10-28-2013, 01:13 AM | #8726 |
Re: What did you do to your truck today?
10-28-2013, 10:25 AM | #8727 |
Put the tailgate, tail lights, hidden latches, and rear bumper on last weekend.
10-28-2013, 10:26 AM | #8728 |
Sorry double post... Stupid phone.
10-28-2013, 12:15 PM | #8729 |
Moderator
Lovin the slot mags! Nice score.
10-28-2013, 06:19 PM | #8730 |
Look at what I had made for my truck. Since my last picture posts have been a TKO500 and a 350 block...well, this gives you an idea where this will end up.
10-28-2013, 06:49 PM | #8731 |
Damn that's funny
http://s1299.photobucket.com/user/jb...23904108567829 |
10-28-2013, 09:37 PM | #8732 |
11-02-2013, 03:55 PM | #8733 |
Driver door swapped out today. Nice to have a rust free door installed over my original which need inner/outer lower sections welded in. Fixed the broken window regualtor issue that popped up Monday too. Ill get some pics up later. 2hr start to finish and alignment/fit are great.
It also upgraded my windows to metal framed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-03-2013, 09:07 AM | #8734 |
I want to do one that say's Sublight and Warp!
11-03-2013, 04:18 PM | #8735 |
I fabbed up a trim piece to extent the dash to hide the firewall. Im going to cover up the ignition box too once i get some more stainless pieces. then gotta polish everything
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
11-03-2013, 05:32 PM | #8736 |
Well the day finally ARRIVED, we loaded up and brought the replacement bed to the painters! The only thing left is to but in the step sides inserts. I decided to use them afterall.
11-03-2013, 06:00 PM | #8737 |
Post Whore
Well, pulled my BRAND NEW carb off my truck today. Taking it back to Autozone to do an exchange for another new one. So I get my first one, bolt it on. 30 miles of driving it starts seeping fuel outta the carb gasket and accelerator shaft. DANG! And that was a BRAND NEW carb! Wish me luck! Hoping my exchange carb will work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-03-2013, 06:08 PM | #8738 |
Started redoing the exhaust on my 66 today
Old headers New headers Modifying the crossmember |
11-03-2013, 06:53 PM | #8739 |
Moderator
Put the bed back on my truck. After I picked it up off the driveway. We had a windstorm, and it blew backwards off the sawhorses. It's bent at the bottoms, and the taillight panels, but it could have been much worse. My heart sank when I came home and saw it pancaked on the driveway. It actually looks ok back on the truck.
11-03-2013, 10:31 PM | #8740 |
hate to hear about the damage after all the work you put into it. ive been there myself and its no fun. hope it works out ok for you.
11-03-2013, 10:45 PM | #8741 |
Moderator
It will work out. Looks better now that the bed is (temporarily) back on the truck. It sat on those stands for three months while I worked on it. Big thunderstorms, etc. No problems. One wind storm with 50mph gusts knocked it over. I did learn that it is much easier to put the bed on from the side with the engine hoist. Didn't even move the truck. I took it off the back last time, rolling the truck out from underneath. I should have put it on myself a couple of weeks ago. You know what they say about hindsight...
11-04-2013, 06:12 PM | #8742 |
How about some Corvette manifolds and a hole for a manifold fill pipe drilled into a brand new Edelbrock to go with that 355 small block I posted a week or so ago?
Meanwhile the patient waits for the new plant. Did I mention yet that my daily hay hauler is turning into a lumpy 4.56 geared, Tremec backed 3/4 ton long bed sleeper that will still haul hay and feed to our barn while being a stop light villain, push starting dragsters at the Vintage drags and burning up the drag strip on the weekend for giggles? |
11-04-2013, 06:38 PM | #8743 | |
11-04-2013, 09:36 PM | #8744 |
That T belongs to my friend and hot rod guru Chip Quinn and a fantastic thread on it can be found here: http://www.jalopyjournal.com/forum/s...d.php?t=824491
11-04-2013, 10:08 PM | #8745 |
Now I recognize that roadster! I've seen that thread many times
11-04-2013, 11:11 PM | #8746 |
11-05-2013, 06:06 AM | #8747 |
Nhra heritage series is Jan 10-12, at wildhorse motorsport park
11-05-2013, 01:15 PM | #8748 |
Got my new motor perches installed and exhaust manifolds on the motor. Also installed the radiator and plumbed the heater core etc.
11-05-2013, 01:46 PM | #8749 |
new seat foam,cover... carpet, cleaned up panels!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
11-05-2013, 01:51 PM | #8750 |
more.....
