Old 07-01-2013, 02:26 AM   #926
mud.man.rj
mud.man.rj's Avatar
Re: LS1 into a 73 cheyenne
LS is coming together nicely, sure is different than a Gen 1 engine isn't it.
mud.man.rj is offline   Reply With Quote
Old 07-01-2013, 01:26 PM   #927
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Looks good. be aware that you may (from what I've read) have to trim the inside of the timing cover a bit to clear the double chain/gears
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-02-2013, 01:31 AM   #928
smokedat
smokedat's Avatar
Thanks for the input, i'll take close attention to this. still few days away from installing pump
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 07-02-2013, 01:42 AM   #929
smokedat
smokedat's Avatar
I finally completed the Camshaft Degreeing Procedure. I tried the method of just lining up the dots to see how close it would be and then i degreed it and compare results. By simply lining up the dots i was advanced 6*. Following the centerline method and actually degreeing the cam i was right on the specs. from the cam card
Old 07-02-2013, 11:06 AM   #930
mcbassin
Still Learning
mcbassin's Avatar
Looks like some very nice tools. I wouldn't expect anything less. Keep the updates coming.
mcbassin is offline   Reply With Quote
Old 07-02-2013, 01:25 PM   #931
docstheman
docstheman's Avatar
Wow, really sweet build!
~ It's a Learning Process ~
Click Here for my Blazer Build: 1971 Blazer 4x4
Click Here for my Work Truck Build: 1970 C10 LWB
Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F
docstheman is offline   Reply With Quote
Old 07-05-2013, 12:19 AM   #932
68 TT
Still plays with trucks
68 TT's Avatar
Great pics Alex. Love the antique look you gave some of them too.
Making good progress. Nice to see you back at it. Keep it up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-05-2013, 07:38 PM   #933
smokedat
smokedat's Avatar
Thanks, pics are a very important part of the build so i try and make them appealing
Old 07-05-2013, 07:55 PM   #934
smokedat
smokedat's Avatar
I have completed the head assembly mock up and clearances are now good. I also need new shorter push rods at 7'', according to the calculations PTV clearance is good and on the safe side, this was my worst case scenario valves crashing into pistons. On the LS series they recommend to stay below a .600 max lift on the valves other wise you will need to shave pistons or add a thicker gasket or adjust cam timing.
Here are a few pics of the MLS gasket, and the valvetrain set up, minus the pushrods thats why they're all up, and one pic with the taller valve covers.
Old 07-08-2013, 04:24 PM   #935
mikekaye69
Very cool indeed...
mikekaye69 is offline   Reply With Quote
Old 07-09-2013, 11:18 AM   #936
mcbassin
Still Learning
mcbassin's Avatar
Great pictures!
Old 07-14-2013, 09:10 PM   #937
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Very nice --- as usual!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-18-2013, 10:44 PM   #938
smokedat
smokedat's Avatar
Hey fellas build is coming along heads are complete and torqued rockers are set and lashed, i went with COMP Cams High Energy Pushrods at 7.00". dressed in ARP hardware from crank internals to heads.
Old 07-18-2013, 10:45 PM   #939
smokedat
smokedat's Avatar
I have a question how do i advertise my extra parts??? i tried this once here and i got deleted??
Old 07-18-2013, 11:02 PM   #940
nlped
nlped's Avatar
I think you have to post them in the "For Sale" forum. And you have to be a paying member of the forum. It's only like $25 & its well worth it for all the extra perks.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-18-2013, 11:36 PM   #941
smokedat
smokedat's Avatar
Thanks, no wonder i couldn't post my for sale items
Old 08-04-2013, 07:44 PM   #942
smokedat
smokedat's Avatar
cant upload any pics no matter how low i reduce the file size WTF. BS cant impede me from uploading pics to my thread followers.
Old 12-22-2013, 08:06 PM   #943
blazinfab
Any updates on this ?
blazinfab is offline   Reply With Quote
Old 12-30-2013, 12:35 AM   #944
1987cut
1987cut's Avatar
Awe man!?!? I just read this whole build up to this point. What a disappointment. I just knew I was going to see the finished product! Please update!
1987cut is offline   Reply With Quote
Old 12-30-2013, 09:20 AM   #945
mcbassin
Still Learning
mcbassin's Avatar
Where you at Alex?
Old 12-30-2013, 11:36 PM   #946
Jake Wade
Jake Wade's Avatar
I just found this thread and went through all 38 pages. You really,really have some serious skills man. Nice work!
Jake Wade is offline   Reply With Quote
Old 12-31-2013, 12:01 AM   #947
blazinfab
Talked to him other day, said he's taking a break for a bit!
Old 05-13-2014, 08:44 AM   #948
NastyBuzzard
NastyBuzzard's Avatar
Wicked.. Just read through all of this. Excited to see the finished product!
NastyBuzzard is offline   Reply With Quote
Old 07-05-2014, 02:01 AM   #949
naphtali5725
naphtali5725's Avatar
any updates???
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 07-05-2014, 02:53 PM   #950
kvn1011
Kvn1011
kvn1011's Avatar
fingers crossed for an update!!
kvn1011 is offline   Reply With Quote
73c10, c10, cheyenne, ls1, swap
