Old 01-14-2012, 08:32 PM   #851
Low Elco
Re: Tbi swap build thread
Oy. So, best to keep fairly close, year to year? Seems a bit of a mess. I'm fine iwth swapping the housings, but the rest is a tad muddy. Thanks for the info, though, answered a lot of questions.
Low Elco is offline   Reply With Quote
Old 03-04-2012, 04:09 PM   #852
manimal
manimal's Avatar
I have a question regarding the EGR solenoid.My CEL comes on spuratically.
I have checked vacuum at TBI=0 at idle,increases with throttle.
no vacuum at egr side of solenoid with engine on or running with throttle.
I can move the egr valve manually and the idle changes,but doesnt stumble.
Does this sound like i have a BAD solenoid?
Vehicle in question is 1989 Suburban R2500 454 TBI(2wd),automatic.
Thanks!
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-05-2012, 02:51 AM   #853
rfmaster
rfmaster's Avatar
Thanks!
Follow up questions:
1) CEL comes on sporadically - which DTC codes are set? Get wire jumper across pins A & B of ALDL and count CEL flashes (groups of 3 starting with 12)
2) If you apply vacuum to EGR valve with a vacuum pump you should see the valve move and there should be some change in idle quality. Too much EGR and the engine should stall. On high millage trucks there is a lot carbon and oily crud build up in the EGR passages restricting amount of exhaust gases reaching intake manifold plenum. The best thing to do is to carefully remove EGR valve and take a small brush and carb cleaner and try to remove, clear the offending crud.
Depending on EGR type you have it may hold vacuum or slowly bleed it of. A blown diaphragm will leak instantly - use a hand held vacuum pump to check EGR diaphragm.
Depending on calibration EGR valve is enabled when truck is in motion and certain other parameters are met. To check for EGR vacuum control side operation I use a vacuum hose and T with a vacuum gauge temporarily mounted on the windshield (duct tape can be used). The vacuum take of point is between solenoid and EGR valve. If you see vacuum while driving - solenoid is supplying vacuum to EGR valve. Check EGR diaphragm first. Check supply vacuum hose as well (between TB and solenoid input).
If you do not see vacuum then I would check ECM control circuit. The EGR solenoid connector should have two wires - pink-black and gray. The pink-blk should have +13.8 Vdc when engine is running (IGN is on). The gray wire is a control circuit - ECM will pulse this line on-off to control amount of EGR. Most DVM's averaging is too slow, but higher end DVM's may have a frequency function and can pick up the PWM waveform. Naturally Oscilloscope is the a weapon of choice!
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-05-2012, 10:25 AM   #854
manimal
manimal's Avatar
At the moment I cant remember the codes,but I do remember it saying the EGR system,check for operation of the valve,check the solenoid,check the plug to the solenoid.
The CEL light comes on at very strange times. I have driven half way to Sacramento(200 miles) with it NOT coming on,then I have driven down the street about 5 miles and it comes on.
I do plan on cleaning out the EGR passage,so a new valve may be in order anyway.
-Lance
Old 03-05-2012, 11:26 AM   #855
rfmaster
rfmaster's Avatar
Well, lets get some basic information squared away before jumping to any conclusions. Pull codes - they should stay put in ECM memory unless battery was disconnected. We'll go from there on.
//RF
"The Beast"
Old 03-05-2012, 02:13 PM   #856
manimal
manimal's Avatar
Code 32 comes up. I checked the pink/black wire at the solenoid,on my DVM it reads 12.01. I dont have a vacuum pump (other than my wife!lol),so I have to draw vacuum the old fashioned way. When I do there is NO movement n the egr valve when the vacuum source(me) is hooked to the manifold side of the solenoid with the key "ON" engine "OFF".
-Lance
Old 03-05-2012, 05:21 PM   #857
manimal
manimal's Avatar
I hooked a vac gauge up to the egr port(between solenoid) and drove it in town and freeway. Vac reading never got above 5" and would stay there for about 10-15sec and then drop to 0.
-Lance
Old 03-06-2012, 03:14 AM   #858
rfmaster
rfmaster's Avatar
EGR solenoid acts as a proportioning device - metering amount of vacuum that reaches EGR valve diaphragm. The fact that you see about 5" inch of vacuum between EGR control solenoid and EGR indicates that control circuit is functioning, but EGR valve diaphragm bleeds off vacuum very quickly. Not being a betting man I would say that you may have a leaky EGR diaphragm. You can temporarily connect EGR valve directly to a manifold vacuum port and if there is no movement - it is time to replace EGR valve!
In the absence of the handheld vacuum pump I would take it off and take it to a parts store - most of the time they have handheld pump handy.
//RF
"The Beast"
Old 03-06-2012, 10:08 AM   #859
manimal
manimal's Avatar
Thank you very much.
-Lance
Old 03-06-2012, 11:27 AM   #860
rfmaster
rfmaster's Avatar
An - unrelated question! On your '89 454 Burban you do not have an AIR pump, right? Is it CA or Federal certified (do you know). The reason why I am asking there was a post recently with a question when GM stopped using AIR on BBC TBI trucks.
//RF
"The Beast"
Old 03-06-2012, 11:31 AM   #861
manimal
manimal's Avatar
It's a CA truck w/A.I.R.
