#901 |
Post Whore
![]() Join Date: Aug 2014
Re: A '54 named Busty
#902 |
Post Whore
so here is my 1954 to 2004 LS Swap To Do list:
1. Install transmission crossmember, the B&M shifter 4L60E cable bracket, run custom steel braided lines and 6 AN fittings to radiator Last edited by Gregski; 06-15-2020 at 12:52 PM. |
#903 |
![]() Join Date: May 2007
nice work on the swappin!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#904 |
Post Whore
So I'm at a bit of stand still waiting on the 4L60E transmission crossmember to arrive, so took some pics of the little tickle I gave to the trans tunnel front lip to slide the gearbox under it, I may hammer and dolly it nice and flat some day (probably not, ha ha)
I also regret not lifting the tunnel cover to clean it's border properly prior to priming, painting, and undercoating it, oh well |
#905 |
Post Whore
I also couldn't help myself and set the intake on the 5.3L just to see her in full bloom, she dusty from sitting on the garage shelf for almost a year, but she fit right in - looks like she's going 45 MPH just standing still, don't it, ha ha
I sure aint worried about hood clearances with that tall hood |
#906 |
Are you sticking with the clutch fan or going electric?
#907 |
Post Whore
#908 |
Clutch fan working well could depend on height of engine and what is blocking air flow for it. Maybe pre wiring is a good idea
#909 |
Busty is looking so good. I'm jealous.
#910 |
Post Whore
#911 |
Post Whore
so why WE are still waiting on parts, I decided to do what I do best and focus on things that involve huge amounts of work with not much to show for...
#912 |
Post Whore
... project Flatapus
#913 |
Post Whore
surely but slowly it's getting there, and mind you I only bid this job because of its hideability factor, it's not like we are fixing the hood or the roof of a split window Corvette ... so, carpet and paint makes me the welder I aint
#914 |
Post Whore
the transmission crossmember arrived today and it is such a nice piece, and made for such an easy install, the two bottom holes of each bracket lined up perfectly with two existing holes on the C channel stock truck frame rail, it was unreal - I am calling this my even a blind squirrel finds a nut sometime moment
all I have to do is drill two more top holes on either side and Flo's your aunt |
#915 |
Post Whore
motivated by the easy transmission crossmember install I pressed on, anyone's who done an LS Swap will tell you the devil's in the details
here I am installing the heater core delete crossover horse shoe Note the nipples are of different size as is the specialty bypass hose |
#916 |
Post Whore
this proved much more difficult then it appears, I had to keep trimming the rubber hose 1/4 inch at a time until it cleared the suspension upper arm knuckle thingie
#917 |
Post Whore
the power steering hoses were next, usually I unscrew the high pressure hard line from the back and screw in one of my old square body nipples in there, but today I felt like making some spaghetti
#918 |
Post Whore
so with the engine and transmission mounted in place it was time to give the ol' stock exhaust manifolds a trial fit, and no dice, Houston we have a problem!
#919 |
Post Whore
the thought of cutting off the three bolt flanges and re clocking them did cross my mind (as these are cast steel and not cast iron) however I decided to throw money at the problem instead, especially since Summit sales copy cat Hooker two bolt flange manifolds for half price $170, score!) and no, no headers for me I'm much too old for that rodeo
I also picked up some Hooker down pipes as they had the O2 bugs already in them and a matching two bold flange, winning Note: I am running the Hooker 2.5" manifolds on my '74 LS Swap and I will tell you that they ain't 2.5" at all they are more restrictive than stock - very dissapointing! |
#920 |
Post Whore
So here is our LS Swap - Progress Report Card - LSS-PRC
#921 |
if you know your center to center u joint distance, you can usually find a driveshaft that is exact or close. if I had to guess from your engine placement you will need a 53" center to center? reg cab short bed s10 is 53", the slip yoke will fit your trans and the rear u joint should bolt to whatever is in back.
if you are going to order one make sure you measure center to center with weight on wheels, and leave 1-2" stickout on the slip joint.
#922 | |
Post Whore
I like to run 3/4 to 1" stick out on my yoke in the transmission, so 54 1/2" gives me 1" exactly, so I'm afraid the s10 will be too short |
#923 | |
it looks like your passenger head is tucked right against the firewall, thats usually a 53" for mine when its like that, not based on the engine but the trans bellhousing of the 4l60e. interesting, is all. thats on 118" wheelbase too, yours is presumably still 116.
#924 | |
Post Whore
and here's a better look at my passenger side cylinder head, seems almost even with the firewall, I know pics can be misleading because of the perception angles |
#925 |
here they pull the driveshafts first, and poke holes in the gas tanks
