01-15-2013, 12:42 AM | #901 |
Re: Junkyard Jimmy Super Low Buck Build Thread
Great progress man
1971 GMC Sierra 1959 GMC 100 |
01-15-2013, 07:54 PM | #902 |
GEARHEAD
Thanks! The only way to get these projects done is to just keep doing something on it.
Finished with my work a little early today so I went out and sanded some more. After spraying the primer the other day I thought the hood kinda looked like crap. But after looking again today, to decide whether or not I needed to fill some spots before I moved forward, I decided it wasn't as bad as I thought. So I got the roll of 180 grit and moved on. Most of the spots I was concerned with sanded out. I ended up just using a tiny bit of filler in a few spots. I just finished sanding those out and it's ready for the next coat of primer and the next grit. It's actually looking real good. I also sanded the cowl with the 180. I really just sanded the ends with a flexible block, then did along the front and rear by hand, then just used a scuff pad on the vent bars. Then used it on the rest of it too. I could probably paint it as it is, but I'll probably spray a coat of primer and smooth it out the same as the rest of the truck. I scuffed the drivers fender with a short block just to find the obvious highs and lows. Smacked the highs down a bit, then I mixed up some filler and got the first layer of that on. (no pic) I'll sand it down another time. 4 hours of sanding is enough.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-15-2013, 07:55 PM | #903 |
Never get discouraged though !!!
Your doing great
01-18-2013, 06:54 PM | #904 |
GEARHEAD
Took a few minutes and set the cowl and hood on the jimmy. Nothing is bolted down or really adjusted. I need to shift the radiator support to the left a smidge to square it up so the hood will settle in properly, but the initial fit looks pretty good. I was kinda worried more about the fit of the hood crown side to side to the cowl, but it was good.
01-18-2013, 07:18 PM | #905 |
6>8 Plugless........
Your hood project turned out awesome! I know what you mean about putting it on and sanding it back off. It drives me nuts! But the end result is always worth it. Plus you save your self big bucks. Keep at it, it is looking great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-19-2013, 03:54 PM | #906 | |
GEARHEAD
As for sanding it back off, yeah, doing some more of that. Sanded the fender this morning, then sprayed a few more coats of primer on that and the door. The door will be next. Another body work chore I'm not fond of is taping. All the stuff that I already painted needs protection from the new coats of primer. PITA. Any way. Pic for the day. Might get back out there tomorrow for more of the same.
01-20-2013, 07:07 PM | #907 |
GEARHEAD
More progress. Any guesses as to what I did?
Got the door and fender sanded again. I missed a couple very small spots I need to fill, but other than that they are both ready for primer and the final blocking. I was sick of sanding after that. My grill was sitting on the saw horses. I am getting ahead of my work flow here a bit. Won't be needing a grill for a while yet, but I've had a plan for a long time to try out some black chrome. After reading the reviews about the kit that is available I decided to go a different route based on some things I've read and learned from other members projects and elsewhere online. I took off one of the headlight bezels and cleaned it up with steel wool and some wax/grease remover (not at the same time). I had a little clear coat in a small can to use up, so I mixed that up like normal, then added a few drops of black tint. At first I thought oh crap, it turned completely black from just a few drops. Then I pulled out the mixer I was using which is shiny stainless steel and I could still see through the paint and see the steel. I have extra bezels around, so I decided to go for it and find out what happens. Not bad. In fact its about perfect. Just what I was going for. The pic doesn't really show it well because the flash made the black go away on the inner part, but you can see the grey around the edge, which is what the whole thing actually looks like. Better pics below. Note the nasty looking grill I'm starting with. While that was drying I started cleaning up the rest of the grill parts. Then the real test came. I needed to show the wife. She liked it, so time to move onward and keep cleaning parts. This pic is showing the bezel by the unpainted fender eyebrows. The rest of it...
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 01-20-2013 at 07:24 PM. |
01-20-2013, 09:12 PM | #908 |
thats pretty cool
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
01-20-2013, 09:58 PM | #909 |
That's kinda neat, sorta subdued lookin! Keep it up, whole thing looks great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-24-2013, 03:37 PM | #910 |
GEARHEAD
Got tired of work today, so I spent the morning out in the garage instead.
