Old 05-03-2022, 12:12 AM   #951
Gregski
Post Whore
Gregski's Avatar
Re: My Dusty 71 GMCe Electruck
once those three are individually loaded and bolted up, we simply flip that batch over - right side up
Gregski is offline   Reply With Quote
Old 05-03-2022, 12:13 AM   #952
Gregski
Post Whore
Gregski's Avatar
and now we are ready for the top batch
Old 05-03-2022, 12:14 AM   #953
Gregski
Post Whore
Gregski's Avatar
and there we have it, "The Stack" configuration (genius I tell yah, genius!)
Old 05-03-2022, 12:16 AM   #954
Gregski
Post Whore
Gregski's Avatar
now every battery pack has it's pros and cons, be it a Tesla pack, a Nissan Leaf, or this BMW 530e, and this one is no different, one of the downsides of it is these unobtanium proprietary high voltage cables, it is a real challenge to reconfigure the standard pack layout whilst utilizing only the stock high voltage cables
some like this one joins two cell modules very smartly.... (we like, we approve)
Old 05-03-2022, 12:17 AM   #955
Gregski
Post Whore
Gregski's Avatar
by Gregski » Mon May 02, 2022 7:57 pm
here is one BMW 530e battery pack (Embedded Fun Fact: which consists of six cell modules, unlike the 330e which only has five) reconfigured in The Stack Formation, unfortunately we are unable to complete this arrangement because we are one cable short, technically we have the cable but it is just too short to join Cell Module #2 to Cell Module #3
Old 05-03-2022, 12:18 AM   #956
Gregski
Post Whore
Gregski's Avatar
Ladies and Gentlemen, the Battery LifterUpper (TM)
Old 05-03-2022, 12:19 AM   #957
Gregski
Post Whore
Gregski's Avatar
I'm a Simple Man, I see a gap... and I fill it!
Old 05-03-2022, 12:20 AM   #958
Gregski
Post Whore
Gregski's Avatar
yes we did run out of gas... (no literally)
but we recovered, and one side's done
Old 05-03-2022, 12:21 AM   #959
Gregski
Post Whore
Gregski's Avatar
and onto the other side, having the frame rails level now is a total game changer
man I love a clean canvas
Old 05-03-2022, 12:25 AM   #960
Gregski
Post Whore
Gregski's Avatar
alright, let's load 'em up proper
Old 05-03-2022, 12:29 AM   #961
Gregski
Post Whore
Gregski's Avatar
now I currently only have one pack installed here, but hopefully you'll get the idea how this design is meant to hold two of them, six cell modules on top and anther six upside down
this will yield 18.2 kWh
so at 3.5 miles per kWh we guestimate a range of 63.7 miles
keep in mind this is just a start, I can install more batteries under the bed
Old 05-03-2022, 03:10 AM   #962
jimbosprint
jimbosprint's Avatar
Excellent progress. I'll have to stop by to check this out in person next time I drive that way.
jimbosprint is offline   Reply With Quote
Old 05-03-2022, 09:05 AM   #963
Gregski
Post Whore
Gregski's Avatar
Thank you, Indeed! bring your wire wheel, this purple paint aint gonna fall off by itself, ha ha
Old 05-03-2022, 10:11 AM   #964
Gregski
Post Whore
Gregski's Avatar
so time to make a List for Phase I as I plan on doing or should I say NOT doing some stuff in this Phase that may be a bit controversial
PHASE I PROGRESS REPORT
  1. Mount Lexus transmotor - ✔
  2. Install modified Lexus drive shaft - ✔
  3. Mount transmission fluid pump controller
  4. Mount Lexus inverter - ✔
  5. Mount Honda CRV brake booster - ✔
  6. Install Toyota Prius power steering column - not happy with this install (my job, not the part)
  7. Install first BMW 530e battery pack - ✔
  8. Lay down the Controller aka VCU on the floor inside the cab
  9. Install modified BMW 530e pre charge circuit aka "Safety Box"
  10. Install Chevy Volt first gen DC-DC converter
  11. Install BMW E46 throttle pedal
  12. Install B&M transmission floor shifter
  13. Install Tesla Model S water pump
Not happening in Phase I
  1. Lock input shaft in the Lexus transmotor*
  2. Install onboard battery charger**
  3. Install Battery Management System aka BMS***
  4. Install customized digital gauges
  5. Install second BMW 530e battery pack
the Controversial Section (we can thumb wrestle over these items if you like - by appointment only, ha ha)
* Input Shaft, I want to dyno test the truck with only MG2 powering the rear wheels to see how much horse power it actually puts out in real life
** no Charger, this is the first of the radical ideas, why do we need a battery charger mounted on board permanently, isn't that the equivalent of driving around with your very own gasoline/petrol pump, can you imagine pulling up to SHELL or Chevron with your own pump mounted in the back of your truck?
