Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-12-2019, 11:42 PM   #826
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Originally Posted by derotoreut View Post
Is your ECM programed for the AC? And I'm curious as to why are you planning to use a binary switch and not trinary? My PCM is set up to control the fans, but I'm also using a trinary switch.
I already wired my fans to come on when the ac was turned on. It works both ways right now with the pcm and the call for ac. The binary switch is only to shut off the compressor under low pressure.
How do you have your trinary switch wired?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-12-2019, 11:45 PM   #827
First c10
First c10's Avatar
Oh and I haven’t had a chance to do the programming on the pcm yet. But I do have what the stock setting are set at. I have not actually used the stock refrigerant sensor before so not sure how it is going to work.
GO GO!!!
Old 04-13-2019, 08:21 AM   #828
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Keep me posted on how it works for you. I haven't wired in my Vortec project it yet, but I have in the past on SB engines. The trinary gives you the low and high pressure cutout.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-13-2019, 10:02 AM   #829
First c10
First c10's Avatar
From what I know about these switch’s is A binary switch is normally closed and opens when there is too much or too little pressure in the system to shut the compressor off to prevent damage. A trinary switch contains a binary switch AND a normally open switch that can be used to turn electric radiator fans on when the pressure determines that more air flow is needed through the condensor.
When wiring the truck or more specifically wiring the main relays for the cooling fans I added a relay to turn a fan on when the ac compressor is on. This is only because I am not sure how the stock ac sensor is going to work. I hope I can remove it when the stock ac sensor is working. The stock ac sensor should let the ECM know the ac is on and to control the fans due to pressures in the ac system. It should also adjust engine idle.
GO GO!!!
Old 04-13-2019, 09:43 PM   #830
First c10
First c10's Avatar
Well as it turns out Gen IV’s only accept ac request(notify the Ecm your AC is on) only be sent through canbus. A company makes the trigger but it’s 300$ that’s BS as all it does it tell the pcm you turned on the ac compressor I wonder if Dakota digital has a bim module for it. I am going to call them about it.
As for now I think I am going to remove all the stock sensor bs. I will keep the binary switch as it does work as I tested it out today. Low and high pressure. System is wiring great. Nice and cold.
GO GO!!!
Old 04-13-2019, 09:48 PM   #831
First c10
First c10's Avatar
I decided to put the head lights I bought from a forum member in. I just leveled and the kept the buckets straight to the core support.
They are HID’s and pretty bright. The high and low beam relay setup I made worked great.
GO GO!!!
Old 04-13-2019, 09:57 PM   #832
First c10
First c10's Avatar
Well a while back I installed a catch can. I ordered it off eBay and built a custom mount to hang it under the wilwood master cylinder.
I built it to the same bracket that held the wilwood adjustable proportioning valve.
I did have to notch the plastic cover to clear the can and hoses
GO GO!!!
Old 04-13-2019, 10:06 PM   #833
72 tigger
72 tigger's Avatar
As usual, nice work!
72 tigger is offline   Reply With Quote
Old 04-17-2019, 12:49 AM   #834
First c10
First c10's Avatar
Thank you very much!
Hope to get my painter back this weekend to paint my steering column, ash tray, and glove box so I can button up the dash and possible drive it out of the shop. Currently the truck starts and runs like a new vehicle. HVAC is working, stereo with blue tooth working, wipers working, remote start working, and DD dash and all working. Just need the few things I stated above. He said he could have them painted by the end of the weekend.
I did splurged and bought my shocks.
GO GO!!!
Old 04-17-2019, 11:46 AM   #835
DWilbur
Cool choice on the shocks. I bought similar one for my Dodge and work much better than the one that came with the lift kit. My plan is to use them on my Chevy too.
DWilbur is offline   Reply With Quote
Old 04-18-2019, 12:18 AM   #836
First c10
First c10's Avatar
Originally Posted by First c10 View Post
Hey DW this May affect you with this intake Y.
After getting the upper radiator pipe built I added antifreeze and started the truck up and let it run. I found out that the intake tube air supply to the crank case ventalation system is unmetered as it connects before the MAF.
The CEL came on and the code was for lean bank 1 and 2. Like an intake or vacuum leak.
I disconnected the ventilation and plugged it, cleared the code and the code never came back. So I am not sure of it can be tuned that way or if I need to figure out how to connect it after the MAF.
Well I decided to put a 5/16” bulk head fitting downstream of the MAF sensor.
I drilled a hole in my MAF tube. I put an o’ring on it and connected it to the PS valve cover like stock.
Now to tig weld the hole in the aluminum intake tubing.
I will check it out with the scanner tomorrow to make sure the fuel trims look good.
GO GO!!!
Old 04-25-2019, 12:23 PM   #837
First c10
First c10's Avatar
Small things are taking the longest time... or at least it feels like it.
I was able to get color on the steering column, ash tray and glove box door.
I installed the column and had a problem with the neutral safety switch is hitting the brake switch. nothing is easy!!!
Also I got the high hump coated inside and out with raptor liner. Now to install the floor shifter bracket.
Waiting on the new brake switch, and Lokar shift linkage
GO GO!!!
Old 04-29-2019, 11:00 AM   #838
7dee2
7dee2's Avatar
Looks like you managed lots of gut room with the column and that's worth the aggravation for sure...
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-29-2019, 04:02 PM   #839
First c10
First c10's Avatar
Thanks Brett,
I built a custom seat frame/mount to lower and move the seat back so hopefully I should have plenty of room. I am waiting on the Lokar shift linkage to come in today and get it installed.
GO GO!!!
Old 04-30-2019, 10:35 AM   #840
First c10
First c10's Avatar
I was able to get the glove box door mounted. I didn't want it to get damaged since it was painted and buffed out.
GO GO!!!
Old 05-07-2019, 01:57 PM   #841
rgunlock
rgunlock's Avatar
Very cool build! I've read posts from it time to time as I noticed this thread come to the top of the page, but I just read the whole thing over the last few days. You'll be glad to have so much of the "fiddly" work like wiring done so that the remainder of the build should go about as fast as you can get the parts ready and you can make time to do the assembly.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 05-07-2019, 02:50 PM   #842
First c10
First c10's Avatar
Hey Rick thank you for the post as I think I needed that. I have been spending every extra moment I have on all of the fiddle work you mentioned. I have started to tidy up all the wiring and have the dash about finished. I just have to install the glove box.
I was able to finish up the steering column install, transmission linkage, and steering column intermediate shaft.
Tonight I’m going to install my high and low tone horn’s.
GO GO!!!
Old 05-16-2019, 01:09 AM   #843
First c10
First c10's Avatar
Doing a few little things like adding a light to my glove box.
I had bought a stock glovebox light assembly awhile back but since I am not using a stock cardboard glove box it would not fit the the old air products plastic glove box that came with the AC system I bought.
So I decided to make a connector and install a glovebox light I ordered off eBay
It was like 4 bucks and can be added to any glove box.
I forgot to take a picture before.
Link to light
https://rover.ebay.com/rover/0/0/0?m...2F362511152606
GO GO!!!
Old 05-16-2019, 09:56 AM   #844
nsulacountry
Very nice light solution.
My 1979 C20 has a light, my 1975 Ford F-250 doesn't. Think the F word needs a glove box light.
CT
nsulacountry is offline   Reply With Quote
Old 05-17-2019, 01:02 PM   #845
DWilbur
I will have the same issue with glove box light using Vintage Air system. I will check it out.
Old 05-17-2019, 01:05 PM   #846
DWilbur
At under $5.00 I bought one.
Old 05-17-2019, 04:07 PM   #847
First c10
First c10's Avatar
Get me your address and I can send you a connector and a couple terminals for it. I happen to have a kit I ordered sometime back that was not what I wanted but it worked great for this light as it didn’t come with a pigtail.
GO GO!!!
Old 05-17-2019, 05:01 PM   #848
DWilbur
I have a bunch of connectors one of them will work. Thanks for the a offer.
Old 05-21-2019, 01:22 PM   #849
First c10
First c10's Avatar
I am having a few issues with the brakes. the pedal feels a little spongy and goes down farther than I would like. after adjusting the brake pedal and bleeding the system I still have the problem. I even put the rear on stands and took the rear wheels off. I put in gear and tried to stop the rears and had to push way harder then I should. so I figure I have air still trapped in the system. Started to get my stuff ready to bleed them and noticed brake fluid leaking from the rear brake calipers. it is leaking from the center of the piston. the brake calipers are new bought 5 years ago. Maybe the seals dryed up from sitting with no fluid.
I am going to get a rebuild kit for them since they are less than 20 bucks for the pair. (79-85 Cadillac rear calipers) but another set back for me to actually drive the truck. well I don't have a steering wheel yet but still!!!
One good thing I received my billet aluminum badges and glove box emblem from Shortie (John) a forum member.
they will look great when installed!!!
http://67-72chevytrucks.com/vboard/s...=701118&page=8
(I noticed in the picture the red X is a little bubbly I think that is from the window cleaner I didn't wipe off.)
GO GO!!!
Old 05-21-2019, 01:42 PM   #850
DWilbur
The emblems look great. I wish I found them before I bought the ones I did
