Old 07-13-2009, 12:43 PM   #76
sams60gmc
sams60gmc's Avatar
Re: my build thread
Here are some pictures of my new hoods. Not sure what I'm going to do yet but I think the one on the truck right now will be easier to fix. Let me know what you guys think.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 07-13-2009, 09:11 PM   #77
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: my build thread
Tip from an old junkyard guy, Look for hoods from schoolbuses. There higher up so less likely to get damaged and retired earlier cause they were not allowed to transport public after a few years. I can still see 37 on the front of my hood even though it had been blasted primed and painted.
Old 07-13-2009, 11:13 PM   #78
Captainfab
60-66 Nut
Re: my build thread
It's kind of hard to tell in the pics just how bad the one with center damage is. But if you can weld sheetmetal, I would think the one with the corner damage might be easier. If you can get that section from another hood, cut out the bad and weld in the good piece. Being on the side where there is more rigidity, there would be less warpage from the welding. On the other hand if the one with the center damage could be hammer and dollied out then that might be easier. To make that easier you could cut out the inner structure for easier access. Then weld that back in when done.
Old 07-29-2009, 03:45 AM   #79
sams60gmc
sams60gmc's Avatar
Re: my build thread
Got an idea today and started pulling the front end for my cross member conversion. Super hot here 113 today so I'm not sure how fast I'll get this swap done. I'll get some progress pictures up soon. Pulled one of my hoods apart and almost got most of the dents worked out of it. A little more finish work and it will look good and then I have got to spot weld the front piece back on it.
Old 09-01-2009, 12:28 AM   #80
sams60gmc
sams60gmc's Avatar
Re: my build thread
Little upate on my truck. I've got the front end all back on the ground now. I've got to make the steering box adapter and do the brakes then its all done. I cut my 12 bolt apart and now I've just got to mock that up and weld on trailing arm saddles. I went to the junk yard today and tried to trade my 7'' wide rally for a 8'' that I found and the guy said if I could find my recipt I could. I ran home and couldn't find it so I bought it for 20 bucks. I've got my hood cut apart right now and I'm some patch panels off of the green hood to repair the dents on the grey hood. I've got my glove box door back off and I'm doing a different design on it now. Here is a picture of the pinstriping I did on the back of my truck. I also bought a set of 1960 ish valve covers off eBay for when I get my small block going. I found an old air cleaner I need to get too. But thats it for now. I'll try to get some pictures up as soon as I get the rear end under the truck.
Old 09-01-2009, 12:36 AM   #81
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: my build thread
Hard to tell in the pics which one is the better one. Nice progress so far.
Alan's Classic is offline   Reply With Quote
Old 09-18-2009, 11:47 PM   #82
sams60gmc
sams60gmc's Avatar
Re: my build thread
Been awhile since I've updated this but not much has got done for a while. I got my axle all stripped down and my axle saddles just got here in the mail. I need to make a steering box adapter and do the brakes and then the front end conversion is done. I went scouting and found another 8'' wide rally wheel in the back of the truck that I got the 3 8'' ones and the 1 7'' wide wheel so now I'll have a matching set. Anyways I don't have any pictures other than this pinstriping one. Hopefully some progress pictures in the next couple weeks.
Old 09-19-2009, 02:12 AM   #83
Captainfab
60-66 Nut
Re: my build thread
Good looking striping.....
Old 09-19-2009, 08:53 AM   #84
scotts62
One day...
scotts62's Avatar
Re: my build thread
Yeah That looks good!
Scott
93 crew cab build
Project 62
Old 09-26-2009, 02:11 PM   #85
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thanks dudes!
Old 10-03-2009, 03:16 AM   #86
sams60gmc
sams60gmc's Avatar
Re: my build thread
Little update. Got my steering shaft cut and re-welded today. And finished up my power steering box bracket. I had to cut it and re-weld it because I found out the on the 1960 frames the rear upper bolt is too high. So I moved my hole down on the steering box and fixed my adapter plate. I will take more pictures of the plate tomorrow. It is all finished now and has ground down corners and looks pretty good. I also cut the top off of my box so it doesn't have 2 holes. Now I just need to mount it up.