*** no BMS, eventually I plan on getting SimpBMS but it is just so expensive here in the States, I think they want $650 for the hardware
Old 05-03-2022, 04:21 PM   #965
Gregski
Post Whore
Gregski's Avatar
Originally Posted by LT7A View Post
Ok, I see... But don't you only need one? I mean, won't it be hardwired in and so that the others will just sit on the shelf? Or are you going to try each of them out and see which one works best? Or are you starting a collection? Not trying to be silly.. okay maybe a little bit.. but definitely curious why you have so many.
Ok, I can only drive one truck at a time, and that hasn't stopped me from getting... uh, more than one... so no implied criticism, just curiosity.
excellent questions, I bought so many chargers to teach myself how they work by comparison
at first when I bought the Tesla charger I thought I could pull up in my converted electric truck to a Tesla charging station and charge, but that's not how it work's Elon Musk prevents you from doing just that, the charging station for a lack of a better term senses your car and you have to be in a genuine Tesla to use it
~ CONTROL VIA HARDWARE~
the other thing I learned is that donor EV components such as the chargers are controlled in one of two ways, either you have to lobotomize them, essentially rip out their logic board and replace it with a reverse engineered one, this is how the Tesla charger works
~CONTROL VIA SOFTWARE Type 1~
Or, you can control the charger in it's current original OEM shape without changing any of the hardware simply by learning what CAN Bus commands it needs to operate, that's how the Chevy Volt first gen charger works
~CONTROL VIA SOFTWARE Type 2~
another way to control a charger in it's OEM hardware form simply by using software is by figuring out what PWM signal to send to it, PWM aka Pulse Width Modulation, this is how the Chevy Volt second gen charger works
hope this helps
Old 05-04-2022, 10:19 AM   #966
Gregski
Post Whore
Gregski's Avatar
another day another mock up, and I'm loving how it's turning out
Old 05-04-2022, 10:21 AM   #967
Gregski
Post Whore
Gregski's Avatar
as much as I love this BMW 530e hybrid battery pack, it's Achille's heel has got to be the proprietary high voltage terminals, which call for the unobtanium plugs and wires, here I am trying to figure out how to use only the stock amount of high voltage cables to rewire it flat instead of two cell modules stacked on top like in the original implementation
Old 05-05-2022, 11:14 PM   #968
Gregski
Post Whore
Gregski's Avatar
no I didn't just spend 4 hours drilling two holes in the most unreachable of places, who in their right mind designed these silly frame extensions?!?!
Old 05-06-2022, 10:11 PM   #969
Gregski
Post Whore
Gregski's Avatar
tell me you're done with Fab without telling me you're done with Fab
Old 05-06-2022, 10:12 PM   #970
Gregski
Post Whore
Gregski's Avatar
finally... no more Purple (sorry Prince, R.I.P.)
Old 05-06-2022, 10:13 PM   #971
Gregski
Post Whore
Gregski's Avatar
the transmission crossmember also got sum red luv in our outdoor free range organic make shift paint booth
Bonus Points for clever use of not only exhaust pipes but exhaust U clamps, not like we're going to be needing them again
Old 05-07-2022, 05:58 AM   #972
72 tigger
72 tigger's Avatar
Painting =progress!!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 05-07-2022, 06:10 AM   #973
zicc1835
zicc1835's Avatar
Looks like you EXHAUSTED some of your enginenuity to get this done🤭
zicc1835 is offline   Reply With Quote
Old 05-07-2022, 09:40 AM   #974
Gregski
Post Whore
Gregski's Avatar
indeed!
Old 05-07-2022, 09:41 AM   #975
Gregski
Post Whore
Gregski's Avatar
Originally Posted by zicc1835 View Post
Looks like you EXHAUSTED some of your enginenuity to get this done��
well played, you're not just blowing smoke that's fer sure
