Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-25-2019, 12:55 AM   #826
DWilbur
Re: 71 4X4 Frame off Restoration
I got some work done this weekend modified the transmission adapter by moving the hole center 1/2" each way so the bolts align from moving the engine forward 1". w
Went to my friend house Friday and he helped cut down a part so my front and rear T-case sticks fit better. Installed the new wiper motor and it fit good. the Vintage Air was difficult to get bolted up the the firewall ad to remove the rear bracket and the wiring on top to fit it in. Only lost 1 grommet pushing the tubing through the fire wall. Got the driver door rubber installed holds the door out about an inch. and got the door lock linkage inside the door working.
DWilbur is offline   Reply With Quote
Old 12-02-2019, 05:53 PM   #827
DWilbur
Well it rained most of my time off work and I got sick Friday so no work on the truck during the Holidays. No room in the garage to move around to work in side. I did receive my wiper motor shaft seal from GMC Paul. The smaller one that fits tight to the main shaft. If the rain stops I should be able to finish up work under cowl.
Old 12-07-2019, 05:49 PM   #828
Gregski
Post Whore
Gregski's Avatar
FACT: this man aint skierd of naffin'!
Gregski is offline   Reply With Quote
Old 01-08-2020, 12:14 PM   #829
First c10
First c10's Avatar
Hey DW how's the truck coming?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-08-2020, 01:28 PM   #830
DWilbur
I have not done much after thanksgiving got sick for the 3 days after and the weekends have been raining + working late shift at work kills my truck time until March. I can only work on my truck in the driveway no room in the garage. I did get the grill installed Sunday. I will have to rework the aftermarket grill insert so my fingers will fit to open the hood.
Old 01-09-2020, 02:57 AM   #831
First c10
First c10's Avatar
Nice. Who did you get the insert from?
Are you going to be able to store it inside the garage when complete since it’s so long??
GO GO!!!
Old 01-17-2020, 05:22 PM   #832
DWilbur
Got the inserts from LMC truck. it fits in the garage now. when its done it will be to high to fit.
Old 01-23-2020, 08:41 PM   #833
DWilbur
Okay I went off the deep end and bought a Magnuson supercharger TVS2300 for my truck. LSX Concepts make kits to fit the supercharger with Vintage Air kit. The other part I had to buy is cylinder head adapter for Cathedral port to square port to make it work on my truck because I put about $1500 worth of work in the cathedral port heads I have. I should have the supercharger and head adapter next week. the pulleys and brackets I will order after I send some pictures of my engine to LSX Concepts to see if I have to change the AC pump brackets or not.
Old 01-23-2020, 09:50 PM   #834
swamp rat
swamp rat's Avatar
Damn!!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-24-2020, 02:12 AM   #835
First c10
First c10's Avatar
Nice. I can’t wait to see it.
GO GO!!!
Old 01-24-2020, 03:09 AM   #836
Richard
I see you decided to use the LSX Concepts brackets. I got the Gilmer belt drive setup for my LSA. Quality looks good. Will not be installing myself for a few months. Truck paint is delayed due to having the car I am selling going into paint first.
Richard
Old 01-24-2020, 07:17 PM   #837
DWilbur
I might have problem with the crank pulley fitting the front cross member is real tight.
Old 01-24-2020, 08:29 PM   #838
DWilbur
So I had to buy the complete bracket and pulley kit to make it work. The pulleys move all the accessories back about 1.5" and the supercharger pulley end up about where my stock truck pulley is now. witch helps with how tight my crank pulley is to the front cross member. Also I ordered there fuel rails do to conflict with the cooling lines.
Old 01-28-2020, 02:52 PM   #839
Richard
I thought that may be the case. Hopefully someone else needs the brackets you already have. You are making me question if I am going to have clearance problems at the front of my motor due to the wide gilmer belt setup I am using. Will know in a couple of months. Cool truck build.
Richard
Old 01-29-2020, 12:54 AM   #840
DWilbur
My supercharger was delivered yesterday and it is heavy I can hardly pick it up. going to take cheery picker to installit. looks real cool. if the weather is good this weekend I will install it. waiting for the rest of the brackets and pulleys to complete the installation.
Old 01-29-2020, 08:01 PM   #841
DWilbur
If you can modify the passenger side fire wall for clearance for the coil pack then you can slide you engine back some more. This is where I have clearance issues. As my engine sits I can pass my finger in-between the fire wall and the right side coil pack and my crank pulley is about 3/16 clear of the front cross member. My cross member is angled back some older frames are more vertical witch would give more room.
Old 01-30-2020, 01:52 AM   #842
Richard
Good to know. Have no problem clearancing the fire wall. I have the Pacific Fabrications crossmember. Have yet to even test fit the motor and trans (LSA/6l90) Have to wait until I get truck back now. Looking at the DT mid length tri-y headers. Seen some info that passenger side clearance is an issue with these as well. Want 1 7/8 primary's and full length usually hang to low for me.
Richard
Old 02-06-2020, 03:28 AM   #843
DWilbur
I received 2 more boxes today from the big brown truck accessories brackets and pulleys. still a couple more boxes coming. I will post pics in the next few days.
Old 02-06-2020, 03:56 AM   #844
Richard
Bad A** hope all goes well with install.
Richard
Old 02-07-2020, 01:26 AM   #845
DWilbur
The big brown truck delivered the fuel rails today. I think that is the last box. if I can find time this week end I will try and install some of the parts.
PS I have a new family member as of last week, 9 week old Black Lab and she has been alot to handle.
Old 03-03-2020, 09:08 PM   #846
DWilbur
picture of Maggy 1st day home and passed out after first walk.
Old 03-04-2020, 05:16 AM   #847
Richard
She looks like a sweetie.
Richard
Old 03-04-2020, 10:50 AM   #848
rgunlock
rgunlock's Avatar
More like a handful Those lab pups have a LOT of energy!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 03-04-2020, 11:31 AM   #849
First c10
First c10's Avatar
Man... I have been wanting to get another dog but thinking of the first year is painful! my last dog chewed everything. I mean everything!!!
I like the name "Maggie" short for Magnuson???
GO GO!!!
Old 03-04-2020, 10:02 PM   #850
DWilbur
My biggest problem is working graveyard shift and not being home then sleeping half of the day makes potty training difficult. she has be good about not chewing on things other than me so far. she does bring in a lot of stuff from the back yard today its pine cones.
