Old 11-30-2012, 07:39 PM   #926
raws67
raws67's Avatar
Re: Tbi swap build thread
As others have already said thanks what a great thread for the TBI swap! I am still gathering info and in the planning stages for my TBI upgrade. I am at a point right now where I need a little guidance on the Drac issue. What I have and plan to install with the TBI is a 90 corvette 700r4 (will manufacture rear mount for vette tailhousing) with the 4 pulse vss and I also have a 90 suburban speedometer I want to use. I need to know if a DRAC will even work if I am going to use a 7747 ECM or do I need a 90+ TPI ECM? Or any other suggestions?
truck is a 78 SWB BIG10 3.42 rear
350 goodwrench w vortec heads, weind street warrior intake,
Crane cam 100052 (cam specs)
Intake Duration at 050 inch Lift:216
Exhaust Duration at 050 inch Lift:216
Duration at 050 inch Lift:216 int./216 exh.
Advertised Intake Duration:272
Advertised Exhaust Duration:272
Advertised Duration:272 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Valve Lift with Factory Rocker Arm Ratio:0.454 int./0.454 exh.
Lobe Separation (degrees):110
1.6 roller tip rockers
2 1/4 true duals with super 44's (plan is for ceramic chevelle headers when I do the upgrade and weld 3 wire 02 right after collector flange)
Has no emission requirements so EGR I am not worried about but will most likely install purge tank from donor. Also do you feel that an alt upgrade would be needed from the stock one considering the extra juice needed?
Right now I am stuck in the planning stages and need to know if the 4 pulse vss is going to work or an idea on what would be the best route with what I have. Thanks
raws67 is offline   Reply With Quote
Old 11-30-2012, 09:28 PM   #927
rfmaster
rfmaster's Avatar
You will need the DRAC to convert AC 4000 ppm signal coming from VSS. The DRAC will provide correct 2000 ppm square wave signal to the 7747 ECM. You do not need 90+TPI ECM. DRAC will also provide 4000 ppm square wave signal to the electronic instrument cluster from 90 burban. Alternative to DRAC is a dakota digital SGI-5 can do the same without DIY alteration of the DRAC to account for tire size, rear end gear ratio and VSS reluctor gear.
Problems
Crane cam 100052 has duration @0.050 216/216 with LSA of 110. This is a good carburetor camshaft, but it will make MAP sensor very unhappy! I am going to guess your idle vacuum is only 12 to 13 in-Hg at 700 RPM with plenty lopping. Even modified 7747 will have problems at idle. The kicker is 216 duration and tight 110 LSA. If budget permits go for a cam with duration around 210/210 and LSA more than 112 deg. You'll loose a little bit of top end power, but your idle will smooth out.
Close alternatives are Comp Cam 12-365-4
Lift I/E .499/.493
Duration @0.050 216/220
LSA 113 deg
If you heads can not take this much lift Speed Pro CS1013R can be a good candidate
Range 2000-4500 RPM
Duration @.050 214 intake/224 exhaust,
Lift I/E 0.443 /0.465
LSA 112
Disabling EGR is straightforward in EPROM. To get the full power of this engine expect to DIY tune. Please be aware that Vortecs do not require too much timing ~ 32 deg maximum at 3000 RPM vs 36+ for conventional heads. Thirdgen.org has extensive articles that covers this in fine detail.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 12-12-2012, 03:41 PM   #928
raws67
raws67's Avatar
Has anybody used the 88-95 headers with this swap? Just wondering because I would rather use headers with the o2 bung already installed vs retrofitting one on the pipe after the collector.
Old 01-13-2013, 07:01 PM   #929
jasons
not enough hours in the day
jasons's Avatar
I have a couple questions about my swap. The engine is out of a 88 pickup and going into my 70 Blazer. The air pump was not hooked up and I am going to remove it and use stock 70 manifolds. I tested the EGR valve and it does not operate with vacuum applied. I drove the pickup before pullling the engine and it ran good.
