Old 07-13-2011, 01:15 AM   #1
tll74
"Junkyard Dog"
tll74's Avatar
100's of misc parts from the last 6 trucks parted out
Hi guys, I have sorted out a bunch of parts from the last 6 trucks I have parted out. Al parts are cleaned and ready to ship. . Shipping on small items will be via USPS and larger-heavy items will be via UPS. I will respond to all post in the evening as I have a 8-5 daytime job. I'm on the west coast so I'm 2-3 hours behind many of you. Combined shipping no problem. Please reply in the thread.
Thanks, Tom
Please list what you are paying for rather it be Paypal or a mailed check.
Pic 1
Visors 20.00 each Black and one pair of olive green are Sold
inside mirrors: 71 olive green better than average glass 23.00 SOLD, 69-70 brown and black average glass 17.50
72 LH armrest needs painted DQ 10.00 SOLD
67-68 armrest 17.50
2-72 olive green armrest 17.50 each Sold
3-70 olive green armrest 17.50 each
70 olive green seat belts 2 pass 95.00 very nice Sold
68? green (turquoise?) 3 pass 125.00 very nice on hold, the wife thinks she wants them for her 68
Glove box doors 1 green 69 GMC, 1 brown 70 GMC, and 1 green Chev 22.00 ea
2 67-70 front - rear (first connection) brake lines nice cond 25.00 ea. plus sh.
3 ashtrays all green 12.50
Dome lens housing with wiring (was chrome) 12.00
2 67-70 GMC horn buttons 9.00 each
head liner retainers tan from 70 GMC with gold interior 7.50
5 headlamp switches with plain and chrome knobs 10.00 each
6 wiper switches with plain and chrome knobs 7.50 each
cigarette lighter 7.50
Pic 2
2 RH outside door handles DQ 15.00 each
2 LH outside door handles DQ 17.50 each SOLD
10 inside door handles 7.50 each
6 window cranks 7.50 each
71-72 turn lens housing nice 17.50
1 back up lens nice 7.50 each
3 tail lamp lens nice 12.50 each Sold
cargo lens, housing (pitted) and rubber 15.00 Sold
cargo lens, housing (nice), rubber, switch and wiring (not in pic) 60.00
white mirrors off 1970, ding in housing, glass DQ has light scratches 50.00
5 original front amber marker lens good color 6.50 each
1 original rear red marker lens good color 6.50
2 rear deluxe red marker lens good color 8.50 each Sold
2 front deluxe amber marker lens faded 6.00 each Sold
4 GMC turn lens-housing good color 15.00 each
5 horns 10.00 each
dome lens and white housing 12.50SOLD
dome lens and chrome housing (chrome gone) 8.50
5 wiper arms with original blades 12.50 each
4 wiper arms without blades 10.00 each
1970 350 point distributor 25.00
4 e-brake cable from cab to frame 18.00 each (only one in pic)
cab vent 6.00
washer res. cap w/hose 4.00
spark plug heat shield set- acid dipped and rust free 27.50SOLD
3 windshield washer hose sets complete 12.50 each
Pic 3
Fender emblems:
2 GMC 1500 V8 8.00 each
2 GMC 2500 V8 8.00 each
2 GMC 2500 custom camper 8.00 each
2 67-68 chev 20 8.00 each SOLD
69-up custom/10 10.00
1 pair K/5Blazer 40.00SOLD
1 pair Custom/20 27.50 (I hot tanked these and the black is gone)
1 pair Sierra Grande 75.00 nice, no studs
1 pair Custom good studs 11.00
8-350 7.50
deluxe 5.00
2 tail gate center moldings 12.50 eachSOLD
4 E-brake cables with all supports LWB only 27.50 each
4 oil pressure lines for sbc 10.00
4 GMC turn/park lamp wire looms 6.00 each
2 ground straps (valve cover-firewall) 3.00 each
2 vent pull rods w/knobs media blasted 4.50 eachSOLD
RH GMC eyebrow minor ding nice driver 15.00
LH GMC eyebrow ding lower corner DQ 15.00
2 69-72 sbc alt brackets complete w/bolts 29.50 each
69-72 sbc upper alt adjustment bracket 15.00
2 67-70 throttle mech. w/ 2wd-Q-jet rod 22.50 each
67-70 gas pedal 7.50
2 69-72 steering column intermediate shafts 27.50 each
2 lower metal steering column bezels 5.00 each
2 lower dash pedal stop brackets 6.00 each
67-68 2wd LH exhaust manifold original GM nice condition 65.00
67-72 2wd RH exhaust manifold used aftermarket plugged A.I.R. holes 50.00
69-72 sbc 2 groove water pump pulley 13.00SOLD
67-72 sbc single groove crank pulley 11.00SOLD
sbc LH exhaust gasket sleeve 5.00
sbc RH exhaust gasket sleeve 5.00
RH 71-72 headlamp bezel DQ minor sand pit 12.00
LH 71-72 headlamp bezel DQ small ding-sand pit 9.00
67-72 GMC RH chrome headlamp bezel nice 17.50
70 green dash bezel only chrome in typical cond. Sold
Pic 4
4 69-72 7 blade flex fans 23.00 each
70 1/2T Bendix power brake booster assy w/prop. valve 75.00SOLD
71-72 3/4T Moraine dual diaphragm booster assy w/prop. valve 85.00
3 original antenna's 2 telescoping and 1 single mass (newer mast) 33.00 ea. One tele. antenna (w/o spring) SOLD
set of door edge guards very nice DQ 25.00
71-72 gas pedal w/cable 27.50 SOLD
3 taillamp wiring harness's for lwb (from cab to bumper) 15.00 each one sold 2 remaining
More to come.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline
