Old 10-03-2012, 04:18 PM   #876
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
I decided to cancel the pop up gas cap because of the work involved, i started to block the truck and realized that right now its nice and straight and if i install the cap i will only create more work thats not necessary.
Right now the truck body work is complete the only thing that is holding me back from starting the paint procedure is the engine. I need to install some new components i rather wait on paint and do the engine work now that its out and easy to work on rather than rushing and installing the motor and having to work on it when installed. I wasnt satisfied with the comp cam i had so i will be taking care of this issue now.
I will be doing a complete new valve train and cam and stall job and try and get all the horse power i can naturally aspirated while still being streetable not a daily driver but i want to drive this and not worry about grinding a lifter on slow rpms.
I havnt ordered the pushrods until i get the assembly going the rockers are adjustable so in theory i can use anything within the range might eaven use the ones installed now
Their are some limitations in cam choice for a streetable car, RPM range curves, maintenace and so, The bottom half of my engine will be stock for now with that in mind i needed to stay below a .600 valve lift to clear the PTV piston to valve clerance anything close or above .600 will push valves to close to the pistons or possibly crash into, you can solve this either by changin the time or changing the rods or pistons . During my build up will will check my clearance with the puddy technique to be on the safe side. Once i get this installed i will give it a proper tune to get the most of this set up, If i ever need more power i will go to a supercharger and redo my build to match the spacs required.
I will be using the following components
Lunati Hyd roller cam, rough idle. Good all out street performance and mid level race cam. Engine and computer modifications are required.
Advertised Duration (Int/Exh): 283/293
Duration @ .050 (Int/Exh): 224/224
Gross Valve Lift (Int/Exh): .560/.560
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2500-6000
Lunati Street Performance Hydraulic Roller Lifters with the link bars
Lunati DUAL VALVE SPRING KIT
Comp Cam billet double roller adjustable
Melling high vloume oil pump
Jesel Sportsman Series Shaft Mounted Rocker Arms 1.7
APS Farbricated Shrt Valve Covers to clear the taller rockers
B&M LS HOLESHOT 3000 STALL TORQUE CONVERTER
ARP hardware
High Performance MLS Head Gaskets
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 10-03-2012, 05:56 PM   #877
Morfias4Twenty
Morfias4Twenty's Avatar
Just added you on FB!!
Roger Gill
......................_____
.........________//__{\_____
,,,,,,,,,/__(O)__/____/_(O)_/
1967 C-10, 383
1975 C-10, 454 SWB Buckets
Low and Slow Baby!
Morfias4Twenty is offline   Reply With Quote
Old 10-03-2012, 07:02 PM   #878
smokedat
smokedat's Avatar
sweet thanks for the add
Roger Gill
Old 10-03-2012, 08:03 PM   #879
y5mgisi
Second Chance Program
y5mgisi's Avatar
I also added you. Valvetrain specs look fun!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-03-2012, 08:31 PM   #880
smokedat
smokedat's Avatar
thanks, i agree cant wait to hear it scream past 6K lol
Old 10-03-2012, 08:44 PM   #881
mud.man.rj
mud.man.rj's Avatar
Sounds like a very interesting build.
mud.man.rj is offline   Reply With Quote
Old 10-15-2012, 12:25 PM   #882
smokedat
smokedat's Avatar
i got some parts in i still need the taller valve covers and the stall converter and new head gaskets. Here are some pics of the goods
Old 10-15-2012, 12:33 PM   #883
smokedat
smokedat's Avatar
few pics
Old 10-15-2012, 12:35 PM   #884
smokedat
smokedat's Avatar
Old 10-15-2012, 02:26 PM   #885
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
purrrdeeee!!!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-15-2012, 03:58 PM   #886
y5mgisi
y5mgisi's Avatar
Damn nice!
