Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 11-10-2005, 08:53 PM   #76
BigSky71
LAIDOUT
BigSky71's Avatar
Re: Wheel/Tire Fitment Pictures & Info
I am ready to order my wheels and tires and can't decide on the size for the rear. I have decided on 255/45 18s [18x8 wheel] for the front but can't decide if I should go with 295/40 20s on the rear or 315/35 20s [20x10 wheel]. I originally planned on the 295s but my tire guy thinks the 315s would look better... I am not sure.
I think that having the sidewall heights match is important so I used the tire sizing guide at 1010tires.com and the 315s theoretically have a side wall height of 4.34". The 295/40s are said to be 4.64". The front 255/45s would be 4.51". I like the idea of 12.5" of tread width on the 315s, but wonder if the tire would look like it needs to be on a wider rim, which I don't want. I don't have to worry about having enough room for the 315s width because I have a shortened rear-end and have tubbed the bed 5.5" on each side. And the truck will have air ride so they have to tuck.
Anyone fit 315s on a 10" rim?
67 2wd Shorty
Build Pictures
BigSky71 is offline
Old 11-21-2005, 12:20 AM   #77
sinistershee
hi guys im new here and was wondering on what size tires would fit on my truck its a 72 1/2 ton 2wd lwb i want to put 20's on it and i plan on putting a 4/6 inch drop on it. will they fit? and what size tire do i need? i think a 245/40/20 or a 275/40/20 might be ok or maybe a 45 series, please let me know what you think. thanks
sinistershee is offline
Old 11-29-2005, 01:17 AM   #78
sbc421
sbc421's Avatar
Exclamation Re: Wheel/Tire Fitment Pictures & Info
Here is my setup... Tire size is 31/16.50/15 Mickey Thompson ET Streets on 15" x 12" Weld Draglite wheels with 7.5"s of back-spacing. (NO these wheels will not fit on your stock truck, however they will if you change out your axles, I went with 35 Spline Moser's) Weld Draglites only come in 5 on 4.5 or 5 on 4.75 bolt circles. I have also included a couple of pics of my trailing arm modification... I have added the ability to adjust my trailing arms up or down in the front to suit my traction needs.
1970 Model C10 LWB, Small Block 421 CID, AFR 220 Heads, 1050 Dominator, Super Victor Intake, Comp Cams Mech Roller, Comp Cams ProMagnum Roller Rockers, 13.8:1 Compression, 4500 RPM TCI Converter, TH400 TCI Transmission w/reverse manual valve body w/trans brake, 5.13 Rear Gear on a full Spool, 31-16.50-15 Mickey Thompson ET Streets
sbc421 is offline
Old 12-02-2005, 12:16 AM   #79
67-72chevyman
What is the bigest height tire can you use on the back of a 2 wheel drive half ton truck with stock suspension, without being lifted up. And how wide?
67-72chevyman is offline
Old 12-04-2005, 11:36 PM   #80
Chucky72
anyone ever thought of doing a mini tub with 15x12 with like 18 or 17x7 or even 6s for like a rail type dragster look? i have a long box so i think it will look good
maybe some one has done it if so anyone have a pictures
1972 Chevrolet C/10 LWB 350ci/350th
completely apart
Chucky72 is offline
Old 12-05-2005, 07:11 PM   #81
Slick71
Slick71's Avatar
Here's a 4x4 pic. 3/4 ton, 4 inch suspension lift, tires are 33 x 15.5 x 16 and wheels are 16 x 10. Doesn't rub, but throws the mud!!
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline
Old 12-12-2005, 01:39 AM   #82
Scottb
i had some 275/85/16's on the front with no problem and some 35X12.50's on the rear that only rubbed with about 1000 lbs on the truck if i hit a bump (never heard it, just saw some paint was worn down). 70 GMC stock height- 81 chevy control arms in front, stock dana 60 in back.... C2500
sorry- only pic i could find on short notice...
oh, found another one- both in the dark...
70 GMC C2500 BB 402, LSD Dana 60 rear, Converted to SM 465, Holley 750, Edelbrock Performer RPM air-gap intake, Flowtech Headers, 2.5" Flomaster Exhaust, HEI ignition, 81 Chevy disk Brakes.
All work done by myself. last 1/4 mile (almost 3 years ago) 15.9 @ 86
Scottb is offline
Old 12-14-2005, 11:31 PM   #83
68-shorty
I love the style of your truck!I have searched high and low to find pictures of a flat black slammed 67-72.Do you have any more pictures you could send me?I would appreciate it.My E-mail is boxwoodboy@aol.com Thanks-David
68-shorty is offline
Old 12-25-2005, 03:40 PM   #84
Blue85
Oilfield Trash
Blue85's Avatar
Can someone with a stock height SWB 1/2ton 2WD take some fender to ground measurments for me, po of my truck said it is a 2/4 drop, but seems to be a bit lower, more like 3/5.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline
Old 01-07-2006, 06:03 PM   #85
Blue85
Oilfield Trash
Blue85's Avatar
Anyone?