Old 10-28-2009, 07:45 PM   #87
sams60gmc
sams60gmc's Avatar
Re: my build thread
Got some work done on the hood yesterday. And the steering box almost all the way in. Picked up some .040 over flat top slugs for my motor and a good crank. Thinking about dropping the motor off to get bored next week.
Old 12-16-2009, 01:45 AM   #88
sams60gmc
sams60gmc's Avatar
Re: my build thread
Well finally some real progress for this build thread. I bought 2 stepside beds for 125 bucks. Sold one for half and picked up some year correct stepside fenders for 50 bucks. So in the process of thinking about shortening my frame I just decided I would rather build a custom back half from the cab back. I made it out of 2x4 and has a 7'' notch built in. The front tube is just in there to keep it square. And when I cut my frame and weld it in it will be a shortbed. All the bracketry is out of 1/4'' plate. It will be a wishbone style 4 link. The bed will have a false floor, should only lose half of it.
Old 12-16-2009, 01:47 AM   #89
sams60gmc
sams60gmc's Avatar
Re: my build thread
Here are the beds that I bought. The fenders I got are in perfect shape altho I don't have any pics of those right now.
Old 12-16-2009, 08:56 AM   #90
scotts62
One day...
scotts62's Avatar
Re: my build thread
Cool! Looks good
Scott
93 crew cab build
Project 62
Old 12-16-2009, 09:28 PM   #91
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: my build thread
Looking good sam you must be the one at work looking for a tailgate? george was askin me about one.. I have the number to a guy who may have one... Truck looks great and the pinstripe in is killer looking....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-16-2009, 09:35 PM   #92
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thanks! Yeah I'm looking for a gate. George has one but I'm looking for the early style script. I'm not in a big rush it will be a while. Next week I'll get my axle mocked up and my ride height set in my backhalf. Need to order another bag too.
Old 01-16-2010, 02:45 AM   #93
sams60gmc
sams60gmc's Avatar
Re: my build thread
Progress! Got my bags in the mail, sold my long bed to order some more bags for the front. Dominator 2600's all around. Here are some progress pictures of the rear end.
Old 01-16-2010, 10:26 AM   #94
FRENCHBLUE72
PROJECT 7DEUCE
Re: my build thread
Looking good looks like Im gonna have to finally get back to work on mine...
MEMBER #6377
Project "7DEUCE"
Old 01-20-2010, 11:59 PM   #95
sams60gmc
sams60gmc's Avatar
Re: my build thread
The rear end is coming together. I've got 2 more bags on the way for the front end. I'm really happy with how its coming together.
Old 01-23-2010, 01:10 PM   #96
sams60gmc
sams60gmc's Avatar
Re: my build thread
lower links
Old 01-23-2010, 02:26 PM   #97
FRENCHBLUE72
PROJECT 7DEUCE
Re: my build thread
Looking good sam thanks for showin it off when I was down in the shop... I should have brakes by the end of today hopefully just waitin on the mail man for my powdercoat.. Also I have a pair of wheels for ya if you want them I just want them outta the yard..
MEMBER #6377
Project "7DEUCE"
Old 01-23-2010, 02:28 PM   #98
sams60gmc
sams60gmc's Avatar
Re: my build thread
Sure man I'll take them.
Old 03-19-2010, 10:33 PM   #99
sams60gmc
sams60gmc's Avatar
Re: my build thread
Here ya go Luke. I got it off the jack stands aired up then put it on the ground! Can't wait til its Z'd and that bumper lays.
Old 03-19-2010, 11:06 PM   #100
scotts62
One day...
scotts62's Avatar
Re: my build thread
Hey man looks good!!
Scott
93 crew cab build
Project 62