Old 10-15-2012, 04:21 PM   #887
mcbassin
Still Learning
mcbassin's Avatar
Great pictures Alex! parts are nice too.
mcbassin is offline   Reply With Quote
Old 10-15-2012, 07:57 PM   #888
smokedat
smokedat's Avatar
thanks
Originally Posted by 68GMCCustom View Post
purrrdeeee!!!
Damn nice!
Old 10-17-2012, 07:02 PM   #889
smokedat
smokedat's Avatar
today i made a cylinder head stand like the one seen in one of the magazines. In all i spent $40 bucks in supplies shopping at a local hardware store, i could have saved more if i got the steel at a steel supply and the hardware at a Big chain store, but i love and support my local hardware store its only 5 min away. This stand is adjustable and allows the head to rotate and lock into any desired position, and its more sturdy than the little legg things that go through bolt hole and sell for up to $100
Tools
Welder
Bench vise
Drill press (or a heavy-duty hand drill)
grinder with zip disc or chop saw (or a hacksaw)
Grinding and filing tools
C-clamps
Supplies
6-foot, 14-gauge, 1-inch-square tubing (1.0 x 1.0 x 0.083)
2-foot, 16-gauge, 3/4-inch-square tubing (0.75 x 0.75 x 0.065)
1/8 and 3/8-inch drill bits
3/8-inch bolts and flanged nuts (3/8 x16)
9/16-inch wrench
spray paint (optional)
Grease and wax remover (optional)
Old 10-17-2012, 07:04 PM   #890
smokedat
smokedat's Avatar
Old 10-17-2012, 07:06 PM   #891
smokedat
smokedat's Avatar
These are more expensive and i think inferior.
Old 10-17-2012, 10:22 PM   #892
mcbassin
Still Learning
mcbassin's Avatar
Dig the head stand killer idea and fab work.
Old 10-18-2012, 01:32 AM   #893
68 TT
Still plays with trucks
68 TT's Avatar
Nice work Alex. Great idea on the cylinder head rotisserie.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-18-2012, 05:01 PM   #894
Gordonr1973
Home Built '87
Gordonr1973's Avatar
That's a great idea!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 10-19-2012, 07:46 PM   #895
Yezzi
Yezzi's Avatar
Nice work!
Yezzi is offline   Reply With Quote
Old 10-19-2012, 08:53 PM   #896
68GMCCustom
I forget what your cams specs are...but I think you'll like the cam that you're going with. My motor is a 6.0L running the L92 heads. I run a Comp LSr cam that's just over .600, but its OK on ptv. It may be since its an LY6 and it has fly cut pistons to clear the valves for VVT (that I took out). Specs are 223/231@ .050 with .610/.617 lift and a 112 LSA.
anyway....this might give you some idea of low-mid range power. if you listen close, it starts to spin the tires in 2nd... just before I pushed it a little harder and it shifted all the way down to 1st.
http://youtube.googleapis.com/v/BkpCYMiU6-c
Kurt -
Old 10-20-2012, 12:53 PM   #897
smokedat
smokedat's Avatar
Wow sweet vid,.. now thats a rocket ship you got there, seems like a fun ride. Good job on the position of the camera too, great in cab perspective, did you use one of those GoPro cameras?
Old 10-20-2012, 12:57 PM   #898
68GMCCustom
Thanks. yes its a gopro. finally getting the efi working correctly and making some power...truck was carb'd.
Kurt -
Old 01-04-2013, 09:36 AM   #899
mcbassin
Still Learning
mcbassin's Avatar
What's up Alex? Hope you had good holidays. How's the project coming?
Old 01-11-2013, 06:07 AM   #900
squaredaway
squaredaway's Avatar
Hey Alex, I saw this over on Garage Forum and thought of your truck! This is on an '81 C 10. Anyway, hope you are doing well.
1987 Silverado
6.0/4L80E
5/7 Drop, 20x8.5(245/45)/20x10(295/45) Coy C5s
squaredaway is offline   Reply With Quote
73c10, c10, cheyenne, ls1, swap