87 Chev 3+3 4x4
Blue85 is offline
Old 01-10-2006, 08:49 PM   #86
72MARIO
72MARIO's Avatar
Wheel to ground is not a accurate measurement. Wheel and tire sizes will vary that measurement.
I have the rear drop measurement from a few guys with ECE 6" and they have between 2.5" to 3" between the axel and frame.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 01-11-2006, 05:58 PM   #87
see ten
WTB this ad
see ten's Avatar
Wheels are 15x8 and tires are 275/60 on all four corners. Drop is Early Classic 3.5" front and 6" rear.
see ten is offline
Old 01-13-2006, 12:05 AM   #88
bighead
Wow. nice truck seen ten! Any tire rubbing problems with that combination?
bighead is offline
Old 01-13-2006, 04:24 PM   #89
see ten
WTB this ad
see ten's Avatar
Thanks man. My only rubbing problem is the rims want to rub on the control arms when the wheel is cut deep at speed. It has only happened once while pulling into a parking spot way to quick. I think it's that syndrome of combining a drop spindle and 15" wheel. I am currently shopping for some new 17" rollers that should solve the problem.
see ten is offline
Old 01-13-2006, 04:34 PM   #90
72MARIO
72MARIO's Avatar
I will confirm that the rim width is the issue. I have 7" van rallys up front and they have never hit the controll arm. That 1" must be the clearance needed.
My front drop is 2.5 spindle and a 1" coil.
2005 TAHOE DD
72MARIO is offline
Old 01-14-2006, 01:03 PM   #91
davidh
davidh's Avatar
I love the back view. How much land you got? You could hide a few parts trucks back in those trees as well. Nice shop too.
davidh is offline
Old 01-14-2006, 09:36 PM   #92
see ten
WTB this ad
see ten's Avatar
I will be sure to pass on the compliment to my buddy who owns the place . His shop is the same size as mine but since he has a torch and a mega air compressor we did the drop at his place. As far as acreage there lets just say "a lot".
see ten is offline
Old 01-18-2006, 06:21 AM   #93
gringoloco
A guy with a truck
gringoloco's Avatar
Found this tonight: http://www.autowaretech7.net/nextwheels/newstal.htm
It has over 300 different classic cars/trucks and a boatload of sweet wheels.
Also allows you to lower the vehicle, change wheel sizes and change colors. Veeeery coooool!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline
Old 01-18-2006, 09:17 PM   #94
ozzcart_83
1970 with 68 bed, 67 front clip, dropped 2.5/4, 2.5 drop coils up front, and 4 inch blocks in the back. 18 inch american eagle series 187. 245/45/18 all the way around.
ozzcart_83 is offline
Old 01-19-2006, 01:26 AM   #95
smbrouss70
smbrouss70's Avatar
Got a bigger pic?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline
Old 01-19-2006, 01:32 PM   #96
roughedup72
roughedup72's Avatar
heres mine before with 235/75/15 and after with 285/70/15's on all four.
roughedup72 is offline
Old 01-24-2006, 11:27 PM   #97
hirdo
I have a 72 longhorn C30. I just ordered 18X9 rims. The truck is stock height. I could use some help in picking the right tire size. Thanks
hirdo is offline
Old 01-31-2006, 11:35 PM   #98
incoma
incoma's Avatar
see ten - are your inner fenders out of that truck? I'm running a 2.5" front drop and it looks like my tires will hit the inner fenders if I go over a bump. I noticed that you said you had some rubbing when cutting corners, and didn't see any comments on the inner fenders, so I thought I'd ask.
incoma is offline
Old 02-01-2006, 12:58 AM   #99
72MARIO
72MARIO's Avatar
I will chip in and answer your question. I am running 2.5 spindle and 1" coil. 255/60's on the 7" van rallys. NEVER has it rubbed in the last 4000 miles. I am sure both of our trucks have inner fenders.
Only diffirence is he is using 8" rallys and 275/60 up front.
What rim size do you have ?
2005 TAHOE DD
72MARIO is offline
Old 02-01-2006, 09:53 AM   #100
incoma
incoma's Avatar
I'm running 235/75/15 on 8" rally's today, but want to put some 255/60/17 on the truck. The 17" will have more backspacing, probably 5". Just looking at my current 27.5" setup, I've only got 3-4" between the tire and the inner fender. I just thought our suspension moved that much when going over bumps in the road.
I don't want to goof up my powder coated chassis!! Thanks for the input.
incoma is offline
