#76 |
Re: '68 C10 Short-Step 6.0 + TT swap
oooo..... good catch! what kinda power u aiming for?
#77 | |
Local Redneck Authority
![]() Updated Turbo pics with the flipped manifolds please! I don't have much experience with tuning turbos on gas engines, but it sounds like a fun time! What about starting with some flipped block hugger headers? Are you tying both sides of the exhaust together, with a Y pipe underneath, or just running off the pass. side? Nice work, beautiful welds! ![]() |
#78 |
Still Learning
Hey, just curious if the main and rod clearance issues come from the machine shop you used or is that part of the rotating assy stock? Probably a dumb question seeing how stout your frame and rear is. I assume you built the engine like a brick crap house. Anyway, I just wonder if a stock engine has too tightly clearanced bearings? Keep up the build
#79 |
![]() Join Date: Sep 2008
No, not running. Another motor at the same HP levels spun a bearing, and investigation led us to the culprit. Pulled my motor just to check so I could sleep well, and well...it wasn't as we asked for & was too tight. Just got lucky, but my buddy wasn't so lucky. His failure saved 2 motors that were moments away from self destructing.
Both. Stock clearance is too tight for my HP goal, and I specifically asked for looser tolerances to compensate for it. Yes, it is a forged motor. 1,000 ish is the current HP goal.
'68 Chevrolet Short Step
6.0 L + 91mm + TH400 + 9" + 4-Link |
#80 |
SCHWEEEEEET!!! thats awesome man, tuned im lookin for 1200 out of mine, cant wait!!!
#81 |
Well, no motor news yet, so I finished my gauge cluster. I am by no means trying to make it look like a billion dollars, but I think it turned out OK for my first try.
#82 |
looks like thatll do the trick! whered u get the guages from?
#83 |
VA72C10
![]() Join Date: Mar 2008
looks good and plenty functional.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#84 |
I wish I could say somewhere interesting and got them at 1/4 price, but I didn't!
Summit.
#85 |
Still Learning
Awesome instrument cluster! Turned out great. I got one that needs this mod.
#86 |
haha cool. yeah i would love to redo my cluster with autometers, just not in the budget right now. does look great though!
#87 |
How about an update? LOL
Motor is back & in. Plumbed cold side of turbo & intercooler. 5" downpipe is finished. Since these pics, it has all been finish welded. Next week hope to finish all oil/trans/turbo oil feed & drain lines. Maybe the stainless headers too. ![]() ![]() ![]() ![]()
#88 |
67cheby
Holy smokes !!!!!! That is crazy
#89 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Wow man very nice...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#90 |
looks awesome!
#91 |
Looks great! I may have missed it, what are the specs on your turbo?
#92 |
How much boost you planning on? looks like an easy 600+hp
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#93 |
Thanks everyone. Turbo is a 91mm Garrett.
No planned boost level, just whatever it will take. Probably 15+ with the right fuel.
#94 |
Me likey!!!! I just figured out I need your motor.....
#95 |
Wow how time flies when you have kids & crazy work schedule. I thought I would update with the current news....IT RUNS!!! Last night was the 3rd heat cycle on the new motor. Mucho props to DBRODS shop for helping me with getting this build closer.
Vid link for startup: http://youtu.be/UpwCbmBiw7A
#96 |
67cheby
SICK ...man that is TOO COOL !!
#97 |
looks good. subscribed
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
#98 |
VA72C10
so when is the first pass scheduled for?
#99 |
October 15th is a meet I am trying to make. Not much time to get the kinks worked out between now & then.
Thanks for the kind words everyone, it has been a long process.
#100 |
Still Learning
Awesome work!