Is the EGR valve necessary, or would I be OK just blocking it off?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 01-13-2013, 07:06 PM   #930
jasons
jasons's Avatar
My 88 engine has two temperature senders. This one in the intake
and this one in the head
Is the one in the intake for the computer and the one in the head for the guage?
It also has this oil sening unit by the oil filter
Is this for the guage and can I eleminate it for the mechanical guage?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 01-13-2013, 07:12 PM   #931
MAX85C10
No you do not need egr. If you wish to use your stock intake manifold you can get a block off plate for it or get an aftermarket intake that doesn't use egr. I assume you're using th tbi with ecm so you may have to remove egr from the ecm via a flash, or new prom.
MAX85C10 is offline   Reply With Quote
Old 01-13-2013, 07:42 PM   #932
jasons
jasons's Avatar
I belive the prom has been changed, but I know noting about it. If I block off the egr and don't flash the ecm what problems would this cause. I'm thinking a new egr for $50 would probably be easier and no more expensive than sending the prom off somewhere to be flashed. Are there any benifets one way or the other?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 01-13-2013, 08:20 PM   #933
MAX85C10
Depends on what you're going for, if you're looking to pass emissions then you will need the egr system. But if your going for a cleaner look then you will definitely want to delete egr. You shouldnt see a difference in economy either way just emissions will suffer. Im not exactly sure what will be affected if you do not delete it in the ecm. I dont imagine it would affect anything. Maybe someone else can chime in here.
Old 01-13-2013, 09:25 PM   #934
jasons
jasons's Avatar
I'm not concerned about emissions. I want reliability and hopefully better than 10 mpg.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 01-13-2013, 11:59 PM   #935
rfmaster
rfmaster's Avatar
You should get better than 10 mpg with TBI unless you have very heavy truck and high gears.
EGR can be blocked off for the non emission application - stock EPROM can not be easily altered (it is an ancient UV erasable 2732A from 70 and 80's). A new EEPROM based on FLASH technology can be sourced with EGR disabled from several outfits or DIY. Interestingly enough functional EGR provides gas mileage improvement, but the difference is very small.
About sensors in your photos
#1 2- wire CTS near thermostat housing - this is one is must have. This provides coolant temperature to ECM.
#2 1- wire sensor screwed into cylinder head (looks like TU-5 or TS-6) - this drives you dash gauge. Can be optional.
#3 oil pressure switch for the oil pressure light - again this can be removed and plugged.
//RF
"The Beast"
Old 01-14-2013, 09:49 AM   #936
jasons
jasons's Avatar
//RF
Thanks, that is what I thought.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 01-15-2013, 10:39 AM   #937
jasons
jasons's Avatar
rfmaster,
I see a couple pages back you were testing temperature sending units. I need one for the gauges in my 70, but the heads are threaded for a 3/8" sender and the one for my Blazer is 1/2". Do you know of a way to get around this?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 01-15-2013, 12:14 PM   #938
rfmaster
rfmaster's Avatar
rfmaster,
If you are referring to a temperature sending unit (single wire) for use with dash gauge the closest equivalent is used by fords F5CF-10884-AA, F5CZ-10884-A.
At first look (TU201) measured:
45C 805 Ohm
98C 100 ohms
I have not had a chance to fully characterize this unit as I have been busy with other projects. It may be close enough to OE AC-Delco G1852 sending unit - after being fully characterized. Equivalent aftermarket replacement units are available from usual parts sources:
Autozone, Duralast / Temperature sending Unit: TU201
Rock Auto still has some from defunct parts maker Kem Parts: TW186
Are you sure that you have 3/8"NPT in your heads? Vortec heads are drilled and tapped for 3/8NPT sensor mounts, while common Gen 1 heads use 1/2NPT (aka dry seal).
//RF
"The Beast"
Old 01-15-2013, 12:19 PM   #939
jasons
jasons's Avatar
Yes, I'm talking about the one wire sender for the gauge. I picked up a new one yesterday for a 70 which is 1/2", when I went to install it in the head I discovered the head is tapped for 3/8".
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 03-12-2013, 11:42 AM   #940
rfmaster
rfmaster's Avatar
Ok Guys.
This thread has been languishing for a while so I've decided to add a bit of swap related information.
It has been mentioned that bolting L31 - vortec heads (casting # 602, 906) nets 40+ HP over stock smogger heads. This swap has been covered extensively by performance magazines and countless gear heads elsewhere. This is a great swap for some one on the tight budget, but it is not without its pitfalls. A stock TBI system uses swirl port heads, but will adapt nicely to Vortec heads.
To use L31 heads on Gen 1 block (assuming 350 CID TBI) will require standard head gasket and vortec specific intake manifold and intake gaskets. If the EGR valve is to be retained exhaust gases will have to be plumbed via custom pipe to EGR inlet port on the manifold. If EGR is to be omitted modification to EPROM will be required. All of the above has been covered before.
The issue is that our trucks use 1/2 NPT sized temperature sending units that screw into driver side head providing resistance vs. temperature signal to the instrument cluster gauge. Original GM sending unit is no longer available (GM 1513321) and the closest equivalent is AC-Delco G1852. Aftermarket produces similar units such as Wells TU5, SMP TS6 among many others. None of these sending units will screw into Vortec heads which are drilled and tapped for 3/8 NPT sensors. It has been suggested that 1/2 NPT sensor units can be turned down on a lathe. However, not everyone has a access to one. Drilling and tapping Vortec Head for a larger sensor (1/2 NPT) can be problematic - sensor boss area is very small and CI can be unforgiving.
This begs a question -are there any 3/8 NPT temperature sending units that will work with square body temperature gauges??? In the past it has been suggested that a Ford F5CF-10884-AA , F5CZ-10884-A, Motorcraft SW5051 can be a possible substitute. Lets take a look if it is even close to what we need.
Test setup - side by side TU5 vs Motorcraft SW5051 mounted into the same AL block.
Measurement setup 2x Fluke 70 DVM + Fluke 52 Temp sensor meter (in my kitchen - the old lady gave a permission). Ideally, I would rather do this characterization testing in the environmental chamber which allows for soaking at a specified temperature, but it is not available at this time.
Test result speak for themselves. When engine coolant is below 50C SW5051 has high resistance which result in a lazy gauge (not reading anything), but above 78C the SW5051 has lower resistance and would result in a higher indicated temperature then it really is!
Zooming into high temperature coolant area.
Cross over occurs right around 76 to 80C region.
AC Delco G1852 (found on Internet) data stops at 100C (212F) - I do not have this sensor at this time, but would like to re-run it to see how it behaves between 100 and 135C.
Next step is to validate SW5051 with the actual gauge.
Suggestions???? Questions???
//RF
"The Beast"
Old 03-18-2013, 12:49 PM   #941
BigrobDog
when u ran new lines did u run steel or were they rubber. just asking because i did a swap and need to move the tank but they are all steel and was wondering if i cut out and replace with rubber
BigrobDog is offline   Reply With Quote
Old 03-18-2013, 01:04 PM   #942
rfmaster
rfmaster's Avatar
I used a combination of 3/8" (SUM-G2538) aluminum fuel lines and short 3/8" SAE 30R7 fuel line which are rated for under 50 PSI working fuel pressure. There are two reason why you want to use metal lines. One that a metal tubing offers lower flow resistance and second that it last a lot longer then a rubber tubing. SS tubing is nice, but it is a real PITA to work with - very hard to bend and bedding of the ends is next to impossible with conventional tools.
