10-03-2019, 09:49 AM | #876 |
Re: What did you do to your truck today.The 3rd chapter
rechinca, that's exactly the same repair that I am working on.
10-03-2019, 10:19 AM | #877 | |
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-03-2019, 10:26 AM | #878 | |
1970 GMC 1 Ton 9 foot Stepside |
10-11-2019, 10:23 AM | #879 |
Made a beverage holder😁
10-12-2019, 06:04 PM | #880 |
Got the rear part of the cab's body work pretty much done. I'll epoxy prime it tomorrow and get some high build on it. Nice having ot to strip to bear metal. So far the drop rails look great.
10-12-2019, 06:08 PM | #881 |
One more
10-12-2019, 08:31 PM | #882 |
Nice work. Easy day for me. Replaced headlamps with Sylvania Silverstar sealed beams.
Changed my TH350 speedo driven gear from 20-tooth to a 24-tooth and verified the speedo with a GPS phone app - right on target. 5% per tooth rule of thumb worked for me as my speedo was reading 20% higher than GPS MPH. Added a spare tire carrier from LMC and bolted in the spare tire. Added a kill switch to the HEI tach lead and tested a few times - works great. |
10-13-2019, 03:51 AM | #883 |
I upgraded to led lights all round. Besides reverse or headlights.
https://youtu.be/nmTLkR-0obk
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
10-13-2019, 03:03 PM | #884 |
Found the exhaust leak 😄
10-13-2019, 03:07 PM | #885 |
10-13-2019, 03:15 PM | #886 |
Painted the visors, stuff works great! Will do my seat next. Changed my kinked fuel line that was long overdue.
10-13-2019, 04:26 PM | #887 |
I’ve got the new (old) manifold cleaned up and installed. Also new carb and distributor.
10-13-2019, 09:47 PM | #888 | |
Old member
I cleaned up a set last week for my daughters 68 step also. Wire brushed and wiped down with brake cleaner then painted black caliper paint.
10-14-2019, 03:22 PM | #889 |
Painted the rear part of the cab. Paint area was a little too cool when I turned on the exhaust fan . I'm using a large ezup with sides . I got a couple minor sags but I got it in the sun now . Debating on whether I will fix them or just leave them. That's the price you pay for using single stage paint.
Not going for show a truck just a real nice driver. That you wont mind taking to a show
10-14-2019, 09:56 PM | #890 |
No photos but got the upper rear shock mounts off and two of the four rivets in the rear most frame cross member out. I’m prepping to paint the rear of the frame and know I’ll be re locating the rear shocks so those parts gotta go.
Guess the truck was stuck at least once and someone connected the chain to that rear cross member and pulled a hickey in it. Buddy of mine has a spare frame so I’m gonna get a straight one from him but figured the frame would clean up better with the old cross member out. Hope I’m blasting the rear frame section this weekend.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
10-15-2019, 10:27 AM | #891 |
Old member
Got the Delco-Pleasure lift gauge mounted and air up the air tank on the ramp truck then took it for a ride.
10-20-2019, 08:02 PM | #892 |
Lots of people would not call this progress but I know this crowd appreciates the level of time and effort to get to this point.
Started with just pulling the drive shaft and removing the long rear brake line. That went so well I decided to cut the springs out. Then that lead to cutting the rear end u bolts. What the heck, wonder if soaking the trailing arm bolts for weeks has paid off. Now all I have to do is clean it all up. Got rust encapsulator and frame paint just need time and a pile of parts.
10-20-2019, 08:08 PM | #893 |
Installed a new master cylinder. New NAPA calipers and hoses. Powerstop drilled & slotted rotors and pads. Stops great now. Pedal doesn’t sink to the floor at a stop light.
10-20-2019, 09:44 PM | #894 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-21-2019, 07:59 AM | #895 |
Working on the power steering this week , This is a 67 short bed frame that wasn't dimpled for a power steering gear , at the bottom left of the picture you can see where I modified the frame just enough to fit the box without going crazy with heat and a BFH to make it fit , It really doesn't take much to have it fit and still look clean . Just waiting on the new pump and pulleys to show up and chase down some stainless steel lines .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 10-23-2019 at 11:30 AM. |
10-21-2019, 08:05 AM | #896 |
Took it to my first judged show and received best of show for my class.
10-21-2019, 08:37 AM | #897 |
Quaker steak and lube on 49th st ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-21-2019, 08:39 AM | #898 |
10-21-2019, 08:46 AM | #899 |
10-28-2019, 07:58 PM | #900 |
Got my power steering pump and stainless lines in today , One more bite off the elephant .
