien, everything I know about EVs I learned from his videos. but please take a looksie and anjoy oh by the way 197 is also the horse power of the bigger electric motor inside of our Lexus transmission, yes there are two electric motors inside of it, the other one is a bit smaller |
#822 |
![]() Join Date: Apr 2008
I am not sure if this is in the works or not, but the two vertical square tubes for your trans crossmember should have caps welded on them so water does not get in the tubes and rust out. Just flat squares welded below the mounting bolts should do it.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 04-17-2022 at 12:44 PM. |
#823 | |
#824 |
Post Whore
so when the combustion engine goes away, so does vacuum or the source of vacuum, this means that we loose power brakes, as the brake booster is vacuum operated, here I am starting to work with a replacement electronic booster called an iBooster from a 2018 Honda CRV (there were two generations of this animal, and I believe mine is still Gen 1)
thanks be to Lars and his amazing blog on this topic at EVcreate.nl Electric power brakes but first the mandatory stare and compare (Chevy on the left, not Chevy on the right) |
#825 |
My combustion is showing, is there an electric power steering unit as well?
