#76 |
Re: Jebb's Project 1959 GMC
Cleaned and painted most of the rear frame today. I removed all the E-Brake stuff that has not been hooked up since the rearend swap.
1959 GMC project |
#77 |
![]() Also installed the flip kit just to get an idea of how it worked and how everything will line up. I got stuck because the kit changes the way the U bolts mount to the rear end. I got new U bolts that are longer and will work but the plate that they bolt to is different also now. I am going to the junk yard tomorrow to get flat ones so I can bolt it together. I looked at my Dad's 83 pickup and it has the right kind so that's what I am looking for. ![]()
1959 GMC project |
#78 |
Hollister Road Co.
just weld in that C clamp. it will put the thrill back into driving.
#79 | |
1959 GMC project |
#80 |
Gone Fishing
ah cmon shawn live a little
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
#81 |
Nice work buddy! Are you notching the frame?
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#82 |
Thanks Cali, the C-Notch is coming soon. A friend of mine's Dad is going to let me bring it to his house for that. He has everything I am going to need to do it plus he is going to help out. I need to get the rearend set up first so I can calculate the cut better. It will also need to get all 4s touching ground again and that's gonna take some money that I don't have just yet.
1959 GMC project |
#83 |
Yellow truck club
It should roll nice on those red rims!!
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#84 |
NICE!!! Keep up the good work!
![]() We got the cab off our '59 Chevy Truck frame. We cleaning up the frame.
#85 |
Nice work
54 Chevy Bel Air 4dr powerglide 54 Chevy SWB 58 Chevy Big Window SWB Fleetside project 58 Chevy LWB 235/4spd 76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine 79 Chevy 4x4 SWB 350/4spd 3/4 ton 81 Mazda RX7 84 F@!d Mustang 96 F@!d Ranger 2.3L/5spd |
#86 |
Thanks guys, got my junk yard tresures today so I am off to work again on Monday.
1959 GMC project |
#87 |
Wow it's low!!!! Flipped rearend and 2 inch lowering blocks. I think it may be a little lower than the front is going to be with the motor in. Only time will tell i guess?????
1959 GMC project |
#88 |
![]() ![]() ![]() Moched her up a bit just to take a look. Aslo got the non power steering box cleaned up and mounted. ![]() ![]()
1959 GMC project |
#89 |
1959 GMC project |
#90 |
Hollister Road Co.
That’s going to look good at that height
#91 |
Look's good buddy!!! Did you get the flip kit on the rear taken care of?
#92 |
Yes Sir! This is just how it is going to bolt together. It is all coming apart again for the C Notch and new leafs. As you can see it also needs some clean up work. I am really happy with the stance!!!
1959 GMC project |
#93 |
Gone Fishing
Thats stance will look sick when completed.
#94 |
Jebb,
Nice job on your project! ![]() Thanks, Leroy
#95 |
Apache Club
looks good
![]() ![]() My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) ![]() |
#96 | |
![]() ![]() Thanks for all the compliments guys! ![]()
1959 GMC project Last edited by Jebb1978; 05-24-2006 at 08:25 PM. |
#97 |
Hollister Road Co.
I used that same stuff except I also used their primer that is for slightly rusty metal
#98 | |
Nice stance, looking good Jebb.
#99 | |
![]() Thanks, Leroy
#100 |
Good luck Ice!
Thanks Apache, get off your drunken butt and get some work done!!!! ![]() ![]()
1959 GMC project Last edited by Jebb1978; 05-25-2006 at 09:59 PM. |
