Old 10-07-2020, 05:28 AM   #851
naphtali5725
naphtali5725's Avatar
Re: My new project 86 Silverado
engine as it is at the moment
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 10-09-2020, 11:40 AM   #852
naphtali5725
Russell pump to carb line came in... manual master cylinder and push rod otw...
My build thread...
Disabled Veteran
Old 10-15-2020, 01:59 PM   #853
naphtali5725
Pass fender on
My build thread...
Disabled Veteran
Old 10-22-2020, 09:35 AM   #854
naphtali5725
i should probably start a thread for this. but... just a shoutout basically...
i have a whole bunch of stuff from my build that i'm not going to use because i replaced it.
i'll list them so you know what i have in a couple days. I'm not looking to sell anything, would rather trade , or give away so i can finish up my build.
My build thread...
Disabled Veteran
Old 10-29-2020, 11:34 AM   #855
naphtali5725
Found a manual master cylinder that comes with a pushrod...
It is a Dorman M98952
39 bucks at the usual place online
My build thread...
Disabled Veteran
Old 11-03-2020, 01:24 PM   #856
naphtali5725
alternator bracket on the way...
My build thread...
Disabled Veteran
Old 11-03-2020, 01:34 PM   #857
naphtali5725
Fuel hose, adel clamps came in so I can finish installing the fuel system
my crimpers and heat shrink tubing came in, getting ready to wire the truck finally...
i think i may have to go with 16 inch wheels. the 2 1/2 drop spindles have the lower control arm lip really close to the rims on the 15's... i'll know more when i loosen the cross arm nuts etc. and get the suspension settled. i hope i don't have to change wheels...
My build thread...
Disabled Veteran
Old 11-05-2020, 04:59 PM   #858
naphtali5725
Got master cylinder installed, have to drill a hole about 1 1/2 inches above the factory Clevis pin location on the brake pedal to get the right ratio for manual brakes
My build thread...
Disabled Veteran
Old 11-05-2020, 05:40 PM   #859
naphtali5725
ignition panel on the way...
My build thread...
Disabled Veteran
Old 11-12-2020, 05:44 PM   #860
naphtali5725
got my ignition panel, and alt brackets in! universal turn signal switch came in too, will be installing parts for a few days
My build thread...
Disabled Veteran
Old 11-14-2020, 09:40 PM   #861
naphtali5725
got the new stainless transmission lines installed today!
i know, its going slow,slow,slow...
My build thread...
Disabled Veteran
Old 11-17-2020, 09:36 AM   #862
daddyjeep
daddyjeep's Avatar
It might be going slow, but at least it is still going.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 11-18-2020, 10:41 AM   #863
naphtali5725
exactly... believe it or not, i'm actually working on it more now than i have in a long time lol
My build thread...
Disabled Veteran
Old 11-19-2020, 07:19 PM   #864
naphtali5725
Finally... get to start on this!!!
My build thread...
Disabled Veteran
Old 05-29-2021, 02:40 PM   #865
naphtali5725
sorry for the long absence, things have picked up, parts ordered... first order of business will be the windshield. updates soon!
My build thread...
Disabled Veteran
Old 12-09-2021, 10:51 PM   #866
naphtali5725
lots of parts on hand
life happens but have leveled off...
am i ever going to finish???? smh
My build thread...
Disabled Veteran
Old 12-11-2021, 07:34 PM   #867
NONHOG
NONHOG's Avatar
Looking good!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-15-2022, 11:35 PM   #868
naphtali5725
i know, long time no updates
welded up the spot weld holes in the windshield track, primed and sanded around both front back glass openings
windshield and back glass is getting installed on the 23rd!
My build thread...
Disabled Veteran
Old 04-17-2022, 02:33 AM   #869
naphtali5725
Glass installed finally!
purchased the rubber from steele rubber in denver, NC
My build thread...
Disabled Veteran
Old 01-28-2023, 03:22 PM   #870
naphtali5725
Sorry for the long delay guys
Been a hell of a year
I’m back on it
Old 04-14-2023, 10:17 PM   #871
naphtali5725
New headers arrived
Waiting on my champion 3 row radiator
Part num cc716
My build thread...
Disabled Veteran
Old 04-28-2023, 03:17 PM   #872
naphtali5725
Ordered a Boyd welding fuel tank
I have 2 new saddle tanks and brackets I’ll be selling if anyone is interested
My build thread...
Disabled Veteran
Old 04-28-2023, 03:20 PM   #873
naphtali5725
Received my champion radiator
Cc716
My build thread...
Disabled Veteran
Old 04-29-2023, 11:31 AM   #874
naphtali5725
Going to oil prime the engine today, get the valves adjusted on covers on
Install the water pump and thermostat housing
Hoping to get the engine installed this weekend 🙏
My build thread...
Disabled Veteran
Old 05-04-2023, 05:24 PM   #875
naphtali5725
Got the oil filter adapter on, new filter, dumped 6 quarts zr1 in.
Primed, 60psi oil pressure with just the drill. Oil everywhere
My build thread...
Disabled Veteran