//RF
"The Beast"
Old 03-23-2013, 12:52 PM   #943
jasons
jasons's Avatar
I have a plug from my doner 88 pickup harness that I'm not sure what to do with. One wire goes to the computer labled Air Pump and the other is labled EGR Relay. Did this plug into the air pump? I dont have it anymore to check and it wasn't being used on the donor vehicle. Can these two wires be eliminated or do they plug in somewhere I'm missing?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 03-23-2013, 05:48 PM   #944
rfmaster
rfmaster's Avatar
You'll have several options, but both require that you have EPROM burned that has EGR function disabled. AIR pump elimination does NOT require EPROM changes.
1) do nothing - just let them flop or tape them to the harness.
2) Remove connector ends and tape-up end of the wires and hide them in the main loom. Simple enough and quick.
//RF
"The Beast"
Old 03-23-2013, 08:23 PM   #945
jasons
jasons's Avatar
//RF
Where did this plug in? Is there a way to utilize the EGR without the air pump?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 03-24-2013, 03:12 PM   #946
rfmaster
rfmaster's Avatar
So let me understand this correctly. You want to remove AIR pump, but you want to keep EGR valve??? Right ?
If this the case the EGR system uses EGR control valve which is mounted on a bracket bolted to intake manifold on the passenger side. ECM is uses PWM control signal to control amount of vacuum that reaches EGR valve. You can simply remove plug used to control AIR pump and individually tape of wire ends
On this bracket you'll find MAP, ESC module and EGR control valve. On the photo the EGR control valve is mounted on the backside, upper middle of the bracket (you can see white and pink wires protruding).
//RF
"The Beast"
Old 03-25-2013, 06:41 AM   #947
BigrobDog
truck starts and runs great , but when going down the road and wanting to step hard on the gas truck bogs way down , but if u ease in to it easy it runs fine, here is my couple of questions, i used a wiring harness from 90 suburban,put it all on after wards i had to add 12 volts to the injectors, and to the fuel pump relay. and tie my fuel pump wire in to the relay .then it started right up.but i do not thing it is right, at end of harness for tbi goes in to the fuse box and right now that is not attached to nothing, not exactly sure on how to wire up that tbi,also i dont have the trouble shooting plug are the check engine light hooked up . does that go to end of harness some wear,can some one give me some info on hooking up this tbi harness,
Old 03-25-2013, 08:11 AM   #948
jasons
jasons's Avatar
//RF[/QUOTE]
Thanks RF, that picture is what I needed. This is the wire for the EGR control valve. Somehow I missed the empty plug when I was running the wires.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 03-25-2013, 11:21 AM   #949
rfmaster
rfmaster's Avatar
@ Dog
It is tough to diagnose what you have going - can you upload couple of good quality photographs of what you have setup and connected? The part of any swap is to document and capture what you have done as when something goes bad you'll have a way to troubleshoot.
From memory - I have pulled 90, 92 burban engine bay harness before. The plug that bolts into firewall bulk head connector (reference designator C100) under brake booster is used ignition and starter solenoid.
Ckt #3 Pink Ignition coil
ckt #430 pink-blk fuel injection power
ckt #120 tan-white Fuel pump supply
ckt #330 orange Battery B+ (always hot)
//RF
"The Beast"
Old 03-25-2013, 09:44 PM   #950
BigrobDog
ok this is what iv got going , i have read some what every body is written and iv gotten some info, some other questions are about the alternator 90 suburban has 2 wires that come out the side of alternator have been cut and just laying there, I also have the original harness from the 72 on the truck , thoes wires that go 2 the alternator is a fat red that bolts to back and a plug white and a blue wire that would plug in to the 72 style alternator, what do i do with all these wires, the plug on the alternator that is there now from the suburban i under stan needs a ground and the other goes to a light is that right, and what do i do with the wires to the 72. they look like they go to the stock 72 voltage regulator that is in the pic '' black box''. and do i need to hook up the o2 sensor and the park neutral switch to the computer, was reading , if park neutral is not hooked to computer then the computer doesnt read the vss and then wont adjust for timing .. I sure thank evrey body for there help .