Didn't get a lot done. Had to move a bunch of crap around to work on the bedside. Then I got distracted and started cleaning up an old aluminum cooler I got a while back. I went over the bedside with a long block to find the highs/lows and it was already pretty good. Just needed some filler in a few spots and mainly around the tail light, which had been smacked in pretty bad. I had repaired/straightened the area like a year ago I think. So I'll let that set up and sand it later. I got the featherfill primer the other day and might try that out on the bedside. I'm starting to see the light at the end of the tunnel. Hood, cowl, tailgate, driver side fender and door are ready for final blocking/sanding. Get this panel done, turn it around it should not take too long to finish up the other side. Might get it in the paint booth in February.
01-24-2013, 07:00 PM | #911 |
That hood came out great from what I can see!...very nice, but subtle effect...If you didnt know any better, or know the hoods, it would look "custom somehow".....almost factory....
I like the effect you got with your "black chrome" look on the trim pieces. nicely done JP |
01-24-2013, 07:29 PM | #912 |
Awesome work! I tried the black chrome Dupli-Color kit on the bumpers for my 40 ford. It sucked and I wasn't impressed at all. I do like your approach though, it looks really nice! If my bumpers were that nice on my 40, I'd do it to them.
01-24-2013, 09:51 PM | #913 | ||
GEARHEAD
One mistake I made was that the clear recommended one part reducer, and I think it was just enough to cause a few runs. It's noticeable in a couple spots but I can live with it.
01-26-2013, 10:31 AM | #914 |
The Jimmy is coming along nicely. It sounds like you are in the doldrums of bodywork like me.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
01-26-2013, 03:33 PM | #915 |
GEARHEAD
Sounds, looks, tastes, smells and feels like the doldrums. Absofreakinlutely. Fab work, hammering, cutting, welding etc. is all good. Finding motivation to go back out there and sand some more is tough.
01-28-2013, 09:08 PM | #916 |
The good news is once you get fresh paint on it your interest and energy levels will through the roof!
01-29-2013, 11:12 AM | #917 |
GEARHEAD
Didn't do much this past weekend. Was feeling down, had a cold, no motivation. Yesterday I got off my ass though and at least made an effort. Before I could do much more on the rear end I need to clear some things out of the way. So tailgate is off, bumper is off, tailgate hinge trunions and latches off, brackets to hold the side panels in the bed (CST) off, tailgate seal parts off. Vacuumed it out and now I just need to wire wheel some paint and surface rust off it. Then I can do more taping and primering and move forward again.
01-29-2013, 11:20 AM | #918 |
GEARHEAD
On another note, while laying around like a slug, the wife and I caught the end of an Overhaulin episode for a gold and black VW beetle. I liked the 2 tone with the black and the gold is very similar to what I'm spraying, so I ask the wife what she thinks and she really liked it. It was a gloss black and I'm thinking flat or satin, but the color combo would look great. I was thinking I could do either all black across the upper section (mustang mach 1 style) or maybe even a pair of racing stripes (camaro style).
01-29-2013, 11:27 AM | #919 |
Just a nother gear head
thats a cool car. unfortunitly i cant watch overhualing cuz i dont get that channel threw direct tv. i like the black on top idea for your jimmy. it will look nice.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
01-29-2013, 02:03 PM | #920 |
I would not do racing stripes. Thats for something sporty.
Maybe the top half, and a slight "pinstripe" along the edge? Or do the traditional two tone, but do it flat black rather then shiny? |
01-30-2013, 12:15 AM | #921 |
GEARHEAD
Are you saying my hotrodded old school jimmy with aluminum slots aint sporty? Haven't you seen my super slick low profile customized hood? This thing is ooozing sporty. I'm almost afraid the racing stripes would just blow off from the wind blasting over the hood.
01-30-2013, 09:10 AM | #922 | |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
01-30-2013, 05:28 PM | #923 | |
GEARHEAD
Wonder what the 90s version will look like?
01-30-2013, 05:32 PM | #924 |
GEARHEAD
I was thinking more like Dales top half of the hood with a stripe, but instead it would just be on the top flat and not down over the sides and front at all. I'm sure there are pics out there that have it but I'm too lazy right now to look for them.
01-30-2013, 09:10 PM | #925 |
I think the flat black on the hood and a stripe like the old Mach 1's would be cool. I agree, I wouldn't do muscle car racing stripes unless that's just your thing. To me, if they're on a truck, that better be a super fast truck.
