03-22-2009, 01:23 AM | #76 |
Re: Getting Started
Are those DM sbc to LS conversion mounts?
I asked Nate about some a while back (@ least 2-weeks ). I mentioned the need to offer this very item to his original DM customers as they updated their sbc equipped rides w/modern, more efficient power-plants.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-22-2009 at 01:23 AM. |
03-22-2009, 02:33 AM | #77 |
True Addiction
Re: Getting Started
SCOTI, You would be correct, I hope. I have the 4L60E to go along with it. I'm going to put them in the truck next week, so hopefully they will go in with ease. I know the cab will need some space. I don't know bout the trans X member though? I'll find out when I get there, If I ever do. I assume it's not bolt in for the LS????
Any other comments are very welcome..... Thanks
RCC |
05-13-2009, 11:45 PM | #78 |
True Addiction
Re: Getting Started
Sorry about the Flash! I'm not as smart as the Camera. Turns out I have to run a 4L65E sunshine bell housing, so the transmission is still out.
RCC |
05-14-2009, 01:07 AM | #79 |
Re: Getting Started
Looking AWESOME Ben!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
05-14-2009, 07:46 AM | #80 |
Happy to be here
Re: Getting Started
Are those Boyd V-twins? Where did you get them?
05-14-2009, 07:48 AM | #81 |
One day...
Re: Getting Started
Wow those look good!!
05-14-2009, 09:00 AM | #82 |
Junior Member
Re: Getting Started
Lookin good man!
05-26-2009, 10:51 PM | #83 |
True Addiction
Re: Getting Started
Thanks for the compliments. I am buying some tires this week, but wasn't sure if these would be ok. In the rear I'm thinking the Nitto Invo, 295/25ZR22. The tire spec's say only to mount on a 11.57" wide rim. Mine are 12", but don't you think thats ok? Anyone know of any other options? I want them to be low profile of course. Thanks again for all the help.
RCC |
05-26-2009, 11:34 PM | #84 |
Happy to be here
Re: Getting Started
Are you set on running a 25 series? Your not going to like the ride.
BTW- Turn your flash off. Most digi-cams have the ability to enhance the existing light.
05-27-2009, 06:00 PM | #85 |
True Addiction
Re: Getting Started
N2TRUX- Thats a tremendous help, I think you where just wanting to make your 21,469 post?
RCC |
05-27-2009, 10:43 PM | #86 |
Happy to be here
Re: Getting Started
Naah, I could care less what my post count is. If I really wanted a big post count I would just change it...
06-01-2009, 11:20 PM | #87 |
True Addiction
Re: Getting Started
Ok guys, I really need some advice. Here's one other option I've found. This is a Toyo Proxes4. It's 305/25ZR22 99W RD. I honestly haven't been able to find a tire that fit's a 22x12" wheel. Thanks in advance
You think you can get away with mounting a tire recommend for a 11.5" wheel on a 12". Also, is the 25 series that bad? Even though it's a rubberband
RCC |
06-01-2009, 11:33 PM | #88 | |
Seņor Member
Re: Getting Started
Yes. Get a kidney belt for your Sunday drives, and plan to replace those wheels if you hit a pothole.
06-02-2009, 12:07 AM | #89 | |
Happy to be here
Re: Getting Started
I have never run a 25 series tire, but I think I know the answer. Like XXL said, they are going to beat you silly. Sure they look cool, you have to decide how much ride you are willing to sacrifice for looks. Here's a set mounted up. Doesn't look like much potential for sidewall flex here.
06-02-2009, 12:11 AM | #90 |
True Addiction
Re: Getting Started
I'd be more than happy to run a tire with more side wall if Ii could find one that fit a 22x12 wheel. Anyone know of one?
RCC |
06-02-2009, 10:22 AM | #91 |
Seņor Member
Re: Getting Started
Sidewall...
06-02-2009, 10:42 PM | #92 |
Happy to be here
Re: Getting Started
Looks like a match up. What tire is that?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-02-2009 at 10:42 PM. |
06-03-2009, 12:14 AM | #94 |
True Addiction
Re: Getting Started
XXL, Thanks for the info. I really appreciate all the help I can get. Thanks again.
RCC |
06-10-2009, 10:44 PM | #95 |
True Addiction
Re: Getting Started
Anyone else? This 12" wide wheel is causing a little trouble. I was hoping to stay under 30" overall height. Anyone know of some close up pics of 25, or 30 series? Is the side wall 2"? Thanks again.
RCC |
06-10-2009, 10:55 PM | #96 |
Seņor Member
Re: Getting Started
I gave you a link in post #93 where you can get all the details you're looking for. Spend a little time on the site and you'll find the info you're looking for.
07-12-2009, 10:30 PM | #97 |
True Addiction
Re: Getting Started
I finally got some rubbers. Also got my 4L80E put in. Man that thing's huge.
RCC |
07-12-2009, 10:45 PM | #98 |
Happy to be here
Re: Getting Started
Looks great! What is it? Why did you choose a 4L80E ? That's a bit of overkill unless your running a BIG motor.
07-12-2009, 11:37 PM | #99 |
True Addiction
Re: Getting Started
Well, I was looking for a 4L60E, the guy I was dealing with was having trouble getting one. He had several 4L80E's so I took on instead. Guess I'll have to juice up my motor. Tires are Yokohama's. There proud of them too.
RCC |
07-13-2009, 12:41 PM | #100 | |
*NO REGRETS*
Re: Getting Started