-Lance
Old 03-06-2012, 11:33 AM   #862
manimal
manimal's Avatar
Another question, would a leaky diaphragm also be the reason it will hold 5" for 10-15sec. and then drop off to 0,repeating that over and over. Or is that the way the system operates,open then close cycles?
-Lance
Old 05-29-2012, 11:21 AM   #863
carboncrew
carboncrew's Avatar
I basically have a 1991 suburban with a 208 transfer case with speedo cable.
I need VSS instead of the mech. speedo cable
From reading and research it sounds like I have 3 options:
signal generator - plugs into transfer case speedo cable (do I need Electronic Ratio Adapter??)
reluctor ring/speed sensor - plugs into tail housing of tranny
reluctor ring/speed sensor - plug into rear diff.
Can someone explain which would be the best option? I'm still confused here.
Thanks for any helps guys/gals
carboncrew is offline   Reply With Quote
Old 05-29-2012, 11:01 PM   #864
68 TT
Still plays with trucks
68 TT's Avatar
What about the optical VSS speedometer used in the 87-89 square bodies with TBI? Mechanical speedo with an optical sensor on the back that feeds the ECM data after passing through the DRAC.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-29-2012, 11:05 PM   #865
manimal
manimal's Avatar
-Lance
Old 05-30-2012, 12:26 AM   #866
rfmaster
rfmaster's Avatar
VSS produces AC wave signal - ECM expects a square pulse (digital like signal). DRAC module is a signal conditioner - multiplier, divider if you will. Another alternative to DRAC is a Dakota digital 'swiss army' knife ratio adapter. Pricey, but very flexible. I would expect a mechanical speedometer cable to turn 1000 times per mile travel - this is how conventional mechanical spedometers operate. But these hybrid early 90's systems are something else - need to refer to FSM to find out. Do not know.... Sorry.
//RF
I hope this helps
"The Beast"
Old 05-30-2012, 12:28 AM   #867
rfmaster
rfmaster's Avatar
This was in reference to fuel pressure regulator???? Or ??
"The Beast"
Old 05-30-2012, 09:19 AM   #868
carboncrew
carboncrew's Avatar
Would this be the easiest/best option? I really didn't consider this because I just finished building/restoring the gauge cluster out of the suburban.
thanks
Old 05-30-2012, 10:40 AM   #869
manimal
manimal's Avatar
Sorry, I was meaning the EGR valve diaphram. The vac would rise to almost 10" and then fall to zero then back up to almost 10" and fall again...constantly. I keep getting the EGR system CEL code.
I have not driven my 'burb very much lately since I got my '82 diesel. But none the less I would like to get it fixed. Thanks
-Lance
Old 05-30-2012, 11:52 AM   #870
rfmaster
rfmaster's Avatar
This is normal operation of the EGR system. However, I suspect that you may have defective EGR control valve - it is being constantly being pulsed by ECM. Over time the vacuum switch (inside EGR control valve) may have developed an intermittent and just stays in a vent position until it gets its 'marbles' again. The duty cycle and frequency of the EGR control voltage pulse determines how much EGR valve opens and allows exhaust to enter into intake manifold plenum.
//RF
"The Beast"
Old 05-30-2012, 01:38 PM   #871
manimal
manimal's Avatar
THANK YOU! I will get a new one,but I also plan to remove the EGR valve and make sure the passages are clean/clear.
Thanks again rfmaster! You're the man!
-Lance
Old 05-31-2012, 12:45 AM   #872
68 TT
68 TT's Avatar
I believe it is. All the gauges other than the speedo from your 91 cluster will fit right into an earlier housing so the work you did is not wasted.
The optical VSS mechanical speedo clusters are pretty cheap and easy to come by too plus the wiring will be just like shown on the stock wiring diagrams for the earlier cable speedo TBI trucks, Suburbans & Blazers. No point reinventing the wheel here when stock parts will do the trick.
Old 06-02-2012, 06:51 PM   #873
kunsan1987
kunsan1987's Avatar
not just TBI trucks,trucks with cruse control used a 3 wire buffer that outputs the correct signal,the 3 wire is gm#25007227
kunsan1987 is offline   Reply With Quote
Old 06-09-2012, 10:55 PM   #874
Slammed67
Progress = 0%
Slammed67's Avatar
Wow, this is a long thread! Lots of great information. I installed a 1991 TBI engine in my '56 Chevy last fall and was successful getting everything hooked up correctly. I'm having one issue though. The car stumbles slightly on acceleration. Tonight I performed some tests on the throttle position sensor. Gray wire is reading 5v, ground wire is good, but the blue wire isn't reading correctly. At idle, I'm not getting any voltage on the meter. I have to move the throttle quite a ways before I get volt reading on the meter and then it jumps up to about +1.6 volts. At full throttle I'm getting about 3.5 volts. From what I've read, I should see about 0.4 to 0.9 at idle and about 4.5 volts at full throttle. I bought a new TPS and got the same results. Any ideas why it's acting this way?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-09-2012, 11:14 PM   #875
68 TT
68 TT's Avatar
Can you rotate / adjust the orientation of the TPS so it starts reading voltage at idle? Mine have slotted mounting holes to allow you to do this. If not you could slot the holes on yours to give it this capability.
